3rd gen Brake light diagram
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ja50n, Jan 15, 2022.
  1. Jan 15, 2022 at 3:49 PM
    ja50n
    ja50n [OP] New Member
    Hi,
    I recently bought a aftermarket taillight bar from Opt7. My 2022 Toyota Tacoma truck doesn’t have the 7-pin connector near the license plate. I want to hard wire this directly to my tail lights but I want to know which wires to use.
    When you take off the tail light from the truck, there are 3 lights.
    Top one: Turn signal
    •3 wires
    -Thick yellow wire
    -green wire
    -white with black stripe wire
    Middle one: Brake light
    •3 wires
    -blue wire
    -green wire
    Bottom one: Reverse light
    •2 wires
    -red wire
    So my question is, is there a diagram that shows what each wire is. And which one should I connect the tail light bar to.
  2. Jan 15, 2022 at 4:54 PM
    caribe makaira
    Caribbean, Puerto Rico
  3. Mar 10, 2022 at 11:24 AM
    EOT Craneman
    EOT Craneman Well-Known Member
    Plano, TX
    2020 Access Cab
    I am trying to wire in a brake light on my camper top and need to know which wire to tap into. I think the middle light is the correct one but I'm not sure if it's the blue or green wire. I think White/Blk is the ground.
    Did you ever get an answer to this?
    tacotommy22 likes this.
