3rd Gen brake pad swap turns into full caliper/ rotor replacement
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Koolbreeze7, Dec 26, 2022.
  1. Dec 26, 2022 at 3:55 PM
    Koolbreeze7
    Koolbreeze7 [OP] GRILL MAN
    Jon
    Jersey
    2017 TRD Sport 4x4 DCLB Black, Trail Limo. RIP- 2009, 2000, 91,89,87 trucks
    Rigid pod fogs, SpartanX stealth grill and hood LED's, 17" SEMA's on 275/70/17 Falken Wildpeak AT3W's, Fox 2.0 on all corners , TRD CAI, LEER 100XQ Blacked out, w/ Thule racks, and Cargo slider Flow master American Thunder "dual" exhaust, remote start, tint, TRD Pro grill and TRD shadow graphics, Alcan custom 8 leaf Spring Pack
    Bought new $21 Bendix Semi metallic pads to get me by until I performed the 13H Lexus Big brake upgrade in the Spring. Took wheels off to find that the OE driver's side top 13G caliper piston was stuck. Had to remove the caliper to retract the pistons. It appears that the boot is corrupted. I lubed it up and it appears and drives/ stops OK. This exact piston failed on my 2nd Gen. I worked it free for now, and noticed some rust on all of the pistons. I installed pads and will get to ordering the parts I need as the weather will be a bit warmer this week. Ironic that of the 4 pistons the same one failed on me twice. At least I got to use my new Rigid Octane Impact gun.
  2. Dec 26, 2022 at 4:01 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    You mean OEM 13WG caliper and bigger 14WA caliper?
    shakerhood likes this.
  3. Dec 26, 2022 at 4:15 PM
    Koolbreeze7
    Jon
    Jersey
    The lexus GX470 upgrade uses the 13WH caliper. Are you suggesting ones that require a bigger brake booster? I did this upgrgade on my 2nd gen and it was an improvement
