3rd Gen---BTLM + LED Retrofit
Discussion in 'Lighting' started by MESO, Jan 1, 2017.
  1. Jan 17, 2017 at 10:18 AM
    #61
    Boogyman
    Boogyman Well-Known Member
    Phoenix
    Corpus Christi, TX
    2022 Lunar Rock Trail Edition
    Yeah I'm referring to the outer led strip. I've been looking to do it myself but my first tail light retro failed miserably
  2. Jan 17, 2017 at 10:28 AM
    #62
    TRSAndrew
    TRSAndrew Instagram: @apissues Vendor
    ATL
    ‘22 4Runner, ‘14 F150, and I’ve had 4 Tacomas (‘12, ‘15, ‘16, ‘18), 2 FJs
    Ahh okay. It could be a bit tricky to get that to look right in an application that's a different shape / fitment and doesn't have something like that designed into the internal bezel.
  3. Jan 17, 2017 at 10:30 AM
    #63
    Boogyman
    Phoenix
    Corpus Christi, TX
    Yeah the biggest obstacle I saw was mounting and making it look clean. Then it was even harder to figure out mounting by the time you painted the outside of the lens to cover your cut marks.
  4. Jan 17, 2017 at 1:07 PM
    #64
    '16TacomaTRD
    '16TacomaTRD Well-Known Member
    2016 White Tacoma TRD Sport w/ premium tech & JBL package
    PLEASE DO SO!!!! Your truck is like a role model! I would send you my headlights, taillights, and wads of money if you would do mine!!!
  5. Jan 17, 2017 at 5:20 PM
    #65
    MESO
    MESO [OP] Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    Yes...I cut open a brand new set of $300 PROS:der::der::der:
    Sneak peak
    RobP62, ScottyR, arnette64 and 7 others like this.
  6. Jan 17, 2017 at 5:29 PM
    #66
    Ducman4x4
    Ducman4x4 Yusi The Yeti
    Ducman
    SoCal
    Suuuper Duuuper White
    Stuff for Mall Crawling
    No More Teasers please !!!!!! just take my MONEY !!!!
  7. Jan 17, 2017 at 7:30 PM
    #67
    DoooDahMan
    DoooDahMan Active Member
    WS/NC
    2017 BBP DCSB Tacoma TRD OR
  8. Jan 17, 2017 at 7:42 PM
    #68
    '16TacomaTRD
    I want!
  9. Jan 17, 2017 at 10:24 PM
    #69
    MilkTeacoma
    MilkTeacoma Well-Known Member
  10. Jan 17, 2017 at 11:09 PM
    #70
    mistahB
    mistahB Well-Known Member
    SoCal
    2017 DCLB TRD OR 4X4 MGM
    This is dope. You got your own CNC? ...MBN
  11. Jan 18, 2017 at 8:49 AM
    #71
    Kennedyusmc
    Kennedyusmc Well-Known Member
    Christopher
    2017 Cement Pro
    Still waiting for it
    OK so when's the GB?
    breader3 and dead.fm13 like this.
  12. Jan 18, 2017 at 6:27 PM
    #72
    RIDERED67
    RIDERED67 Well-Known Member
    2017 TRD OFFROAD QUICKSAND, DCLB, TECH
  13. Jan 18, 2017 at 7:29 PM
    #73
    RIDERED67
    I'd buy a set
  14. Jan 18, 2017 at 9:17 PM
    #74
    MESO
    State of Jefferson
    Just a little homebrew benchtop CNC. If I need larger table space, I have access to a HAAS:)
    I'm not sure how it would be structured, since these tails are super custom and require some re-wiring of the factory connectors.
    I have been tossing around the idea on which light pattern, configuration, and color would be the best for a true "plug-and-play" LED tail(which is what most people would want).
    POLL TIME!
    What do you guys feel is most important in an LED replacement tail light?
    1)Side "raptor style" running light
    2)brake/running LED panel in place of old stock bulbs.
    3)Blacked out inner bezel/lens
    4)Turn signal relocated to reverse light(You will need to upgrade to switchback bulbs and do some re-wiring for the reverse/turn circuit)
    My thoughts on a simple, but custom looking OEM setup:
    -Raptor glow bar around the outer edge (glows red when parking lights are on, flashes orange for turn)
    -3 row LED board in brake light area (dim output for parking lights, Bright for Brake) all LED's switch to orange for turn signal
    -Reverse light & connector unaltered
    -Matte black finish inside (remove all inside chrome)
    ^doing it this way, all 3 tail light connectors would plug and play and no wiring/alterations would be needed to the vehicle.
    Let's hear watcha' want!:cheers:
    P.S: keep in mind.....this project is a hobby(I like to tinker).
    I still work a full time job(~60hrs/week) so don't expect a mass production of these to hit the shelves.
  15. Jan 19, 2017 at 4:35 AM
    #75
    Kennedyusmc
    Christopher
    2017 Cement Pro
  16. Jan 19, 2017 at 6:04 AM
    #76
    '16TacomaTRD
    I'm fine with your second option! I would rather keep my reverse lights they way they are, all I want is it painted black, 3 row leds, and for sure the "raptor style" light strip. That would be perfect! I'm BEGGING for a set
    breader3 likes this.
  17. Jan 19, 2017 at 9:19 AM
    #77
    elrob
    elrob Active Member
    2016 TRD OR DCSB w/tech
    bruhhhhhhhhhhhh
    Sometimes I like to think I'm really cool by telling my wife that I do my own maintenance, then I read this. Thank goodness she doesn't give a shit ab what can do.
    gulzeb likes this.
  18. Jan 19, 2017 at 2:10 PM
    #78
    MESO
    State of Jefferson
    Here is the sequence of how mine are wired:
    DRL: Side glow bars only
    TURN:Lower orange bulbs and side glow bars(switchback)
    PARKING lights: 3 row LED(50% dim)
    BRAKE: 3 row LED(100% bright)
    REVERSE: Lower bulb switchback to white
    Also, to show how the front Switchback bulbs are wired:
    DRL: OEM white LED bar + Amber Inner bulbs
    TURN: Amber bulb switchbacks
    HEADLIGHTS: HID projectors + 50% DIM white led bar & 50% Dim amber bulbs.
    ScottyR, TRD493, LTacoman and 4 others like this.
  19. Jan 19, 2017 at 2:17 PM
    #79
    Broccoli
    Broccoli Well-Known Member
    Airdrie Alberta
    2016 trd sport blazing blue,
    I can only get the 2nd video of the headlights to work.
  20. Jan 19, 2017 at 5:59 PM
    #80
    J0mes
    J0mes Active Member
    James
    16' TRD Off Road
    Dang... very kool thread man! I've seen a few posts about the drl with the Amber's nothing to informative or instructional. I for sure lack the knowledge on how you managed this...
    Is there a way you can explain? Did you by chance splice into the power cables of the drl?
    Anyways kool stuff man can't wait for more posts.
