3rd Gen Canadian Market Taco in the U.S. help
Discussion in 'Canada' started by takomajake, Dec 17, 2023.
  1. Dec 17, 2023 at 11:36 AM
    takomajake
    takomajake [OP] Well-Known Member
    Jake
    2021 DCLB SR5
    Really long story long bought a Canadian Market 2021 Toyota Tacoma SR5 dclb a few months ago in Wisconsin at a used dealership. It was much cheaper compared to similar Tacomas in the area. The US owners manual isn’t much help. Not sure if there is a Reset Maintenance Required or Oil Life reset. No way to scroll through the options on the instrument cluster. No apps on the entertainment head unit. The trip/odometer “stick” push and hold didn’t work either. Just did an oil change at 30k miles and wanted to know.
    Also, the instrument cluster is the MPH or bald eagles per cheese burger. The heat/ac dual climate control reads in Celsius which is not a big deal. It has a “certified to the US standards” sticker in the door frame. Was the instrument cluster switched out when it got imported here?
    It also doesn’t have a TPMS reset button under the dash but has “low tire pressure” light on the dash. It only illuminates on startup. I don’t need it just wanted to be aware of it when I take off the winter tires it came with.
    I swear I have checked other threads and searched. Looked through other Canadian market threads with tundras and Camrys. Nothing confirmed.
    other than that it’s a great truck. No complaints about it just wanted to learn. Had a 2007 aclb sr5 4 cylinder for 5 years and had 248k miles.
    Thanks for your help. Sorry if this is in the wrong thread. Just wanted the Canadian knowledge.
  2. Dec 17, 2023 at 11:42 AM
    Bishop84
    Bishop84 Well-Known Member
    Canadian tacomas dont have maintenance cluster resets. Only the higher trims with nav had maintenance reminders in the dash.
    It likely had the cluster changed, they are KM priority up here.
