3rd Gen Catalytic Converter Thefts a thing?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacoTruck808, Nov 11, 2022.
  1. Nov 15, 2022 at 8:49 AM
    ksjung714
    ksjung714 Member
    Kevin
    2018 TRD PRO MT
    Geico did not offer a discount either.
  2. Nov 15, 2022 at 8:51 AM
    ksjung714
    ksjung714 Member
    Kevin
    2018 TRD PRO MT
    The mechanic told me to just put a generic aftermarket CC on mine with no shield and the bad guys wouldn't even bother to steal it because of the low value
    cammerv8 likes this.
  3. Nov 15, 2022 at 8:55 AM
    pdxTacoSR5
    pdxTacoSR5 Well-Known Member
    PDX area
    2018 Tacoma SR5, V6 Auto, Access Cab, 4x4, Silver Sky Metallic
    i did too. wish i had seen this first.
    TexasWhiteIce likes this.
  4. Nov 15, 2022 at 9:14 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    A theif isnt going to take the time to determine if its a generic aftermarket cat when they are under cutting it off, leaving you up shits creek again.
    Get a cat shield and call it good - an ounce of prevention is worth a pound of cure. Also in places like here in lovely CA... cats have to be CARB approved, and the only aftermarket cat is the same prices as oem... so $$$$
  5. Nov 15, 2022 at 9:58 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    :mad:.
    :spending:
    Well shoot. I was procrastinating installing a shield until after I do my trans service in about 5000 miles. Instead I just bought these. They say Prerunner/ 4WD "only" :confused: , I guess I'll be the guinea pig on that one.
  6. Nov 15, 2022 at 10:36 AM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Thats a sweet cat shield. Much cheaper too than a full plate. I’d get these in a heartbeat if I didn’t already get a millercat
  7. Nov 15, 2022 at 11:31 AM
    greyson.tacos
    greyson.tacos New Member
    MGM TRD Off-Road
  8. Nov 15, 2022 at 11:51 AM
    Servingko
    Servingko Well-Known Member
    2022 DCSB OR MT
    Placed an order for the Cali Raised as well.
  9. Nov 15, 2022 at 12:05 PM
    Mister Grey
    Mister Grey The Viking of disapproval looks in your direction
    Hayward Ca
    2017 Tacoma DCLB Sport 4x4
    The Works.
    Sleep like a baby knowing my cat shield is protecting my investment.
  10. Nov 15, 2022 at 12:31 PM
    ksjung714
    ksjung714 Member
    Kevin
    2018 TRD PRO MT
    Yeaaah I figured I would still be better off getting a plate. I still should, but I was cheap and saved money at the time.
  11. Nov 15, 2022 at 12:34 PM
    Pickeledpigsfeet
    Pickeledpigsfeet Well-Known Member
    Foothills, CA
    Perfect description of the situation.
    ksjung714 likes this.
  12. Nov 15, 2022 at 1:09 PM
    MGMoverland
    MGMoverland Well-Known Member
    Brad
    Golden, CO
    22 Tacoma TRD 4x4 Offroad
    Full RCI Armor/Sliders, Bilstein 6110/5160 w/Deaver stage 3 leaf pack, Method 703 titanium wheels, BFgoodrich KM3 265/70/16, BD Sport Amber fogs, OEM LED HL, Meso 1st stage Tail conversion, Anytime front camera, EE accessory dash mount, Alu-Cab Contour canopy, Alu-cab ammo box slide, Alu-cab fridge slide, Alu-cab large cupboard, Alu-cab gen 3 tent, Goose gear deck plate, ARB twin compressor w/DDI under seat mount, Yaesu FTM 400XDR ham radio, Snomaster 72 classic fridge freezer, Battleborn 100AH lithium house battery, Front Runner 17.7 gallon onboard water.
    Recently bought the full armor for mine from RCI. Bought the cat guards as well. :thumbsup:
    SoCalAG likes this.
  13. Nov 15, 2022 at 1:41 PM
    CT-Tacoma
    CT-Tacoma Member
    CT USA
    2022 SR5 ACLB 2.7AT 4x4
  14. Nov 15, 2022 at 2:01 PM
    ksjung714
    ksjung714 Member
    Kevin
    2018 TRD PRO MT
    Yeaaah, I just moved from a not great part of Chicago, to an even less great part...
  15. Nov 15, 2022 at 2:09 PM
    #35
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    Sound logic, not to mention the down time on the vehicle and figuring out substitute transportation etc
  16. Nov 15, 2022 at 2:16 PM
    #36
    pdxTacoSR5
    PDX area
    huh? this is what i see: (do you have a 2WD?)
    CATALYTIC CONVERTER SHIELD FITS 2016 - 2022 TACOMA
    Fits: Access Cab, Double Cab Short Bed & Long Bed, PreRunner, and 4WD Models Only.
  17. Nov 15, 2022 at 2:20 PM
    #37
    TexasWhiteIce
    Texas
    Another benefit of having the shield is you’ll never accidentally drain your transmission fluid when doing an oil change….HALP!!!
  18. Nov 15, 2022 at 4:15 PM
    #38
    Mbtstaco
    Mbtstaco Well-Known Member
    2023 Tacoma Pro MGM
    Post how it is after the install I'd like to know about the rattle factor once bottled down.
    rsimi72 likes this.
  19. Nov 15, 2022 at 5:03 PM
    #39
    Rock Lobster
    Dee Eff Dub
    I drive a Miata.
    Yes I do, aka, a PreRunner to use the old fashioned term. :cookiemonster:
    The difference between drivetrains is a slightly different spacing between cross members. Hence why 4WD shields don't fit on 2WDs: the bolts will be an inch or so off when trying to fasten it to the transmission side. However, this design looks like it only goes to the transmission cross member and brace and leaves the forward member alone. That might be worth the $150 experiment to see what it will take to bolt up to my 2WD. Maybe I'll be lucky and they'll squeeze right in, maybe it'll take a little bit of mechanical persuasion.:sawzall:Either way, it'll be a way to burn a weekend in the garage.
    Will do. :thumbsup:
  20. Nov 15, 2022 at 5:23 PM
    #40
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    It will if the buyer looks at the cats. Truck can not be sold in all 50 states now as it is not emissions compliant.
    I personally would offer less if OEM cats were not included as aftermarket ones usually don't last as long, don't work as well since they are cheaper and don't include as many precious metals.
