3rd gen click pop
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Assman, Oct 15, 2024.
  1. Oct 15, 2024 at 1:48 PM
    Assman
    Assman [OP] Member
    New York City
    2020 AG MT TRD PRO
    Firestone Ride Rite w/ Daystar Cradles
    Hi, I hate to start a new thread on the infamous front end click, pop but after spending hours reading other threads and doing multiple repairs, I’ve had no luck finding a solution. Truck is a 2020 TRD Pro with 53k on it. Noise has been progressively getting more consistent for the past 5k miles. Can be heard going 10-20mph, over small, sharper bumps including some speed bumps. Easiest way to recreate on cue is to quickly turn the wheel left and right while moving at about 15mph.
    Clicking/pop is coming from passenger front wheel area.
    Attached video for sound!
    What I’ve done:
    - both front body mounts (oem)
    - 4 runner lower shock mount bolts (oem)
    - skid plate spacer washers
    - sway bar end links (oem)
    It’s about done my head in, what do I try next!?
    https://youtube.com/shorts/NOehd1g3t0k?si=itnhGE-EM5IZRuVv
  2. Oct 15, 2024 at 2:30 PM
    Clearwater Bill
    Billy
    Largo Florida
    Can you test drive with the sway totally disconnected?
  3. Oct 15, 2024 at 2:36 PM
    montanacruiser
    montanacruiser Well-Known Member
    2017 DCLB Off Road
    Mine did this and it went away after I installed new front struts. I think the spring was catching on something. Maybe try taking them out and inspect for rub marks?
  4. Oct 16, 2024 at 7:40 AM
    akimmel
    akimmel Well-Known Member
    Alex
    2019 TRD OR DCSB 6MT
    Assman[OP] likes this.
  5. Oct 16, 2024 at 8:02 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Using OEM radiator support bushings was a mistake (what's that saying about insanity often attributed to Einstein?), but I don't think it's causing your problem now.
    Torque the shit out of the LCA and UCA pivot bolts or they'll shift a little when loaded.
    Are you able to recreate the sound at a standstill (transmission in park) and just turning the steering wheel back and forth?
    Assman[QUOTED][OP] likes this.
  6. Oct 16, 2024 at 8:20 AM
    Off Topic Guy
    Off Topic Guy 2023 Trophy Points - Runner Up
    Torque LCA bolt to approximately 3.4 curse words.
  7. Oct 16, 2024 at 8:56 AM
    Assman
    Assman [OP] Member
    New York City
    2020 AG MT TRD PRO
    I inspected the fox units and didn’t see anything that was rubbing or making contact.
  8. Oct 16, 2024 at 8:56 AM
    Assman
    Assman [OP] Member
    New York City
    2020 AG MT TRD PRO
    seems like the upper and lower control arms might be the issue. I’ll crank down on them and see if that helps!
    Off Topic Guy[QUOTED] likes this.
  9. Oct 16, 2024 at 9:05 AM
    Assman
    Assman [OP] Member
    New York City
    2020 AG MT TRD PRO
    unable to recreate in neutral with the truck parked but haven’t tried for a few weeks. I’ll try again.
  10. Oct 16, 2024 at 9:05 AM
    JFriday1
    JFriday1 Well-Known Member
    Jesse
    Lakewood, CO
    19 Taco TRD-Sport, 16 4Runner
    Mobile Mechanic in Denver Instagram - "Jfriday123"
  11. Oct 16, 2024 at 9:05 AM
    JFriday1
    Jesse
    Lakewood, CO
    Camber / Caster Bolts are 134 and 139 LB.
  12. Oct 25, 2024 at 7:41 PM
    Assman
    Assman [OP] Member
    New York City
    2020 AG MT TRD PRO
    To follow up….
    I don’t want to jinx it but for the first time in many months it’s been quiet for multiple drives. I greased the hood stops and I tightened the UCA inner bolts. I wish I had done one at a time so I could report exactly what fixed it but it was one or both of those things.
    I’ll come back to this space if it rears its head again. Thank you everyone for the helpful comments!!
  13. Oct 25, 2024 at 7:42 PM
    MGMDesertTaco
    turn the volume up on the radio :notsure:
    Pibbles99 likes this.
  14. Oct 25, 2024 at 8:17 PM
    Cushmaat
    Cushmaat Well-known wiseass.
    SE AZ
    2022 TRD OR 4x4 DCLB MGM
    So I just chased this same thing. I was convinced it was the bolts on the lower end of my shocks. Changed them for the ones for the T4R. No dice. But, when I shook my truck side-to-side by my the skid plate, I could definitely feel the “click, pop” in the skid plate. No doubt. Like, NO DOUBT! Fuck it…I’ll live with it.
  15. Oct 25, 2024 at 8:19 PM
    Nyrob
    Nyrob Well-Known Member
    Robert
    2021 SX 2.7 AT 4WD
    5100 1.1 Front, 5125 Icon Stage 2 Rear, 5.29's, LCE Header
    The stock rad bushings are shit but the polys have a history of cracking the support. Change the bushing every 20k sounds like the better option unless there's something else in between
  16. May 13, 2025 at 8:52 AM
    Assman
    Assman [OP] Member
    New York City
    2020 AG MT TRD PRO
    It pains me to revive this thread but back to square one with this noise. Oddly, if the hood is opened and allowed to close hard, the noise goes away for a little and then comes back. I’ve looked multiple times at all hood parts and nothing is seemingly loose or broken. When the noise is there, it is replicable by turning the wheel back and forth while driving at 25mph and causing the the body to roll back and forth.
    Parts changed/adjusted during the hunt:
    - front body mounts (OEM)
    - tie rod end links (OEM)
    - 4 runner shock bolts (OEM)
    - skid plate checked for loose bolts
    - control arms torqued
    Any fresh ideas to check are greatly appreciated!
  17. May 13, 2025 at 9:23 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    Oh you have Fox coilovers? Those can make noise internally.
    Make sure hood hinge bolts are tight.
    Make sure the hood latch bolts are tight.
    Spray some lithium grease in the hood latch mechanism.
    Check the hood underside rib structure for disbonded adhesive.
    You've replaced the radiator support bushings? Retighten the bolts.
  18. May 19, 2025 at 12:20 PM
    Assman
    Assman [OP] Member
    New York City
    2020 AG MT TRD PRO
    Went through and tightened all hood related components… click still there. Sounds like a joint that pops inside your body. It’s like a click pop. Losing my mind on this.
    HondaGM likes this.
  19. May 19, 2025 at 12:31 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    My 23 does this...I've tightened every bolt on that truck...Mine started around 20k..got 36K now.
  20. May 20, 2025 at 5:02 AM
    Assman
    Assman [OP] Member
    New York City
    2020 AG MT TRD PRO
    On front passenger side as well?
    HondaGM[QUOTED] likes this.
