3rd gen clunks from park to reverse only on cold start.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Johnfeb94, Jan 20, 2019.
  1. Jan 20, 2019 at 3:44 PM
    Johnfeb94
    Johnfeb94 [OP] Member
    Johnathan
    2016 White Tacoma SR5 L4 4x2
    Aftermarket stereo system
    When I shift my truck from park to reverse on a cold start it clunks. Sometimes it jerks the truck a bit. It only does this from park to reverse, not park to drive. If I start it in neutral then go to park it doesn't clunk. It goes away after I drive it a bit then there is no clunk from park to reverse. Shifts fine in all gears. I've changed the tranny fluid and rear diff fluid and have taken it to the dealership and an independent shop and both have said they couldn't find anything wrong. It's been like this for the past 10k miles or so.
    Any transmission guys out there who could help me out?
  2. Jan 31, 2019 at 1:03 PM
    jeg0005
    jeg0005 Well-Known Member
    Jon
    BHM, AL
    2001 Tacoma SR5 double cab
    Full OME 883s, SPC UCAs, 33" STT Pros
    I have the same issue with my 2001 except mine does it from R to D or P to D on cold starts. I'm wondering if it's a U joint/carrier bearing or mount issue
  3. Jan 31, 2019 at 1:15 PM
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    Could be because of higher engine RPMs when cold at Idle. Or perhaps you have weight on the parking pawl and suddenly releasing the tension when shifting to R.
  4. Jan 31, 2019 at 1:18 PM
    jeg0005
    Jon
    BHM, AL
    So what issue would the higher RPMs be exposing? Surely it's not normal.
  5. Jan 31, 2019 at 1:20 PM
    here4cake
    here4cake Well-Known Member
    Pretty common.
    Back-up into the parking stall so you don't have to go into reverse when you drive out. No more cold-start clunks. Heh
  6. Jan 31, 2019 at 1:24 PM
    Tehkoema
    Tehkoema Well-Known Member
    Ottawa, ON
    2024 TRD Sport 6MT
    Pretty normal sounding. This winter I have been getting 1 second delay from shifting from park to drive from a cold start in minus 30 (Celsius) weather. The parts are cold, what do you want them to do?
  7. Jan 31, 2019 at 1:26 PM
    DansSr5
    DansSr5 Well-Known Member
    2016 Sr5 double cab silver 4x4
    P265/75/16 Destination AT stock wheels 12v socket bed pocket install diy Truck bed beer bottle opener No drill hidden/uv5r ham radio installed GoPro hero 5 session Center console organizer and top tray Front air dam delete Sidestep delete Add factory mudguards Recovery/equipment: Everything fits behind or under the seat Tool roll up bag Battery terminal cleaner Electrical grease for terminals Digital multimeter Alternator tester 4 gauge jumper cables Breaker bar with 19&21mm sockets Viair compressor Tire deflator Tire repair kit Tarp Hitch with d-ring Standard hitch 1 1/8 to 1 1/2 open ended hitch wrench Rope Ratcheting tie downs Tire gauge Cellphone charger wall/socket adaptors Gloves Recovery strap Crowbar Mighty might fishing pole Small tackle box First aid kit Michelin road atlas (4) 1 liter water bottles in rear doors 1 empty grey plastic ammo can (not sure what to put in it yet).
    I had this fixed about a year ago. I cannot remember what the TSB was. Problem was solved after work was done.
  8. Jan 31, 2019 at 1:30 PM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    Mine does this as well. I've always just assumed it's my truck telling me it's ready to roll.
  9. Jan 31, 2019 at 1:40 PM
    specter208
    California
    Reverse is engaging and is shock loading slightly. Kind of like pressing the gas and shifting to D.
    jeg0005[QUOTED] likes this.
