3rd gen clutch life expectancy
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Nw_nomad, Sep 30, 2019.
  1. Sep 30, 2019 at 12:56 PM
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    Well, I doubt you have to worry about the accumulator causing premature wear. There is plenty of anecdotal evidence that these clutches will last a long time with a completely stock truck.
    What I CAN tell you for sure is the immediate effect on driveability when it is removed/modded - the vagueness of engagement goes away. The clutch responds exactly to your left foot input!
  2. Sep 30, 2019 at 12:58 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    It definitely allows a bit more slip on engagement. Yeah, it is not going to wear out a clutch on its own but doing the ADM will add some miles to the life.
    RH408RN and MOC221_[QUOTED] like this.
  3. Sep 30, 2019 at 12:58 PM
    Freegolf
    Freegolf Well-Known Member
    Denver
    2016 offroad, manual tran
    I believe the accumulator will actually increase life of the clutch.
    MOC221_[QUOTED] likes this.
  4. Sep 30, 2019 at 12:59 PM
    csmacomber
    csmacomber Well-Known Member
    NA
    I have the part to do this... I really need to get around to making the time to do this...
    RH408RN, tonered[QUOTED] and MOC221_ like this.
  5. Sep 30, 2019 at 12:59 PM
    MOC221_
    Frank
    To each their own. I enjoy driving my M/T more with the damn thing modded.
    RH408RN likes this.
  6. Sep 30, 2019 at 1:01 PM
    MOC221_
    Frank
    You absolutely do lol.
    RH408RN, Junkhead and tonered like this.
  7. Sep 30, 2019 at 1:02 PM
    csmacomber
    NA
    Is it something I can do by myself, or will I need assistance with bleeding the line after I finish it?
  8. Sep 30, 2019 at 1:07 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    I just ordered a kit from Trident. Cant wait to remove that pos! Any tips?
    I got 17k km on my clutch.
  9. Sep 30, 2019 at 1:07 PM
    MOC221_
    Frank
    I had a helper both times (my '16 and now my '19). I don't see it being something you could easily bleed yourself without special tools.
    csmacomber[QUOTED] likes this.
  10. Sep 30, 2019 at 1:08 PM
    MOC221_
    Frank
    Yes - have you visited the ADM thread? If not do that first!
    Junkhead[QUOTED] and tonered like this.
  11. Sep 30, 2019 at 1:08 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I do not see it that way given how it functions. I am curious why you think that?
    Sort of. If you do the gravity bleed method, folks have done it by themselves. I had a helper for the bleed portion only. 10min max of help on my end.
    csmacomber[QUOTED] and MOC221_ like this.
  12. Sep 30, 2019 at 1:09 PM
    Freegolf
    Denver
    I have no doubt it's a better feeling of engagement. I should have elaborated a little more. I believe that Toyota believes/believed that the accumulator will add life to the clutch. Now it could be doing the opposite. Adding a delay to the engagement while the operator is already accounting for the "lack of engagement feeling" compounds the issue.
  13. Sep 30, 2019 at 1:10 PM
    MOC221_
    Frank
    I did the gravity bleed first, then a "proper" bleed with a helper. There was quite a bit of air in the system to get rid of.
    tonered[QUOTED] likes this.
  14. Sep 30, 2019 at 1:12 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Very true.
    I believe Toyota added this to help newbs get engagement down. While that might help with shocks through the driveline, I can only see that it allows more slip, all things being equal.
    The fact is that a newb should have 95% of the clutching down in a week or less. From there, more feel and direct action would benefit a newb.
    My wife picked it up in a dealer parking lot. Of course, she was buying a 70hp Geo at the time.
    Freegolf[QUOTED] likes this.
  15. Sep 30, 2019 at 1:13 PM
    #35
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Interesting. I know mine continued to flow slowly during the 90min that I was kludging things together. One helper pump was all that I really needed when done but did two more for insurance.
  16. Sep 30, 2019 at 1:13 PM
    #36
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Yes, ive been reading a lot about the ADM, just dont wanna fuck up getting air in the system haha.
  17. Sep 30, 2019 at 1:13 PM
    #37
    ClintS
    ClintS Well-Known Member
    San Diego
    2019 Tacoma TRD Off Road
    If those folks have to replace the brakes and rotors at 49K, that goes a long way in explaining how the truck was driven/treated, and hence the needed repair issues.
    xxTacocaTxx and tonered like this.
  18. Sep 30, 2019 at 1:13 PM
    #38
    MOC221_
    Frank
    I suppose it could help prevent clutch damage and driveline shock from errant/noob dumping. For me, it was absolutely something I had to compensate for. Forces you to sloooooooow down to be buttery smooth.
  19. Sep 30, 2019 at 1:19 PM
    #39
    Freegolf
    Denver
    I think that is the exact reason behind Toyotas design of the accumulator and in theory should add to the life of the clutch.
  20. Sep 30, 2019 at 1:24 PM
    #40
    MOC221_
    Frank
    Well, as Tonered alluded to - after everything was re-assembled I opened the bleed valve a bit on the slave cylinder and then took the clamp off the supply hose. I already had the bleed hose/bottle hooked up. I then allowed fluid to fill the system until it began dribbling out of the bleed valve. I could see air coming out while doing that.
    Next, I closed the bleed valve, topped up the reservoir, and had my helper pump the clutch a few times.. then push it in about 1/4 way and hold. I told him, when I say go - slowly push the pedal in. I opened the bleed valve when I said "go" and closed it before he got the pedal to the firewall. The last thing you want is air being sucked back in through the bleed valve. Anyway the clutch pedal may not return on it's own during this process, but not to worry - you can have your helper pull it up by hand. After each round of bleeding I had him pump the pedal a few times. After about 4-5 cycles, there was no more air coming out and we were good to go! All I did then was top up the reservoir again and re-install the heat shield.
