3rd Gen Concerns
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TT11, May 28, 2015.
  1. Aug 13, 2015 at 10:51 AM
    #321
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    Inferior in heat dissipation, but superior in longevity and weather proofing. Let's not forget too that it's not like companies are throwing massive 4 piston calipers on the back of small trucks. If anything Colorado is using the same puny rear discs as the Malibu and Equinox, which aren't much of an improvement.
    Anyways, I go back to the point that hopefully Monday will tell all. If this Tacoma stops faster than the last truck and similarly to the Colorado, who cares if Toyota saved a few bucks using drums in the rears?
  2. Aug 13, 2015 at 10:55 AM
    #322
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    I don't understand the " F1 cars have disks so my Tacoma needs disks " argument
    F1 brakes are all carbon fibre too and I doubt a Tacoma needs to decelerate from 300kmh to 80 kmh in 100m at about 5G to the driver
    Apples / Oranges
    2016_dbag likes this.
  3. Aug 13, 2015 at 10:57 AM
    #323
    JBecker
    JBecker Well-Known Member
    Virginia
    2015 AC SR 4X4 2.7 Manual
    The Colorado also stops shorter doesn't it?
    And because a disc brake is self cleaning, it doesn't need to be weather proof. All my disc equipped off road toys stop incredibly well in rain and mud compared to a drum does.
    Regarding life, I got 100k miles out of the front pads and rotors on my 07 Colorado Z71. I had to change my first set of shoes at 45k miles, and again at 90k miles with new drums and hardware. Everything I've had with discs has been less of a headache than the drums I've had, especially when servicing them.
    Honestly a floating 1 or 2 piston caliper setup with a disc that will fit under a 16" rim would be great on the back of a Tacoma.
  4. Aug 13, 2015 at 10:58 AM
    #324
    JBecker
    Virginia
    Never said anything about F1 BTW.
    because_wumbo-truck likes this.
  5. Aug 13, 2015 at 11:02 AM
    #325
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    The 2016 Colorado stops faster than a 2015 Tacoma, but the 2016 Tacoma will be lighter and the rear brakes have been redesigned. Also the ABS system has been played with, including a different vacuum booster.
    I eat rotors all the time in my Ram because of rocks from gravel. Road salt and sand getting into the brake also cause excessive wear.
    I've never got more than 40K-50K out of disc brakes up front, and usually I need new rotors in the back at the same time for reasons noted above. Then again I go offroad every day, do field work with both trucks, and don't live in a large city. That right there could be the difference.
  6. Aug 13, 2015 at 11:02 AM
    #326
    OZ-T
    Peter North
    British Columbia
    Didn't say you did
  7. Aug 13, 2015 at 11:02 AM
    #327
    scocar
    scocar hypotenoper
    Holy shit. I think I get it now.
    What if the 3rd gen forum was created to keep all the pissy butthurt e-penis douchebags out of tall the other forums?
    because_wumbo-truck and nv529 like this.
  8. Aug 13, 2015 at 11:04 AM
    #328
    JBecker
    Virginia
  9. Aug 13, 2015 at 11:06 AM
    #329
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Land Cruiser has rear discs, 4runner has rear discs, FJ Cruiser has rear discs... Just saying. :D
  10. Aug 13, 2015 at 11:08 AM
    #330
    archerm3
    archerm3 Well-Known Member
    Nebraska
    97LX (sold) 15DCSB BRM MT OR(RIP) 09 Tahoe
    Brake controller, Snugtop, Hellwig981, Gentex, custom frame bending and body removal by red light runner.
    Stopping distance is more a function of tire tread/compound than what kind of brakes it has. As long as the breaks can lock up both the front and rear axle. Which I find hard to believe any car on the road can't do.
    Regarding life, everything is relative...but on everything I've owned I get about double the life of rear brakes than the front brakes...and big suprise, i've replaced more fronts than rears...and mostly disks...
    Thats a history of 2 FJ40's, Landrover Defender, Ford Sierra, BMW M3, Pontiac GTO/Monaro, 7 different El Caminos, Datsun 200sx, Chevy Caprice, suburban, jeep cherokee, first gen tacoma... replacing disks always more expensive than drums. Turning disks or drums always been a waste ive learned.
  11. Aug 13, 2015 at 11:11 AM
    #331
    JBecker
    Virginia
    Sadly my initial guess is the Tacoma will still not stop as well as the twins do.
    Comparing to a full size is also not a good comparison regarding maintenance life of brakes. My F350 work truck eats brakes regularly, but it also stops a 15k pound trailer easy.
    Not sure how you're getting so much junk in your brakes either.
  12. Aug 13, 2015 at 11:12 AM
    #332
    JBecker
    Virginia
    It's not the tires in this case.
  13. Aug 13, 2015 at 11:18 AM
    #333
    2016_dbag
    2016_dbag Well-Known Member
    2016 POSTURD
    I'm so glad we are still arguing about disc vs drum...
    Jun 8 on TW - DRUM BRAKES OHMAHGAWD
    Aug 13 on TW - DRUM BRAKES OHMAHGAWD
  14. Aug 13, 2015 at 11:21 AM
    #334
    BlueT
    NorthEast
    :notsure:How do you manage this ? Calipers are mounted behind wheel center, so anything falling on rotor will get pushed up and away from rotors and pads.
    The only way to get gravel inside would be to have gravel that floats upward or driving only backwards.
    Also drums are not weather proof. there is 1/4 inch space around the edge for air to get in and cool the pads. Problem with that design is that things get in but will not get out, they just get grinded inside.
  15. Aug 13, 2015 at 11:22 AM
    #335
    nv529
    nv529 Well-Known Member
    Nick
    Metro Detroit, Michigan
    2006 Long Travel Taco, 2010 FJC, 2018 F250 Alumiduty
    More like..
    Jan 12th on TW - DRUM BRAKES OHMAHGAWD
    2016_dbag[QUOTED] likes this.
  16. Aug 13, 2015 at 11:25 AM
    #336
    BlueT
    NorthEast
    More like 1908 Model T redesigned horseless buggy - look we have drum brakes... with inferno red accents wow.. :rofl:
    Tideline likes this.
  17. Aug 13, 2015 at 11:42 AM
    #337
    archerm3
    Nebraska
  18. Aug 13, 2015 at 11:46 AM
    #338
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    Rocks kicked up from the front tires can end up going into the rear tire rims, from there it's just bad luck. Call any dealer in Southern Alberta who sells trucks and he'll agree that the rear rotors will get destroyed on gravel here. It's just a fact of life if you do a lot of gravel driving.
    You hear it right away when it happens, back up to kick the rock out, but still the damage is done. I don't tow much with my Ram 2500, I use it mostly for the payload for a soil sampler, and at 60 K I need new brakes again :(.
    As for the drums I've never had a problem. There was a good video on here showing how, in the Canadian climate, several reviewers from Motoring (a Canadian Auto Show) felt that the drums were superior for longevity gives the salt, sand, and other weather related grit on our roads. Maybe they were wrong. Who knows. Drums just seem to hold up for me.
    BTW the fronts should definitely be the biggest disc brakes you can fit on a truck. I'm not debating that discs aren't better than drums from strictly a brake force point of view. I had a pop can get lodged in the front rotor once years ago on my old F150, but that was probably some idiot kid and had nothing to do with driving.
  19. Aug 13, 2015 at 11:48 AM
    #339
    JBecker
    Virginia
    They are all using comparable, budget minded tires on the vehicles. If it were a small difference, I'd chalk it up to tires and conditions, but it was 22 feet. Well outside any discrepancy tires would make.
    Just realized in that test they compared the TRD Pro, so I get why that particular truck stopped worse given its lift and maybe larger tires than the Frontier Pro 4X. Not sure what size that comes with.
  20. Aug 13, 2015 at 11:52 AM
    #340
    archerm3
    Nebraska
    Disagree. Tires make all the difference in the world. A person that knows cars and specifically knows racecars would know that. :boink:
    They were using the tires that came on the truck OEM.
