3rd gen coolant leak
Discussion in 'Hawaii' started by Swagnutz, Sep 20, 2023.
  1. Sep 20, 2023 at 7:27 AM
    Swagnutz
    Swagnutz [OP] Well-Known Member
    Any Hawaii 3rd gen owners out there have coolant leak issues? It's been well documented out there in TW about the plastic rear bypass tube having leaking issues.
    Recently noticed having low coolant reservoir,, but haven't noticed any obvious leaks? Had a friend do a pressure test and also no leaks detected?
  2. Sep 20, 2023 at 8:01 AM
    toku58
    toku58 Well-Known Member
    On a Rock in the middle of the Pacific
    Mall Crawler!
    21' TRD OffRoad 2" 887 OME on Bilstein 5100's. 285/70R17 General Grabbers G3 17x8.5" Icon TRD wheels (Gun metal gray) 4.75" BS
    I'm not sure why you 're only asking Hawaii guys??
    This isn't an exclusive Hawaii thing.
    2016 to early 2018 was the years to be worried about.
    How many miles on you rig? Any sign of coolant in you Oil? Did you do a combustion gas test of you coolant?
    If the bypass is leaking you may not see any leaking because it's slow and evaporates before it can drip.
  3. Sep 20, 2023 at 9:32 AM
    Swagnutz
    Just asking locally if anyone who has dealt with it, where would be best to get a diagnosis and repair cost.btw reached ot to servco service, replied as not know issue
  4. Sep 20, 2023 at 10:39 AM
    toku58
    Mall Crawler!
    The Service writers at Servco don't know anything.
    Get an inspection mirror and take a look behind the motor at the bypass tube and all around the motor. See if you are able to see pink dried residue. If it is the bypass even if your truck is beyond the Warranty I believe that because of the TSB they need to fix it!
    https://amzn.to/46Cj4u7
  5. Sep 20, 2023 at 11:07 AM
    Swagnutz
    I'll look into it, mahaloz!
  6. Sep 20, 2023 at 11:32 AM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    Is it possible you have a head gasket leak? Mine was leaking and I never realized it until the dealership was doing warranty work on my leaking timing cover. Apparently my water pump was also leaking. Luckily for me it was all covered under warranty.
    toku58 likes this.
