3rd Gen Differential and Manual Transmission (6MT) Fluid Change
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Omar RVA, Mar 19, 2017.
  1. Oct 15, 2018 at 2:57 PM
    #321
    Omar RVA
    Omar RVA [OP] Well-Known Member
    Omar
    OR
    2020 Ram 2500 Power Wagon; 2019 Land Cruiser
    Yeah the front is a pain to deal with regardless. I'll pull the driver front wheel for access anyway so that should help.
    The hose may stay on the ridge of the lube pump, but I'm guessing I would need to invert the bag (like an IV) and I'm not sure I have enough hands to pull that maneuver off. Worst case I can always cut off more of the tip to get the flex hose into actual oil.
    OA
    tonered[QUOTED] likes this.
  2. Oct 15, 2018 at 3:18 PM
    #322
    RocTaco
    RocTaco Free stun!
    Pete
    Green Mtns
    21' SR5 Trail AG
    I'm also curious how the aftermarket fluid is doing. I did all 4 fluids at 30k, my diffs were pretty nasty but the MT oil and T-case oil looked great. Granted I didn't send any samples in. I almost bought the bag oil but the pump I bought worked well, despite not screwing onto the amsoil bottles.
    tonered[QUOTED] and Omar RVA[OP] like this.
  3. Oct 15, 2018 at 3:35 PM
    #323
    fredgoodsell
    fredgoodsell Well-Known Member
    Salt Lake, UT
    2017 DC TRD OR
    Looking forward to this round of Blackstone results
    tonered and Omar RVA[QUOTED][OP] like this.
  4. Oct 15, 2018 at 5:30 PM
    #324
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I'm thinking about a gentle squeeze?
    Yeah, the front is a PITA, but it is only a 1.6qt PITA! Hahaha!
    I did that last after pumping the transmission and rear. It was a joy compared with the quantity of those and that little pump. :D
    Omar RVA[QUOTED][OP] likes this.
  5. Oct 19, 2018 at 3:11 PM
    #325
    Omar RVA
    Omar
    OR
    So I left work early today and did my diffs and transmission fluid work afternoon! That shitty pump made life hell as per usual BUT, I discovered the Amsoil severe gear bags have the exact same thread as the lube pump, which made the front diff actually pretty easy (unfortunately there wasn't enough room to angle the nozzle of the bag into the fill port for the front). Dumping the 4ish bags into the rear diff was so much easier than using a pump. For those using Amsoil, I highly recommend using the easy pack bags when possible.
    Mod/Maintenance beer of choice today: Lagunitas Brown Shugga’
    I've got 3 samples (front and rear diff and trans) to be mailed to Blackstone tomorrow. For shits and giggles, I'll post the sample containers and let y'all figure out which fluid came from which part (spoiler tag beneath the photos). Keep in mind the containers themselves are frosted so the fluid looks much darker than it did running into the drain pan. I put a bright LED flashlight behind each to get the color to show better. The dark area near the top of each container is where light didn't penetrate (i.e. if I move the light up or down behind the tube, the areas farther from light get darker).
    OA
    1:
    1: Transmission - dark amber/syrup color in the pan
    2: Rear diff - dark again, however, much less solids on the drain mag this time
    3: Front diff - clearer than the "break-in" change; thin coating of solids drain mag
    supralee, RJS59 and tonered like this.
  6. Oct 19, 2018 at 6:03 PM
    #326
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Front diff, rear diff, tranny?
  7. Oct 19, 2018 at 6:21 PM
    #327
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    This.
    I see a hint of red on the counter in the middle pic...
    Omar RVA[OP] and tonered[QUOTED] like this.
  8. Oct 19, 2018 at 8:47 PM
    #328
    Omar RVA
    Omar
    OR
    Interesting guesses! I added a spoiler at the bottom of that post for the answer.
    OA
    TeecoTaco and tonered[QUOTED] like this.
  9. Oct 20, 2018 at 6:30 AM
    #329
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Hahaha! That spoiler button is neato. We were close!
    Thanks for the laugh.
  10. Oct 20, 2018 at 11:55 AM
    #330
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    Transmission, rear diff, transfer case.
  11. Oct 20, 2018 at 12:13 PM
    #331
    Omar RVA
    Omar
    OR
    You were close! No transfer case on this one.
    OA
    specter208[QUOTED] likes this.
  12. Oct 20, 2018 at 12:34 PM
    #332
    specter208
    California
    How's your transmission been treating you? shifting buttery smooth I hope. You have any little grinding accidents that you're expecting to see show up on the OA report.
  13. Oct 20, 2018 at 1:34 PM
    #333
    Omar RVA
    Omar
    OR
    Smooth for the most part but I’ve definitely had a few grinding incidents. The new ECU update from Toyota is already doing wonders for my clutch wear I’m sure.
    That said, since the update I’ve had a few instances when I’ve “locked” out of first; it’s been so long since that’s happened that I didn’t notice and let the clutch out only halfway between N and 1. I wouldn’t expect it to show up on the report. I was kind of concerned with the color of the rear diff fluid again but we will see.
    I also sprung for the TBN analysis this time - curious to know if after 20k the Severe Gear fluid has any life left to it.
    OA
    tonered and specter208[QUOTED] like this.
  14. Oct 20, 2018 at 5:48 PM
    #334
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    1st is triple syncro'ed, I believe. Sometimes it is rough to get them all to slide and align. The old trick was to quickly go to 2nd and then back to 1st. Our old saab was always difficult to get into 1st from a stop. Folks and I tried two different OEM fluids other than stock and ended up with Redline MTL. It still did it every once in a great while, but nothing like earlier. I'm not saying to switch to Redline, but sometimes it is just a characteristic of all those syncroes.
    kakwvu and Omar RVA[QUOTED][OP] like this.
  15. Nov 4, 2018 at 8:11 AM
    #335
    Omar RVA
    Omar
    OR
    11/29/18 UPDATE - Front Diff fluid sample made it to Blackstone Labs and results are in.
    Blackstone results are in! Kind of...
    I USPS'd the kits to Blackstone since they pre-pay the postage. I used UPS last time since I typically don't trust USPS. I'm an idiot for not listening to my gut... the kits took a week and half to arrive at Blackstone Labs and USPS lost one of my samples. Thankfully it was the front diff (least concern based on a number of factors), and thankfully Blackstone only charges AFTER running tests. So the only thing I lost was a bit of time and mess collecting the sample; but still a frustrating issue.
    On to the results! Some general comments for both oils is that they are much healthier in general after 20,000 miles than the stock situation after 10,000 miles. That's a huge deal to me considering they did twice as much work. I'm now totally comfortable putting 30,000 miles on my trans and diff fluid from here on out; and I will continue using Amsoil Severe Gear and Manual Trans respectively. Here's the abridged version for those on mobile who don't want to open the PDFs.
    Transmission:
    • 20k mile interval was no issue at all
    • Metals lower across the board and within universal average limits
    • No insolubles = minimal oxidation of the oil
    • 30k interval for next go around!
    Rear Diff:
    • Wear rates are significantly better
    • Somewhat acidic based on TAN
    • Everything is at or below universal averages except Iron, Nickel, and Potassium
    Front Diff:
    • Significantly better than factory fill (and on a 10k mile longer interval)
    • TAN is in proper range
    • Across the board, all metals and fluid properties are within expected ranges
    • 30k interval for next go around.
    OA
  16. Nov 4, 2018 at 8:27 AM
    #336
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Thanks!
  17. Nov 4, 2018 at 1:13 PM
    #337
    Jh8473
    Jh8473 Well-Known Member
    Bowling Green
    2025 Tundra SR5
    None
    Is the truck running the same
  18. Dec 5, 2018 at 6:43 AM
    #338
    bg567
    bg567 Member
    Brad
    Edmonton Alberta
    2016 Tacoma DCSB MT TRD Sport Inferno
    Bilstein 5100s @ 0.65 BHLM Pro Comp 7069 wheels
    It appears that Redline has a new product that may also work for the transfer case. Redline MT-LV 70W75W GL-4. Which appears to have a low viscosity like LF, so it shouldn't rob any fuel economy like a 75W-90 gear oil. I have contacted Redline to see if this would work for our application, & I am still waiting to hear back.
    In Canada Ravenol is unavailable on Amazon making it very difficult to get. So hopefully this is a suitable alternative.
    https://www.redlineoil.com/mt-lv-70w75w
    tonered likes this.
  19. Dec 5, 2018 at 9:52 AM
    #339
    splitbolt
    NW Arkansas
    Here are some others that make the LF compatibility claim.
    -Bravoil FMT-3 75w
    -Morris Lubricant Lodexol MTFE 75w
    -EXN-MTF 75w
    -Royal Purple Synchromesh
    tonered likes this.
  20. Dec 6, 2018 at 8:05 AM
    #340
    Alxndr13
    Alxndr13 Member
    Alex
    Minneapolis, MN
    2011 Tacoma SR5 6-n-6
    Brush-guard Nerf/step bars
    I think you mean RP SynchroMax?
    A
