3rd Gen Differential and Manual Transmission (6MT) Fluid Change
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Omar RVA, Mar 19, 2017.
  1. Dec 6, 2018 at 9:21 AM
    #341
    bg567
    bg567 Member
    Brad
    Edmonton Alberta
    2016 Tacoma DCSB MT TRD Sport Inferno
    Bilstein 5100s @ 0.65 BHLM Pro Comp 7069 wheels
    Thanks for this information!
  2. Dec 27, 2018 at 10:07 AM
    #342
    txst
    txst Well-Known Member
    Wichita, KS
    2018 Tacoma Sport Access Cab, 6MT
    TSB0058-18, TRD Pro Grill
    I am just getting ready to change the fluids in my 2018 TRD Sport 6MT. Looking at the Ravenol, it actually states Toyota 08885-81081 NOT 08885-81080 which I understand to be the LF fluid that Toyota recommends. I am not familiar with Toyota's part number system, so maybe 08885-81081 supersedes 08885-81080. Also, there appears to be a significant difference in the amount of Zinc, Phosphorus, Magnesium, Calcium and Boron based on the oil analysis of the two: https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/4389571/1
    For an extra $50 or so, I think I am just going to order the Toyota fluid online. I found a place that sells it for $56: https://www.oempartsource.com/oem-p...sRa3_xe75l98EOK8WW1glPIsMhnTUiHsaAgmsEALw_wcB
    One question - Do we need the differential fluid with the friction modifiers or not?
  3. Dec 28, 2018 at 10:23 PM
    #343
    Omar RVA
    Omar RVA [OP] Well-Known Member
    Omar
    OR
    2020 Ram 2500 Power Wagon; 2019 Land Cruiser
    Regarding your last question; we don't need any sort of extra friction modifiers (e.g. for limited slip diffs and the like). The "Auto LSD" function our trucks have is a simulated LSD via braking.
    OA
    shakerhood likes this.
  4. Dec 29, 2018 at 5:13 AM
    #344
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    There seems to be an online consensus that 08885-81081 and 08885-81081 are the same.
    It's unclear whether it's, foreign vs U.S. market or parts number update.
    How's your Russian?
    https://www.oil-club.ru/forum/topic/24314-toyota-transfer-gear-oil-lf-75w-08885-81080-i-08885-81081/
    tonered likes this.
  5. Dec 29, 2018 at 5:36 AM
    #345
    Ruggybuggy
    Ruggybuggy Well-Known Member
    NW ONT, CANADA
    2020 Tundra SX
  6. Jan 5, 2019 at 8:11 AM
    #346
    dbyker
    dbyker Well-Known Member
    Dave
    NE TN USA
    2018 Tacoma TRD Sport Access Cab V6 6MT 4x4 Inferno Red
    VF Tune, TRD Intake, TRD Cat-Back.
    So much good info in this thread, many thanks to the OP and others who have contributed.
    At 1,000 miles I changed my engine oil & filter, Blackstone Lab oil analysis came back fine. At 6,000 miles now I just changed my engine oil & filter, manual transmission, transfer case, and front & rear diff fluids. I am a lousy wrencher and had no real issues, so if I can do this anyone can. I did have access to a lift which helped a lot, but this could be done with the truck on the ground or on jack stands as long as it's level. Followed Toyota fluid & torque specs. Used Toyota fluids in engine & transfer case, Redline fluids in transmission & diffs. Used all new washers. All stock fluids were full up to bottom of fill plugs, all looked decent when draining, and front & rear diff magnetic drain plugs were coated with gunk as previously noted. Added Dimple magnetic drain plugs to engine, transmission & transfer case. Added Liqui-Moly MoS2 Anti-Friction Gear Lube to transmission and front & rear diffs (should be good for any gear case w/o filters or clutches, wasn't sure about t-case). Removing left front & spare tires would make front & rear diff access easier, but I didn't and had no issues. Gloves definitely recommended, gear oil is slippery nasty smelly stuff, and if you're like me with these cheap pumps you WILL spill some.
    Engine: Used exactly 6 quarts of Toyota OE 0W20 motor oil and a Toyota filter. The skid plate is a minor hassle to remove & re-install, the filter housing is a bit fussy but doable, oil drain & fill is straightforward. Replaced the stock drain plug with a Dimple magnetic one. Torqued all bolts to spec. Sent an oil sample to Blackstone Lab, which I expect will return fine after 5,000 miles on oil.
    Transmission: Used about 2.6 quarts of Redline MT-90 75W90 GL4 gear oil. Fluid drain & fill was straightforward, except had to use a combo wrench instead of socket on fill plug because O2 sensor wire was in the way, no biggie. Drained stock fluid, replaced stock drain bolt with Dimple magnetic one and torqued to spec. Used Redline one gallon jug and a pump, pumped in til it ran out the fill hole, added 50g (one tube) of Liqui-Moly MoS2 mid-fill, and tightened fill plug with combo wrench as I couldn't fit a torque wrench.
    Transfer Case: Used 1 Liter can of Toyota OE 75W LF fluid, $55 from dealer, though that Ravenol might work as well. Fluid drain & fill was very straightforward, nothing to be scared of here. Drained stock fluid and replaced stock drain plug with Dimple magnetic one, added a second washer as it's longer than stock and didn't want it sticking further into t-case, torqued to spec. Poured Toyota gear oil into empty Redline one-quart bottle and pumped it in til it ran out the fill hole, torqued fill plug to spec.
    Rear Diff: Used about 4.3 quarts of Redline 75W90 GL5 gear oil. Fluid drain & fill was straightforward. Could hear air escaping while removing fill plug, guess I need to check vent line(?). Drained stock fluid, blew in fill hole to blow more out drain hole, replaced stock magnetic drain plug and torqued to spec. Used Redline 1 quart bottles and a funnel to pour fluid directly into diff til it ran out the fill hole, added about 75g (1.5 tubes) of Liqui-Moly MoS2 mid-fill, tightened fill plug to spec.
    Front Diff: Used about 1.6 quarts of Redline 75W90 GL5 gear oil. Fluid drain & fill was straightforward, 10mm hex bolt access, removal & replacement was not a big issue. Drained stock fluid, replaced stock magnetic drain plug and torqued to spec. Used Redline 1 quart bottles and a pump, pumped in til it ran out the fill hole, added about 25g (0.5 tube) of Liqui-moly MoS2 mid-fill, tightened fill plug to spec.
    Feels good changing out the stock fluids following a reasonable break-in, and knowing where everything is and that it's all done right. I plan to change engine oil & filter at every 5K til 20K, then every 10K after that. I plan to change all other driveline fluids at 30K intervals. The driveline will probably last longer than me. Hoping to see a little better mileage with new fluids now, averaging 18.2 so far and will see if that goes up a bit over time. Stock shifting was always good with very occasional slight grinding if shifting too fast when cold, seems slightly better now but could just be Placebo Effect ;)
    Hope this helps a bit. Have fun with your truck :)
    Cheers, Dave
  7. Jan 8, 2019 at 6:25 PM
    #347
    Silverbandit
    Silverbandit New Member
    2017 Silver Sky DCSB V6 TRD OR 4X4 MT6
    I just changed my rear differential fluid on my 2017 OR M6 and went with the recommendation of 4.3 quarts from this thread. I know the service manual calls for 4 quarts with the M6, any issues filling to 4.3?
    mcharfauros likes this.
  8. Jan 8, 2019 at 6:35 PM
    #348
    trd09
    trd09 Well-Known Member
    Chuck
    NW Ark
    17 TRD Pro 6AT
    Overkill, but well done. Who ever buys your truck second-hand will be getting a gem.
    dbyker[QUOTED] likes this.
  9. Jan 8, 2019 at 6:49 PM
    #349
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    4.3 Quarts sounds just right as I think that is what is called for.
  10. Jan 8, 2019 at 6:54 PM
    #350
    Silverbandit
    The manual calls for 4 but OP and other members have said they filled to 4.3 quarts. Right around 4.3 mine dripped out a little and I wiped it and closed the full plug.
    Just wanting to make sure running 4.3 ok.
    shakerhood[QUOTED] likes this.
  11. Jan 31, 2019 at 2:40 PM
    #351
    dbyker
    Dave
    NE TN USA
    Add diff fluid til it runs out the fill hole then cap it up.
    I suspect the 6MT 8.8" rear diff takes 4.3 qts, the auto 8" rear diff takes 4.0 qts.
    tonered likes this.
  12. Jan 31, 2019 at 2:58 PM
    #352
    Professional Asian
    Professional Asian Ridgeline Enthusiast
    Andrew
    Eureka, California
    2017 DCSB TRD off road MT [OVtuned]
    Also, which magnetic drain plugs did you get?
  13. Jan 31, 2019 at 3:44 PM
    #353
    dbyker
    Dave
    NE TN USA
    "...Added Dimple magnetic drain plugs to engine, transmission & transfer case..."
    "...Engine: ...Replaced the stock drain plug with a Dimple magnetic one..."
    "...Transmission: ...replaced stock drain bolt with Dimple magnetic one..."
    "...Transfer Case: ...replaced stock drain plug with Dimple magnetic one..."
  14. Jan 31, 2019 at 3:47 PM
    #354
    dbyker
    Dave
    NE TN USA
  15. Jan 31, 2019 at 3:48 PM
    #355
    Rockoma5
    Rockoma5 Well-Known Member
    St Louis
    2019 TRD Sport Lifted
    Why add the Liqui-Moly Mos2 to the fluid? Is it required or help?
  16. Jan 31, 2019 at 4:27 PM
    #356
    dbyker
    Dave
    NE TN USA
    This is the stuff:
    https://www.amazon.com/Liqui-Moly-2019-Anti-Friction-Lubricant/dp/B00CPL8UPY
    It's not required but it's helpful, increases lubricity and reduces wear. Don't use it where there's clutches or filters, only essentially gears on gears (like manual trannies & open diffs). My experience is two drain & fills with quality fluid plus this makes the manual tranny notably better-shifting than new, and probably for a long time. YMMV and recommend you do your own research first if you wish. HTH.
  17. Jan 31, 2019 at 5:50 PM
    #357
    Professional Asian
    Andrew
    Eureka, California
    Very helpful! Thanks for the link to the magnetic plugs too :thumbsup:
    I plan on keeping this truck a very long time.
  18. Feb 10, 2019 at 1:22 PM
    #358
    '16goingon'17
    '16goingon'17 Well-Known Member
    Trailslayer
    NoVA by way of NWA
    2017 TRDOR 4x4 DCSB MT
    JBA STD UCAs. 6112/5160 @6/5. Wheelers 1.5" 3AAL with Superbumps. BROG molle headrest covers. GMRS & Ham radios with roof-mounted NMO Laird Phantom antenna. Thinkware front/rear dashcams, FreshMexicanTaco's DMM, Meso's dome/map LEDs & Flipfob, Swingcase on driver side. Accumulator Delete Mod (ADM). Two-wheel drive Low Range Mod (2LM). Overland Tailor Tune (OTT) 7.0. Extra juicy oil spill on the bed mat.
    Changed these fluids for the first time at 29K miles. I didn't take photos since my hands were dirty. FWIW:
    • MT oil:
      • Original oil seems flawless, didn't seem to need changing.
      • Refilled with Redline MT-90
    • Front Diff:
      • Original oil nearly black with 1/8" of wet oil/metal powder collected onto the magnet
      • Refilled with Redline 75W-85
    • Rear Diff:
      • Original oil is a translucent light gray color and had only a little wet oil/metal powder collected onto the magnet. It must have been changed by the dealer during warranty work, but no records state that it was changed. :notsure:
    Flash1034, dbyker, shakerhood and 2 others like this.
  19. Feb 10, 2019 at 3:01 PM
    #359
    dbyker
    Dave
    NE TN USA
    ^ Well Done ^
    Document your work, a good future owner will care, and your early maintenance will stand out from a sea of uncaring sellers. Cheers, Dave
    '16goingon'17 and Omar RVA[OP] like this.
  20. Mar 5, 2019 at 3:02 PM
    #360
    rubiconjp
    rubiconjp Well-Known Member
    Austin TX
    JDSmith likes this.
