3rd Gen Differential and Manual Transmission (6MT) Fluid Change
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Omar RVA, Mar 19, 2017.
  1. Jun 25, 2022 at 10:54 PM
    #601
    vecdran
    vecdran Barely-Known Member
    Jeremy
    Kirkland, WA
    2020 TRD Pro Super White 6MT
    Financial Black Hole
    O'Reilly's is running a 20% off sale right now for home shipped orders. In my excitement to save money, I incorrectly ordered MT-85 for my trans. :frusty:
    To my surprise they don't carry MT-90? Weird. Oh well, the "rainforest" had plenty.
    CygnusX191 and tonered like this.
  2. Jun 25, 2022 at 11:29 PM
    #602
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    Just wanted to input that I’ve been running Motorcraft XT-M5-QS for a few weeks in the manual and I like it. On the factory fill I would be blocked out of 1st occasionally and the truck only had 4-5.5K miles up until I swapped it. Bought 3 quarts of the motorcraft stuff and used about 2.5. I’ve used Redline on my Jeep AX15 for years but honestly I think RL is overhyped. I’m going to try the Motorcraft on my Jeep next.
    highly recommend filling up through the top of the transmission rather than pumping in fluid like a peasant. Pumping sucks, it’s uncomfortable and it feels like an eternity of pumping and usually makes a mess as you move the pump bottle to bottle, plus it never gets all the fluid out of one bottle so you end up pouring remaining fluid into the next bottle. It’s a losing situation and pains me every time I have to do it.
    It’s easy: disconnect the outer shift boot from the knob, spin off the knob, take off the console upper trim, remove the two bolts and two snaps for the inner shift boot, push down and twist CCW on the little collar holding the shifter down into the trans. Remove the fill plug, remove the drain and drain it. After draining just pour in your fluid until it comes out the fill plug hole. Let the level stabilize and stop dripping out the fill hole and put humpty dumpty back together.
    for the front and rear diffs I put in 85W-140 Currie Conventional gear oil. I like to use heavy stuff for 1) Texas heat 2) extra gear protection and 3) slight noise reduction. The fact that it is conventional and thick almost guarantees I’ll never have leaks as well. Synthetics in axles leak fairly often in my experience.
    prob will do the Toyota expensive can of stuff for my tcase as a baseline and won’t change it again for a while after that. Or I may do Ravenol. I like to get the factory fluid out soonish to remove break in material. Probably will leave the trans and diffs for 20-30K now.
    CygnusX191 likes this.
  3. Jun 26, 2022 at 10:55 AM
    #603
    dr4g1116
    dr4g1116 Well-Known Member
    2019 Silver Sky Metallic TRD OR SB M/T
    ...You're kidding right? Took me maybe 5 minutes of pumping, total.
    Junkhead and CygnusX191 like this.
  4. Jun 26, 2022 at 10:59 AM
    #604
    BLtheP
    Plano, TX
    I have never been able to fill 2+ quarts of anything in less than about 20-30 minutes…..I was not really kidding (the peasant part sure)….you leave like 1/4 of the bottle down in the bottom, then need to pour it into the next one, sometimes the pickup tube falls off the pump and then you can get less than half a bottle out until you fish the tube back out, etc. It’s just a hassle every time I do it the pump method. You must have a really good pump to be able to go that fast.
    On the other hand I can have the top of the transmission open and collided back up in about the same 5 minutes, and I can pour the fluid right in. My process is to get the transmission draining while I disassemble the top so that it’s ready to fill by the time I’m ready to pour.
  5. Jun 26, 2022 at 11:04 AM
    #605
    BLtheP
    Plano, TX
    To clarify, I haven’t pumped a transmission in years. I always do it through the top. My disdain lives on by working with axles though, and I usually use a heavier fluid which is slower and harder to pump. So maybe the transmission would be a better experience, but even when I used to pump into my transmissions, I always disliked it then too. I just see no reason to go that route when I can be comfortable and pour it in from up top.
  6. Jun 26, 2022 at 11:07 AM
    #606
    dr4g1116
    https://www.amazon.com/Slippery-Pet...&qid=1656266557&sprefix=dif+flu,aps,88&sr=8-6
    Works great - I got the pump for the gallon bottles since I had a mix of gallons and quarts, and the Red Line necks are smaller than a standard quart anyway.
  7. Jun 27, 2022 at 6:35 AM
    #607
    c_walters
    c_walters Well-Known Member
    Mooresville, Nc
    2019 TRD Sport 6MT MGM
    Planning on finally doing Lucas 85-140 in front and rear diffs, how much do I need to pick up?
  8. Jun 27, 2022 at 6:47 AM
    #608
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    See the 1st Post. Quantities, crush washers, and torques are all there.
  9. Jun 27, 2022 at 7:12 AM
    #609
    BLtheP
    Plano, TX
    As said above, quantities are in the main post. For my locker MT rear I needed about 4 quarts (probably a 5th one since you can’t get it all with a pump). Up front I needed two quarts. I think buying 6 quarts and the leftover from the second one up front is enough to get the rear done. The rear takes a while, being a third member it needs a lot of fluid.
    CygnusX191 and c_walters[QUOTED] like this.
  10. Jun 29, 2022 at 2:30 PM
    #610
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Transmission pump took 4 min flat for me. Much easier and quicker than taking half the interior out just to get the trim around the shift boot off. :D
  11. Jun 29, 2022 at 2:55 PM
    #611
    BLtheP
    Plano, TX
    Half the interior?? Lol it’s one panel, a knob and the boot….it’s literally like 2 minutes.
    CygnusX191[QUOTED] likes this.
  12. Jun 29, 2022 at 3:14 PM
    #612
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Yours must be magical. The trim around the boot requires half the front to come off and the center console on mine.... That's one biiig piece of plastic
  13. Jun 29, 2022 at 3:14 PM
    #613
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    What's this transmission pump drain business?
    Forgive me if I come in mid convo
    shakerhood and CygnusX191 like this.
  14. Jun 29, 2022 at 4:22 PM
    #614
    BLtheP
    Plano, TX
    There’s one long piece of plastic that holds the outer boot, cupholders etc. it comes up in one pull. Undo the knob before you pull up on that and it comes right off. After that it’s just the inner boot (2 bolts 2 clips) and then undo the shifter stick from the trans. It’s very easy. I don’t think 2018 is different from 2021.
  15. Jun 29, 2022 at 4:25 PM
    #615
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    I prefer the pump, as painful as it may be, to trim removal. Definitely don’t want gear oil anywhere near the interior either.
    points for creativity though.
    for me, just turn up the Aerosmith and flex the guns till it’s done.
    gonna try the squeeze packs next time. Just to see how they are.
  16. Jun 29, 2022 at 4:43 PM
    #616
    TeecoTaco
    SW Ontario
    Wait...there are people that don't do this from under?
    shakerhood, Junkhead and CygnusX191 like this.
  17. Jun 29, 2022 at 4:49 PM
    #617
    BLtheP
    Plano, TX
    Yes.
    CygnusX191 and TeecoTaco[QUOTED] like this.
  18. Jun 29, 2022 at 5:17 PM
    #618
    TeecoTaco
    SW Ontario
    Interesting
  19. Jun 29, 2022 at 5:19 PM
    #619
    BLtheP
    Plano, TX
    Clearly not a popular decision, but I’ve always found it easier/more relaxed for myself so I do it that way.
  20. Jun 29, 2022 at 5:21 PM
    #620
    TeecoTaco
    SW Ontario
    Hey man, whatever works tho...:thumbsup:
    Clearly unorthodox to be certain
