3rd Gen Differential and Manual Transmission (6MT) Fluid Change
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Omar RVA, Mar 19, 2017.
  1. Sep 13, 2022 at 9:32 AM
    #661
    Pengowirr
    Pengowirr Well-Known Member
    2018 TRD Off Road Manual Transmission Cement
    265/75/r16 Cooper ST MAXX
    I called the dealership for a quote and they told me $332.49
    The rep said this is because they have to let the transmission sit and cool for multiple hours and they have to do checks for the temperature. i explained my truck was a six speed manual and they said they still had to do that and do “checks” and that I needed “special” tools for the job. They warned me I could cause severe damage if these checks weren’t done.
    Safe to say they’re just trying to rip me off but what I am curious about is the temp of the transmission. Am I going to be ok with just changing the fluid like I’m changing the regular engine oil?
    it seems to be that’s all people do with the manual transmission fluid change.
    CygnusX191 and tonered like this.
  2. Sep 13, 2022 at 9:38 AM
    #662
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    LoL! The price isn't bad, if that includes the diffs also. If that is just the MT, keep a firm hand on your trousers and run!
    But, they are absolutely clueless about the fluid swap.
  3. Sep 13, 2022 at 9:46 AM
    #663
    22Coma6MT
    22Coma6MT Well-Known Member
    2022 TRD Sport AC 6MT
    Is the $332 for all the gear boxes or just the transmission? If all the gear boxes, that's not terrible in my experience.
    There is no requirement I know of to wait to drain the transmission, I never have.
    CygnusX191 likes this.
  4. Sep 13, 2022 at 9:50 AM
    #664
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    It is better to warm up the fluid before changing it. Warmer fluid will flow better and drain faster, and if freshly driven, contaminates won't be settled in the bottom but mixed into the fluid and drained with it. Other than that, there is no 'special' way to change the fluid. The dealer just wants to change your money into thier money. That requires the 'special' tools.
    doublethebass and CygnusX191 like this.
  5. Sep 13, 2022 at 10:28 AM
    #665
    Pengowirr
    yeah it that rep seemed to think the manual and AT fluid change is the same.
    i just asked for the Transmission fluid and emphasized that it was a straight drive. They still quoted me that much.
    that makes sense, change it when it’s warm and not cold and settled.
    Yeah I’ve looked up videos on how to change the fluid for the 6MT and I knew the rep was trying to rip me off.
    tonered[QUOTED] and CygnusX191 like this.
  6. Sep 13, 2022 at 10:32 AM
    #666
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    That's the service writer trying to sell you everything. Find a better dealer.
    Yep the manual transmission is literally as we've said in here. Crack the fill plug, and pop the drain plug, when you're done replace washers replace drain plug, fill and then replace fill plug. There is no special tool. Same with the diffs.
    That being said there is a certain way to do the automatics... So maybe the clueless service writer was thinking of that. Either way, this is a manual transmission you can do it yourself if so inclined for much much cheaper than some ripoff dealer is trying to do you for. The fact that they don't know the difference tells me they might be selling you an automatic service and some clown may be pumping the wrong fluid into your transmission.
  7. Sep 13, 2022 at 10:36 AM
    #667
    Pengowirr
    Yeah I’m just gonna stay away from this dealer. That’s what I was thinking too. They were confusing the AT with the MT service and that just makes me believe they’re complete idiots will probably screw up something.
    i just wanted to check here to make sure I wasn’t crazy for thinking this rep was out of her mind.
  8. Sep 13, 2022 at 10:37 AM
    #668
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    You can do the MT and diffs at home for about $100 less than that quote.
  9. Sep 13, 2022 at 10:38 AM
    #669
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    What part of the country are you in? Maybe someone in here could point you to a better dealer in case you need anything else done
    33yrsoftoys and tonered like this.
  10. Sep 13, 2022 at 11:06 AM
    #670
    MegaHurts777
    MegaHurts777 Well-Known Member
    Jacob
    ID
    2019 Tacoma TRD Off-Road (MT)
    Dang, I guess this is what happens when the reps aren't the actual techs working on the vehicles.
    While yes, its better in my opinion to change the oil when it's warm-ish, (drains better etc) it's not a requirement like with the Auto.
    The Auto requires a special change procedure where the manual does not.
    I've run into mixed results when dealing with reps where some are not mechanically inclined, and asking technical questions generally doesn't yield much value.
    In slightly other news, I changed my T-Case and Trans oil at 28,000 miles (rounding up) and it was rather dark all things considered.
    Definitely worth changing and not waiting till 60,000 miles.
    The first change interval for the T-Case and Trans I'm told should be 30,000 miles even though the dealer won't technically agree with that.
    Like with the diffs, the first change generally is a bit more glittery/dirty as the gears wear in.
    Once you get past the initial change I'm told you can go the normal interval.
    Normal intervals>>
    T-Case = Every 30,000 miles
    Trans = Every 60,000 miles or 6 years
    Pengowirr[QUOTED] and CygnusX191 like this.
  11. Sep 13, 2022 at 11:43 AM
    #671
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    I was quoted something around 300 for transmission fluid from the dealer. Not sure if maybe they were reading the AT price sheet though. It may well be the MT price.
    shakerhood likes this.
  12. Sep 13, 2022 at 11:53 AM
    #672
    roboturner
    roboturner Dead Eyed
    Colorado
    00 IJM AT XC 4x4 3.4L TRD | 18 CB MT DCSB 4x4 V6 Pro | 98 NW MT 4x4 3.4L SR5 4Runner
    I second that, I waited till 45k, and wish i had done it much sooner, the 'cleanest' fluid of the bunch was the T-Case at a syrupy brown. Diffs and Tranny were all jet black - yikes.
    also as others have said, all this is easy DIY, the Tranny is just like diffs with the MT - 'special tools' required: torque-wrench, and a way to pump oil. lol
  13. Sep 13, 2022 at 12:29 PM
    #673
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Viscosity is more important than color, esp with the first change. If they were flowing well, no worries.
    That is roughly the AT price sheet for a fluid exchange and condition/cleaning service.
    Jet black is fine. That's just break in coating from gears. As long as the fluid was flowing well (warm) it's perfectly normal for the first change to be super dark.
    daveeasa[QUOTED] likes this.
  14. Sep 13, 2022 at 6:57 PM
    #674
    Pengowirr
    Btw, I’m in NC in Burke County. The dealership I use is Mike Johnson of Hickory Toyota. Just so everyone around here knows.
    Id say they’ve gone down hill. Granted all I ever got from them was oil changes that came with the warranty but now they won’t stop trying to push services and this last visit completely soured me on them.
    CygnusX191[QUOTED] likes this.
  15. Sep 13, 2022 at 7:35 PM
    #675
    daveeasa
    David
    PNW
    Thanks for pointing this out. The guy was a bit young but I was f’ing clear on MT because of the TSB. And I paid full price on said TSB since 2016 is out of warranty. But she shifts smooth now and I have added confidence that I can not f up a darn MT fluid swap. I mean, I would have to be a friggin idiotic to fail at that, right? Easier than oil.
  16. Sep 13, 2022 at 7:38 PM
    #676
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    You maybe, but my track record lately would be raising some red flags. Hahaha!
  17. Sep 13, 2022 at 7:38 PM
    #677
    roboturner
    Colorado
    I wanted to point out that it’s easier than changing your oil - and less “specialty tools” too lol
  18. Sep 13, 2022 at 7:41 PM
    #678
    daveeasa
    David
    PNW
    I was only scared because of the trouble I encountered shifting out of 5th and 6th at the hot end of a 1000 mile drive. Some helpful TW guys pointed me to a TSB that the dealer confirmed. I may go redline next time but for now I can safely say that it seems my amsoil MT fluid is working properly.
    I was definitely willing to pay $300 to not have problems shifting at 45 MPH on a steep grade.
  19. Sep 13, 2022 at 7:45 PM
    #679
    roboturner
    Colorado
    That’s why I keep it in 2nd in the fast lane when going to the mountains- never have to see 45! Bonus points if you can match the speed of a semi in the slow lane for 40 miles
    :tinfoilhat:
    CygnusX191 and daveeasa[QUOTED] like this.
  20. Sep 14, 2022 at 5:39 AM
    #680
    Homiec
    Homiec Well-Known Member
    2020 TRD Sport Access Cab 4X4 MT
    Stealerships don't know squat about MTs. One post on here describes techs unable to start the Taco to get it in the garage. They tried jumping it, etc. They were too stupid to notice it's a manual and to press the clutch pedal......
    My local parts guy insisted Toyota's straight 75W MT oil (which is used on some Toyotas) was the correct oil despite me showing him what's in the manual.
    So yeah, do it yourself.
    shakerhood, CygnusX191 and tonered like this.
