3rd Gen Differential and Manual Transmission (6MT) Fluid Change
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Omar RVA, Mar 19, 2017.
  1. Oct 19, 2022 at 11:14 AM
    #701
    JDSmith
    JDSmith The Overland Shop, VT
    Jesse
    Essex Jct, Vermont
    21 Pro MGM MT
    Always changing
    Found one like that now, I’m gonna keep her! She buys parts for the truck :D
  2. Oct 19, 2022 at 11:16 AM
    #702
    Horseshoez
    Horseshoez Well-Known Member
    Dale
    Maryland
    I must be doing something wrong, my wife and I will be celebrating our 29th anniversary in a few months, first marriage for both of us. That said, we were 35 when we met and had both "played the field" for, well, a long time, so I guess we kind of already knew what we wanted. :)
  3. Oct 19, 2022 at 11:26 AM
    #703
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    That is great.
    Mine doesn't partake in the mod fun, unfortunately.
    CygnusX191 and JDSmith[QUOTED] like this.
  4. Oct 19, 2022 at 11:28 AM
    #704
    JDSmith
    Jesse
    Essex Jct, Vermont
    21 Pro MGM MT
    Always changing
    I’m looking at ordering those Dimple drain plugs also, what factory drain plugs are already magnetic? I believe I read the trans is not?
    CygnusX191 likes this.
  5. Oct 19, 2022 at 3:28 PM
    #705
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    You read incorrectly.
    That being said, the factory magnets are abhorantly weak. So soon as they have even a little bit of grime on them, they're pretty much useless
    JDSmith[QUOTED] likes this.
  6. Oct 29, 2022 at 3:11 PM
    #706
    moon_taco_420
    moon_taco_420 Well-Known Member
    Josh
    2022 TRD Sport Access Cab, 6SPD MT, Lunar Rock
    Damn! This just popped up for me. Definitely thinking about doing those on my next oil change. 22 Sport MT with 8300.
  7. Oct 29, 2022 at 4:41 PM
    #707
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Good time for the diffs and MT, IMHO.
    CygnusX191 and Junkhead like this.
  8. Oct 29, 2022 at 8:20 PM
    #708
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    FWIW, I did mine at about 35k miles and the rear diff fluid looked like new but the front was black with a bunch of sparkles in the fluid.
    Used red line so I’m good for a while.:)
  9. Oct 29, 2022 at 8:50 PM
    #709
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Mine dropped into a black pan, so it was hard to evaluate, but they both looked dark for such a short run. Getting close to doing them again.
  10. Oct 29, 2022 at 9:01 PM
    #710
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Its been on my to do list for quite some time.
    tonered[QUOTED] and CygnusX191 like this.
  11. Oct 29, 2022 at 9:44 PM
    #711
    maxmk8
    maxmk8 Well-Known Member
    2022 Electric Lime M/T Taco
    Has anyone noticed improved shifter feel with a non oem fluid ?
  12. Oct 29, 2022 at 9:46 PM
    #712
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
  13. Oct 29, 2022 at 9:51 PM
    #713
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Black fluid on your first change isn't a problem, especially if the fluid isn't thick and doesn't smell burnt.
    Now the sparkles..... Keep an eye on that. Normal wear, but ideally it never gets worse than a few sparkles.
    duece5811 likes this.
  14. Oct 29, 2022 at 10:16 PM
    #714
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    At about 30K I swapped the factory fill for Motorcraft XT-M5-QS, it made a noticeable improvement in shifting smoothness. (Meets Toyota specs.)
    https://www.motorcraft.com/us/en_us...ull-synthetic-manual-transmission-fluids.html
    Rock Auto had the best price.
    https://www.rockauto.com/en/parts/motorcraft,XTM5QS,transmission+fluid,13630
    I'm a pretty slow driver (and shifter too), frequently second especially would not quite grind but you could feel in the stick the syncromesh being not quite fast enough, the fluid change eliminated the problem on the first trip around the block.
    Overall the transmission instantly felt smoother, slicker. I'm at 45K now and it shifts very nicely. Lots of fun to drive.
  15. Oct 29, 2022 at 11:15 PM
    #715
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    It is a pretty easy task, just a bit pricey for all that diff lube.
  16. Oct 30, 2022 at 5:48 AM
    #716
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    Absolutely. I switched to redline MT90 from OEM and the trans feels much smoother. I use to often hear synchro noise (possible grinding) when up/downshifting to 2nd gear. I’ve never again experienced this with MT90.
  17. Nov 1, 2022 at 10:49 AM
    #717
    JDSmith
    Jesse
    Essex Jct, Vermont
    21 Pro MGM MT
    Always changing
    Oil changes are done, trans and tcase ended up not having magnetic plugs in them. Not too hard to swap out without loosing minimal fluid though. I will say it feels way better with the MT90 in the trans.
  18. Nov 1, 2022 at 10:58 AM
    #718
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    MT90 is magic
  19. Nov 3, 2022 at 9:49 AM
    #719
    Colemac4
    Colemac4 Well-Known Member
    2021 TRD OR 6MT
    2021, 2017, 2016, 2014, 1997
    As someone who has owned 4 third gens (all TRD ORs). I've always flushed differentials at 20k. What I recently found interesting is when I flushed the rear diff on my '21 at 20k - that fluid was still in relatively good shape, still transparent, and missing the normal smell of wrecked gear oil. Sure there was a little metal on the drain bolt magnet but that is to be expected. My prior 3 third gens when flushed at 20k drained fluid that looked closer to used diesel oil. The '21 has not been used any less or more or in any different manner than the prior trucks. Just interesting to see such a substantial difference...
    duece5811 and CygnusX191 like this.
  20. Nov 3, 2022 at 10:06 AM
    #720
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Was the fluid dark and runny or dark and thick?
