3rd Gen Differential and Manual Transmission (6MT) Fluid Change
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Omar RVA, Mar 19, 2017.
  1. Jun 19, 2023 at 5:39 PM
    #781
    happyvirus
    happyvirus Well-Known Member
    Knowing what you found out at 7k change, would you do the first change earlier?
    CygnusX191 likes this.
  2. Jun 19, 2023 at 7:12 PM
    #782
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Maybe your left foot is made out of lead :D
  3. Jun 19, 2023 at 7:47 PM
    #783
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    It's what my right hand feels.
  4. Jun 19, 2023 at 7:49 PM
    #784
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    For me, it was needed as the factory stuff was blocking me out of 1st and @Omar RVA got an unfavorable UOA on it.
    Redline snicked into gears better and let me get into 1st at stops. I've had similar experience with Redline on other cars when others were of no help.
    Just my experience though.
  5. Jun 19, 2023 at 8:08 PM
    #785
    33yrsoftoys
    33yrsoftoys Over 40yrs now
    joel
    mid Michigan
    2021 dcsb off road 6 speed manual
    Bilstein 6112's 5th clip 1/4" spacer driver's side. Icon tubular UCA's with Delta joint, wheelers superbumps, ECGS bushing. Allpro standard leaf packs, 5160's, U bolt flip kit with wheelers super bump's, extended stainless steel brake lines, carrier bearing drop. Icon rebounds 17" with Nitto terra grappler G2's 285/70/17's.
    Every MT I've used Redline in shifted better. It really helped my gen 2 MT. It was a really notchy shifting trans though. My 3rd gen MT shifts really smooth in comparison but it'll get Redline anyway.
    Sandthemall and CygnusX191 like this.
  6. Jun 19, 2023 at 8:14 PM
    #786
    Benny blanco
    Benny blanco Mr. Jiggletits
    Ben Day Ho
    Whoville<>Trollhättan
    21 Cement TRD OR MT
    Some stuff
    When I changed my fluids and used the redline I was amazed at the difference. Not just the ease of first, but the hard downshifts going up a grade became smooth. Butttery. Velvety.
  7. Jun 19, 2023 at 8:15 PM
    #787
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Y'all are making me want to get redline again...
  8. Jun 19, 2023 at 8:17 PM
    #788
    Benny blanco
    Ben Day Ho
    21 Cement TRD OR MT
    Some stuff
    I had to use the empty valvoline squeezable oil packs leftover from the diffs, and refill them with the redline. My anti gravity fluid exchange apparatus failed miserably. Tools that look like they are going to fail, fail.
  9. Jun 19, 2023 at 8:18 PM
    #789
    33yrsoftoys
    joel
    mid Michigan
    It's good stuff. There may be better out there but I haven't found it yet.
    CygnusX191[QUOTED] likes this.
  10. Jun 19, 2023 at 8:19 PM
    #790
    33yrsoftoys
    joel
    mid Michigan
    Ain't that the truth. Those plastic POS's anyways.
  11. Jun 19, 2023 at 8:39 PM
    #791
    Benny blanco
    Ben Day Ho
    21 Cement TRD OR MT
    Some stuff
    It was a siphon with a bulb, that never held a vacuum. After an hour of pissing myself off I got smart.
  12. Jun 19, 2023 at 8:39 PM
    #792
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    I still firmly stand by my opinion that manual trans fluid is much easier changed via the shifter cane removed and pouring it in with a funnel. Yeah, little bit of a risk bringing gear oil into the cab but if you’re careful, it’s no big deal. It’s probably not faster but much more relaxed.
  13. Jun 19, 2023 at 8:41 PM
    #793
    Benny blanco
    Ben Day Ho
    21 Cement TRD OR MT
    Some stuff
    What?! Is this really a thing? Or are you yanking my crank?
    CygnusX191 and cookiedough like this.
  14. Jun 19, 2023 at 8:44 PM
    #794
    BLtheP
    Plano, TX
    It’s the only way I change trans fluid lol. The only reason more people don’t do it this way is because of the risk of spilling fluid on the carpet. Personally I despise cheap transfer pumps that take infinite seeming quantities of pumps, so I skip that method, but I am careful with handling fluid in the cab.
    Remove knob & console panel, remove the two clips and screws for the main shift boot, remove main boot, lift up the circular small shift boot, use gloves to press down the locking collar and twist counter clockwise, Pull out shifter, remove drain plug and drain, install drain plug, fill through shifter hole with a funnel until fluid comes out the fill hole, install fill plug, install shifter, install console and knob.
    Done
  15. Jun 19, 2023 at 8:49 PM
    #795
    Benny blanco
    Ben Day Ho
    21 Cement TRD OR MT
    Some stuff
    You don’t spill a little on overfilling?
  16. Jun 19, 2023 at 8:51 PM
    #796
    BLtheP
    Plano, TX
    It spills out of the fill hole when done. You can definitely overfill out of the shifter by overloading the funnel if you pour too quick there but I monitor that and stop as needed.
  17. Jun 19, 2023 at 8:54 PM
    #797
    Benny blanco
    Ben Day Ho
    21 Cement TRD OR MT
    Some stuff
    That stuff stinks so bad.
  18. Jun 19, 2023 at 9:00 PM
    #798
    cookiedough
    cookiedough Well-Known Member
    Phx, Arizona
    02 DCSB OR, 19 DCSB OR
    '02 - No mods. '19 Blue Friday - GFC, RXT S1, Bilsteins
    1st at a stop is occasionally my issue with Toyota factory fill as well. I did the Amsoil purchase, so no MT90 for me, coming up on the 30k for the change.
    Even with removing all the interior stuff, I can't believe it's easier than the squeeze packs? I went out to my truck just to check - that is really easier? :mind_blown:
    CygnusX191 and Benny blanco like this.
  19. Jun 19, 2023 at 9:12 PM
    #799
    Benny blanco
    Ben Day Ho
    21 Cement TRD OR MT
    Some stuff
    I have to remove skids and the cat protector and I’ve had the console apart a bunch of times. But nah, I’d rather use the fill hole. I bet if you don’t loosen and tighten that thing once in a while it won’t loosen again.
    cookiedough[QUOTED] likes this.
  20. Jun 19, 2023 at 9:13 PM
    #800
    BLtheP
    Plano, TX
    No fluids I buy come in squeeze packs, so those aren’t a quicker option for me. I don’t really know about ‘easier’, since again I don’t use squeeze packs. I was comparing easier to using a crappy pump screwed to the top of the bottle or worse, a 2-hose pump where one goes in the bottle and one goes in the trans. I always make a huge slippery mess when I use those.
    As for disassembly, I can have the shifter out in about 2 minutes.
    as for the being blocked out of 1st at a stop, that is not a Toyota fluid problem. That has happened to me on every different fluid I’ve tried.
