3rd Gen Differential and Manual Transmission (6MT) Fluid Change
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Omar RVA, Mar 19, 2017.
  1. Nov 6, 2023 at 4:54 AM
    #841
    33yrsoftoys
    33yrsoftoys Over 40yrs now
    joel
    mid Michigan
    2021 dcsb off road 6 speed manual
    Bilstein 6112's 5th clip 1/4" spacer driver's side. Icon tubular UCA's with Delta joint, wheelers superbumps, ECGS bushing. Allpro standard leaf packs, 5160's, U bolt flip kit with wheelers super bump's, extended stainless steel brake lines, carrier bearing drop. Icon rebounds 17" with Nitto terra grappler G2's 285/70/17's.
    I just got done changing my fluids last week. I forget how much I hate those hand pumps until I have to use them again.:annoyed:. I went with redline mt85 for my trans this time. I had been kicking around about trying the mt85 instead of the mt90 for awhile. Very smooth and well defined shifts. Winters coming on and I heard it shifts a little smoother cold. We'll see.
    CygnusX191[QUOTED] likes this.
  2. Nov 6, 2023 at 6:06 AM
    #842
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Looking forward to hearing your longer term results
    I'm about 10k out from doing my transmission again
    MQQSE and 33yrsoftoys[QUOTED] like this.
  3. May 27, 2024 at 1:59 PM
    #843
    bulldog
    bulldog Well-Known Member
    SW MO
    2023 Pro
    Umm…it’s a Pro Retired 4/29/2023 Dobinsons MRR Dobinsons UCA Dobinsons C59-314 Front Springs Dobinsons I59-110 Rear Springs 4.88 Yukon Gears CMC MobTown Sliders Line-Xed RCI Aluminum Skid BAMF Recessed Grille WARFAB Rear tube bumper SSO Full Plate Hybrid (sitting in the garage still) TTD Carbon Fiber Steering Wheel Clazzio Dark Gray Seat Covers 35% Tint Vinyl Tailgate Letters Undercover Elite Tonneau Apex Stealth Cali LED 31.5" w/upgrade OPT 7 harness and MicTuning Switch V5 Gemtech Homelink 265/75 16 Mickey Thompson Baja Boss A/T Volk Gloss Black 16” 17' Pro Rigid Fog Lights 17' Pro Tail Lights Complete sound proofing
    For the love of Pete, I change both the front and rear in mine today. It's a 23 Pro, but I thought I'd upgrade the front to Lexus bolts before they were seized up. Holy moly, the front drain was so tight it took me forever to get it out. I only have 4100 miles on it and it's superclean underneath, but the factory torqued that mother on there. Glad I did it!
  4. Jul 13, 2025 at 2:04 PM
    #844
    Welder94
    Welder94 Member
    111,000 miles on my ‘22 third gen manual and never done the tranny fluid or diffs. Still runs and operates like the day I got it. What’s y’all’s thoughts?
  5. Jul 13, 2025 at 2:07 PM
    #845
    SandyTaco4x4
    SandyTaco4x4 Well-Known Member
    Southern CA
    17 DCSB/AT QS TRD Sport 4x4
    It will run like the day you got it until the day it doesn't anymore and then you might wish you had changed fluid a little more regularly :D
    mistareeman, akimmel, OZ TRD and 3 others like this.
  6. Jul 13, 2025 at 2:14 PM
    #846
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    Original clutch?
    CygnusX191 likes this.
  7. Jul 13, 2025 at 2:27 PM
    #847
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Bragging about lack of maintenance isn't a flex.
    Good thing is, manual transmission, t case, and diffs take like 5 min each to swap fluids.
    At 111,000 you're probably still good, but changing fluids is a LOT cheaper than changing out diff components
  8. Jul 13, 2025 at 3:26 PM
    #848
    InThePlains
    InThePlains Well-Known Member
    Many in 3rd world countries never got changed, they won't baby them either. They are fine.
  9. Jul 13, 2025 at 4:47 PM
    #849
    10ptXtreme
    10ptXtreme Well-Known Member
    NJ
    2020 DCSB TRD Sport Voodoo Blue
    Just curious... How long does it take to change the front and rear differential oils, and the manual transmission oil? Thanks!
    David
  10. Jul 13, 2025 at 4:54 PM
    #850
    Welder94
    Welder94 Member
    yup
  11. Jul 13, 2025 at 4:55 PM
    #851
    Welder94
    Welder94 Member
    not flexing just curious
  12. Jul 13, 2025 at 4:58 PM
    #852
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    I would think it would be advantageous to change your fluids. Never know at what point the additives and lubricity of each oil starts to break down and things start to get unhappy. Probably still fine but it’s not that expensive or difficult to change, so why push it? I doubt any damage has been done, but I bet you’ll get better life out of your stuff than you would have if you change it now vs never.
    CygnusX191 and Pablo8 like this.
  13. Jul 13, 2025 at 5:01 PM
    #853
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    A few hours MAX. Most time for me getting under the truck, letting old juice drain well. Pumping or squeeze bagging in, minutes.
  14. Jul 13, 2025 at 5:04 PM
    #854
    10ptXtreme
    NJ
    Would you suggest going with the bag route or the bottles and pump?
    David
  15. Jul 13, 2025 at 5:37 PM
    #855
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    Whatever you prefer same same for me. The pump ya always gots to deal with the pump after the job
  16. Jul 13, 2025 at 5:48 PM
    #856
    Wyo_37
    Wyo_37 New Member
    2020 tacoma trd or 6mt
    I have a 2020 trd o.r. 6spd mt with 9800 miles. Should I change transmission fluid and diff fluid? Always thought that would be a 30k mile service at the earliest.
  17. Jul 13, 2025 at 6:11 PM
    #857
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    Change now and go a looooong time
  18. Jul 14, 2025 at 9:26 AM
    #858
    OZ TRD
    OZ TRD Well-Known Member
    Central Coast CA
    6sp Manual TRD PRO - Lunar Rock '21
    Evo A SmartCap, Cali Raised Sliders (0 degree), 2WD low Mod, Puddle Pods, 3 switch overhead panel, 8 slot middle console panel, Custom driver's switch panel, Rek Gens, 265 75 16 Falkens, lil B Bed Stiffeners, All new Speakers, Diff Breather, AC Drain, Many interior bits...
    All is good until it is not...
    ^This...
    Better at 111k than later...
    once you have your 'ducks in a row', fluids in hand, and tools, the actual fluid change is pretty quick. Less than 1 hour for all 3 at a very leisurely pace.
    It is easy to do all three at once. (MT, TC, Diffs)
  19. Jul 14, 2025 at 10:04 AM
    #859
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    As several have said in here, it's fairly quick. This is one of those maintence jobs that won't actually kill your back or shoulders (unless they're already killed).
    Pretty simple too. The definition of "drain.... And fill"
    And unlike some Japanese manufacturers, Toyota put the fill plugs at the proper height so you get the right amount of fluid inside, instead of having to park sideways on a hill *ahem* Nissan
  20. Jul 14, 2025 at 10:25 AM
    #860
    BLtheP
    Plano, TX
    Just curious, what Nissan stuff has the fill holes at the wrong spots? Seemed like my Frontier transmission and t-case were right.
