3rd Gen Differential and Manual Transmission (6MT) Fluid Change
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Omar RVA, Mar 19, 2017.
  1. Mar 25, 2017 at 10:35 PM
    #81
    duckytw
    duckytw Well-Known Member
    Probably wont make much of a difference at all since the specs (outside of a teeny bit on the hot side weight) is different. But if you want to change it again, try some redline-- https://www.amazon.com/Red-Line-Transmission-Transaxle-Lubricant/dp/B004D4URV6 and if you need MT fluid, they got you covered too -- https://www.amazon.com/Red-Line-503...coding=UTF8&psc=1&refRID=GAC9TDADTBXKF72TYH67
  2. Mar 26, 2017 at 6:57 AM
    #82
    Omar RVA
    Omar RVA [OP] Well-Known Member
    Omar
    OR
    2020 Ram 2500 Power Wagon; 2019 Land Cruiser
    My understanding is that the transmission/transaxle product has different modifiers for the sake of Transmissions (being more "slippy" and kinder to the internal components is one of the reasons).
    OA
    Dannyblues and shakerhood like this.
  3. Mar 26, 2017 at 7:08 AM
    #83
    tibadoe
    tibadoe Well-Known Member
    Joe
    Gladys, VA
    17 Tacoma SR 4X4
    Good write-up. I was thinking of using Red Line products when I change my fluids but they don't offer a oil for the Transfer Case (SAE 75W). Anyone find a exact spec or equivalent that will satisfy the Toyota warranty? May have to stick with OEM for now.
    Dannyblues likes this.
  4. Mar 26, 2017 at 7:50 AM
    #84
    Omar RVA
    Omar
    OR
    Based on my research there is no equivalent for the transfer case fluid. A few pages back that got discussed and we pulled the safety sheets on the OEM Fluid.
    Cheapest I've found the cans online is $50ish per quart. Toyota decided to pull another dick move and spec 1.1 quarts. So you'll need two cans and barely use the one.
    OA
    1bad2k, Dannyblues and shakerhood like this.
  5. Mar 26, 2017 at 8:48 AM
    #85
    Dannyblues
    Dannyblues Well-Known Member
    Danny
    New Milford Connecticut
    2016 Tacoma TRD sport 4x4 double cab black
    weather tech mats, mud flaps, black side rail step, cargo bed liner, roll up cargo bed cover, wheel locks towing package
    I understand that OEM transmission fluid is Toyota labeled 75/85 w. Isn't their fluid good enough? If there is something proven to be better I might be interested in trying it but I don't want to blow my warranty. I bought the extended 6 year 100,000 mile bumper to bumper warranty. Note: your true warranty from Toyota corp expires at 36,000 miles or three years. The additional warranty I bought does not come from them as I thought!!! It's from a secondary company. You can't call and complain and get the case number and corporate field rep from Toyota corporation to come to the dealer and go to bat for you after your original warranty expires. So buy a second vehicle to use to keep the warranty in effect for the full three years and keep your mileage at 35,999. Dannyblues
  6. Mar 26, 2017 at 8:51 AM
    #86
    Dannyblues
    Danny
    And at $50 plus a quart and the need for that extra .1 quarts what do you think the dealership is using? I'm certain it's in unmarked drums. Dannyblues
  7. Mar 26, 2017 at 9:18 AM
    #87
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Transmission is 75w-90 and the Diffs are 75w-85, that straight 75 is for the Transfer Case.
  8. Mar 26, 2017 at 9:39 AM
    #88
    hikerduane
    hikerduane Stove & lantern collector, retired
    Duane
    Meadow Valley, Jefferson USA
    '16 Blazing Blue Pearl TRD Sport AC V6 manual, tow pkg
    RCI sliders fuel tank skid plate, Softopper, tailgate insert
    Nice, well written write up.
    Duane
  9. Mar 26, 2017 at 9:59 AM
    #89
    TartanEagle
    TartanEagle Well-Known Member
    '17 ACLB 4x4 MT
    OP = Thanks for all of your efforts in getting this great info to us. Nice work all around! I'm hoping it will be useful in helping my truck make it well past the 300k plus mile mark. Cheers!
  10. Mar 26, 2017 at 3:35 PM
    #90
    tibadoe
    Joe
    Gladys, VA
    17 Tacoma SR 4X4
    That's the same conclusion I came to. Was hoping I missed something. Sucks, but I will bite the bullet when the time comes.
  11. Mar 26, 2017 at 3:45 PM
    #91
    CaptainAwesome
    CaptainAwesome Well-Known Member
    Calgary, Alberta
    So explain it like I'm 5...
    When should I have the rear diff fluid changed? 10k? 20k?
  12. Mar 26, 2017 at 3:53 PM
    #92
    tibadoe
    Joe
    Gladys, VA
    17 Tacoma SR 4X4
    I will use the Toyota Maintenance as a guide and will replace the DF by 15k which is listed under the "Special Operating Conditions". Even though I do not really qualify for SOC I also use this schedule to change engine oil and other fluids. It's just what I do and I like to do it.
    Dannyblues and IronPeak like this.
  13. Mar 26, 2017 at 4:43 PM
    #93
    Omar RVA
    Omar
    OR
    My opinion, FWIW:
    • Front Diff, Rear Diff, MT Fluid - Break-in change between 5k and 10k
    • Front and Rear Diffs every 20k after
    • MT fluid every 20k or 30k after
    • I'll be using non-OEM oil for the subsequent changes (due to price and probably quality)
    I used to be someone who bought into the Toyota literature and the fact that they say "everything is broken in when it gets to you!" The blackstone results tell me for the most part, that simply isn't true.
    OA
    mtip, Dannyblues, TartanEagle and 2 others like this.
  14. Mar 26, 2017 at 4:49 PM
    #94
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    Did you forget the transfer Case..??
  15. Mar 26, 2017 at 5:10 PM
    #95
    Storman
    Storman Fukitol abuser
    South Western PA
    2017 SR AC 4x4 AT AC UP ->LONG BED<-
    Whole bunch of shit! $$$
    Yes, the toyota oil was too expensive .
  16. Mar 26, 2017 at 5:18 PM
    #96
    Omar RVA
    Omar
    OR
    I didn't forget it, just expected it to have much less use/wear since I'm not in 4wd often. I'll probably get it at my next service interval and just bitch about buying $50 cans of oil.
    OA
  17. Mar 26, 2017 at 6:13 PM
    #97
    over60
    Muskoka, Ontario
    Owch that is crazy pricy..! I had to top up my rear and front diffs, but the trans case was full (they musta made a mistake on that one)..hehe
    There has to be something cheaper than $50 damn dollars... My Dog..!:eek:
  18. Mar 27, 2017 at 10:11 AM
    #98
    brotherparker
    brotherparker Well-Known Member
    Nova Scotia, Canada
    2016 Access Cab TRD O/R 6MT
    With regards to the front diff. fluid being darker then expected, is the front differential always turning on these trucks in 2wd. I tried finding a good explanation of the A.D.D system online but I wasn't sure.
  19. Mar 27, 2017 at 10:18 AM
    #99
    Broccoli
    Broccoli Well-Known Member
    Airdrie Alberta
    2016 trd sport blazing blue,
    The diff spins but is not locked/engaged.
    Its a typical open diff.
    Omar RVA[OP] likes this.
  20. Mar 27, 2017 at 10:27 AM
    #100
    Omar RVA
    Omar
    OR
    Most of my knowledge here comes from my last vehicle (5th gen 4Runner). But piggy backing on @Broccoli here, my understanding is it operates as an open diff with only the side gears spinning. The ADD slides over to lock the passenger side axle in when in 4WD.
    OA
    Broccoli likes this.
