3rd Gen Differential and Manual Transmission (6MT) Fluid Change
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Omar RVA, Mar 19, 2017.
  1. Apr 1, 2017 at 5:28 PM
    #121
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    PM sent Teeco
  2. Apr 1, 2017 at 5:43 PM
    #122
    Dannyblues
    Dannyblues Well-Known Member
    Danny
    New Milford Connecticut
    2016 Tacoma TRD sport 4x4 double cab black
    weather tech mats, mud flaps, black side rail step, cargo bed liner, roll up cargo bed cover, wheel locks towing package
    I think you and I are living identical lives in parallel universes
    Dannyblues
  3. Apr 21, 2017 at 7:38 PM
    #123
    sxe4533
    sxe4533 Well-Known Member
    Edmond, OK
    2016 TRDORDCSBAT
    2015 TRD PRO suspension
    I just got the service done at the dealership and it looks like they mixed LSD oil in my rear deferential! According to what I have read here the TRD OR does not need that! Will it though hurt my differential in any kind of way?
    Dannyblues likes this.
  4. Apr 22, 2017 at 1:39 AM
    #124
    1bad2k
    1bad2k Well-Known Member
    Lone Star State
    2017 Tacoma TRD PRO
    Not in the least. It's just a total waste of the LSD additive. Make sure they didn't charge you for it.
    Omar RVA[OP] likes this.
  5. Apr 22, 2017 at 8:19 AM
    #125
    sxe4533
    Edmond, OK
    2016 TRDORDCSBAT
    They sure did charge me for it but I was more worried about actual damage!
  6. Apr 22, 2017 at 8:41 AM
    #126
    Dannyblues
    Danny
    What's a TRD OR? By LSD fluid do you mean rear differential limited slip differential fluid? Excuse my ignorance.
    My 2016 TRD sport has four wheel drive with a limited slip rear differential in the rear differential if that's any help.
    Dannyblues
  7. Apr 22, 2017 at 8:47 AM
    #127
    Omar RVA
    Omar RVA [OP] Well-Known Member
    Omar
    OR
    2020 Ram 2500 Power Wagon; 2019 Land Cruiser
    He's referring to a TRD off road (TRD OR). Our sports don't have a real LSD. It's all electronic.
    OA
  8. Apr 22, 2017 at 8:48 AM
    #128
    Dannyblues
    Danny
    Thanks for the clarification
    Dannyblues
  9. Apr 22, 2017 at 8:56 AM
    #129
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    Would checking your own fluid void warranty?
  10. Apr 22, 2017 at 9:03 AM
    #130
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    08 or 09 was the last of the true limited slip rears with clutch packs in the TRD Sport.
  11. Apr 22, 2017 at 9:21 AM
    #131
    Dannyblues
    Danny
    But whether electronic or mechanical etc a limited slip rear works the same right? As I understand it when one wheel turns faster than the other complimentary side, maybe 100 rpm faster either or any device provides a normally open rear differential to engage the slower turning side to make up for the less than 100% total traction required along the axle. Like the closed old positraction but only part time as necessary.
    I'm unclear as the exact methods used to accomplish this but I assume it's like a clutch with synchros???
    Dannyblues
  12. Apr 22, 2017 at 9:21 AM
    #132
    Omar RVA
    Omar
    OR
    No, checking or replacing with OEM or OEM equivalent fluids will not "void" warranty.
    OA
  13. Apr 22, 2017 at 9:23 AM
    #133
    Dannyblues
    Danny
    No. As long as all necessary or other maintenance is done to spec by you or a local mechanic shop your warranty still is intact. Save all receipts! Dannyblues
    specter208[QUOTED] likes this.
  14. Apr 22, 2017 at 9:28 AM
    #134
    shakerhood
    Southern Ohio
    Totally different, clutch packs are mechanical, the simulated stuff now uses electronics to apply the brakes or cut engine power.
  15. Apr 22, 2017 at 9:35 AM
    #135
    1bad2k
    Lone Star State
    2017 Tacoma TRD PRO
    That's how yours is different, instead of a real normal limited slip diff, yours electronically senses the wheel slip and the computer applies brakes to the spinning wheel so the other wheel can get traction and the power isn't wasted at the corner that is slipping. The clutch style is more like the old school posi traction and are much better imo.
  16. Apr 22, 2017 at 9:36 AM
    #136
    1bad2k
    Lone Star State
    2017 Tacoma TRD PRO
    Shakerhood beat me to it.
    Dannyblues and shakerhood like this.
  17. Apr 24, 2017 at 8:09 AM
    #137
    EdgeCrusher
    EdgeCrusher Well-Known Member
    Chicagoland
    '16 OR DCSB Fully Loaded
    Did my rear end yesterday @ 11.3k miles. Was a little low, couldn't get my pinky on any oil. Oil looked pretty clean surprisingly. Not like OPs. Magnet did it's job and had some decent flakes on it. Took a full 4 qts to refill. Should be good to go for 30k now. Will do the front soon though I doubt it needs it.
    Dannyblues and Omar RVA[OP] like this.
  18. Apr 24, 2017 at 8:14 AM
    #138
    Omar RVA
    Omar
    OR
    It's odd how different trucks wear different (we should have the same diff, mine without e locker obviously). Curious as to the build date on yours.
    OA
  19. Apr 24, 2017 at 11:16 AM
    #139
    EdgeCrusher
    Chicagoland
    1/16 baja
    Omar RVA[QUOTED][OP] likes this.
  20. Apr 25, 2017 at 10:30 AM
    #140
    Dannyblues
    Danny
    WOW!!! I had no idea the limited slip on my 2016 TRD works like that! That's only the traction control using the ABS system!!! Better than nothing but I find it outrageous that Toyota lists my TRD as having a limited slip rear! It's a bait and switch at best and intentionally misleading. It's like without being a modern day master mechanic you don't even know what the hell you bought. Thanks. Needless to say I'm disappointed in toyota.
    I had a 2006 Sonata that the dealer assured me had the modern equivalent of a real limited slip front wheel drive that delivered power equally between both front wheels or distributed it from the spinning wheel on ice to the opposite wheel.
    One day my right drive wheel spun on ice going up a hill. I waited for the limited slip to kick in. The ESC light came on and with my foot pinning the throttle down I disengaged the ESC. The right front tire had come to a dead stop so I again expected the LSD to engage. Instead the front one wheel only drive wheel spun back to life at full throttle and pulled me sideways into a ditch.
    That's when I learned about traction control and electronic stability control
    By the way forget about stopping on a bumpy decline with ABS brakes
    In the past before ABS I could lock up the wheels and they would hop up and down over the bumps and grab and skid my old van to a stop
    With ABS I tried it on the same bumpy decline and blew right through the intersection. The tires wouldn't lock up or grab and skid as the old style did when they bounced back down on the bumpy blacktop
    Several times a week I drive by a rusting early 1950's Chevy pickup sitting in the tall grass along the front of a local home.
    If I had the money I'd buy and restore that old truck and be done with all this new technology
    I'm old. I love the old stuff I grew up with and except for the medical advances mostly I could do without all of it.
    Dannyblues
    shakerhood likes this.
