3rd gen diffs in 2nd gen?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by davisi, May 5, 2021.
  1. May 5, 2021 at 3:52 PM
    davisi
    davisi [OP] Member
    Does anyone know if a front differential assembly from a 2016 tacoma will fit a 2005 tacoma? Also if a 2016 axle housing and rear 3rd member will fit a 2005 tacoma? Will the driveshaft fit? Will the rear axles/brakes fit?
  2. May 5, 2021 at 3:55 PM
    tacoman45
    tacoman45 Well-Known Member
    Orygun
    2014 TRD OR DCSB - MGM
    Hmm. That's a good question. I wouldn't be surprised if they were the same parts, but then again, thats a good spread of years between the two gens.
    You could compare parts numbers for each gen and see if they're a match?
  3. May 5, 2021 at 3:58 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Rear axles on the 3rd gens are completely different.
    I believe, but dont quote me, front clamshell diff is the same (but will have different gearing stock).
    tacoman45 likes this.
  4. May 5, 2021 at 9:24 PM
    davisi
    davisi [OP] Member
    If I bought the 3rd gen rear axles, would it work?
  5. May 6, 2021 at 7:22 AM
    tacoman45
    Orygun
    @nd4spdbh - you said 3rd gen axles wouldn't work on a 2nd gen, correct?
  6. May 6, 2021 at 7:25 AM
    Taco_Coma
    Taco_Coma That's a lovely accent you have. New Jersey?
    South NJ
    2018 DCSB SR5
    I mean you can make anything fit, it's just is it worth it
  7. May 6, 2021 at 7:36 AM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    theres a bit more to it than just "will 3rd gen fit on my 2nd gen" as there are different differentials/axles between different trims of each gen.
    2nd gen's had the 8.4" open/LSD or the 8" TRD e-locker whereas the 3rd gens get the upgraded 8.75" e-locker in the Off-road's and (to my knowledge) the 8" with open carrier diff in the Sports/SR5 etc.
    I'm pretty sure brakes and wheel speed sensors are identical, not sure on driveshaft length's between the different 3rd member sizes. We'll likely be doing a 3rd gen e-locker housing swap into a 2nd gen TRD sport fairly soon however so I'm sure we'll gain some additional knowledge by doing that and have better answers at that time.
  8. May 6, 2021 at 1:07 PM
    nd4spdbh
    SoCal
    If you bought the whole axle itself, (housing, shafts, diff etc) it would bolt right up (elocker wiring is likely different). But mixing and matching parts wont work, and driveshaft lenghts are probably slightly different.
  9. Sep 3, 2024 at 1:35 PM
    TomHGZ
    TomHGZ Well-Known Member
    2014 TRD Frankensport 4x4 AC AT
    Partial list: Vagabond Drifter 3rd Gen OR rear axle 4.30 gears Bilstein 6112s and Tundra 5160s.
    Just did this swap. The 3rd Gen OR axle (entire assembly) bolted right up to my 2014, no problem. 4.30 gears and a locker. I have a custom wiring harness for the locker on the way. More details soon.
    JasonLee and 6 gearT444E like this.
  10. Sep 24, 2024 at 6:44 PM
    TomHGZ
    NHyota and deanosaurus like this.
