3rd Gen DIY maintenance quick reference
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Amanelot, Dec 20, 2015.
  1. Oct 27, 2016 at 12:48 PM
    #261
    Hank Heel
    Hank Heel Well-Known Member
    WA
    Been a member of m3forum for almost 10 years, I've never taken my car to a shop with exception for alignments, with that said, it is common knowledge at least on that forums( yea I know car vs truck) that redline breaks down quickly, if you do use it, be aware that's you'll probably want to replace it in shorter intervals.
  2. Oct 27, 2016 at 12:56 PM
    #262
    GPsevinSixx
    GPsevinSixx Well-Known Member
    Ros Angerus
    2015twoAX2.4techPAWS
    6112/5160AALfnCNTSTRyokG015
    Bottle of RL has some sort of Toyota approval or recommendation, but using a synthetic lube doesn't mean "extended" service intervals. Agree with Hank.
  3. Oct 27, 2016 at 1:16 PM
    #263
    Hank Heel
    WA
    I don't know why people stray from oe fluids not knowing that aftermarket might have adverse effects.
    If I absolutely had to, I may go amsoil first, and possibly rp (pending manufacturers approval) id never go redline
  4. Oct 27, 2016 at 3:59 PM
    #264
    2016 Tacoma SR
    2016 Tacoma SR Well-Known Member
    HOCO Maryland
    2016 MGM 4Runner SR5
    ToyTec Ultimate lift, FX Pro wheels, 295/70/17 Ridge Grapplers, AFE drop in filter.
    Toyota doesn't make engine oil. They simply rebrand someone else's oil just like a lot of other manufacturers. Mobil 1, Valvoline, many other great engine oils out there at a lower cost. Buying OEM means nothing when it comes to that.
  5. Oct 27, 2016 at 5:06 PM
    #265
    Hank Heel
    WA
    Yea, but there's Toyota formulation, on bitog it is considered one of the best 0-20 synthetics out there. Your truck and your money, you do as you see fit, but making a blanket statement with no data to back up your "there's better than oem toyota" doesn't mean much.
    I just gave my 2¢, take it or leave it doesn't matter to me
  6. Oct 31, 2016 at 8:46 AM
    #266
    dilbert
    dilbert AI Member
    PNW
    2019 DCLB TRD Off-Road
    Wiper Blade Rubber Inserts for 2016
    85214-04030 (left)
    85214-0E140 (right)
  7. Oct 31, 2016 at 9:49 AM
    #267
    2016 Tacoma SR
    HOCO Maryland
    People really still buy inserts rather than just replacing the whole wiper?
  8. Oct 31, 2016 at 7:35 PM
    #268
    renau001
    renau001 Well-Known Member
    sure, why not, toyota OEM wiper inserts work great and last a long time
  9. Nov 6, 2016 at 2:28 PM
    #269
    SOSHeloPilot
    SOSHeloPilot My 1st Muscle Car
    S.E USA & S.E. Asia too
    2024 4Runner SR5
    Missing My Last Tacoma --- Had 11 Toyota trucks in the past and many other Toyota cars too.
    ...^^^... This thread helped me a lot this weekend ... :thumbsup:
  10. Nov 13, 2016 at 7:25 AM
    #270
    sorgon82
    sorgon82 wanna go for a rip bud
    Ont. Canada
    2016 Grey Tacoma sport dc long bed
    What grease does toyota use on their brake inspection?
  11. Nov 15, 2016 at 5:39 AM
    #271
    SilverII
    SilverII Well-Known Member
    DFW
    2016 Tacoma Limited 4x4 Blue
    Any info on spark plug maintenance/change?
  12. Nov 16, 2016 at 5:38 AM
    #272
    gpb
    gpb Well-Known Member
    Atlanta
    2017 White DCSB TRDOR 4x4
    My 2017 Warranty & Maintenance Guide states a 60,000 mile / 72 month interval to change spark plugs on the 2GR-FKS (V6)engine.
    For the V6, the 2016 service manual PDF that's floating around indicates the plug is Denso FK20HBR8, with new plug gapping of 0.7 to 0.8 mm (0.0276 to 0.0315 in.) and 18 Nm torque spec. Ignition coil attachment torque spec of 10 Nm, and wire harness bracket is 8 Nm.
    SilverII[QUOTED] likes this.
  13. Nov 17, 2016 at 2:38 AM
    #273
    Chiefandy
    Chiefandy Well-Known Member
    andy
    2017 tacoma
    thanks for all the info
  14. Dec 4, 2016 at 2:57 PM
    #274
    1_short
    1_short Member
    2016 MGM
  15. Dec 21, 2016 at 6:01 AM
    #275
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
    Toms 17 likes this.
  16. Dec 21, 2016 at 6:04 AM
    #276
    srdoublecab2.7
    srdoublecab2.7 SRlifted&gifted
    Austin, Tx
    2017 DC SR 2.7 MGM
    Stock for a minute
    Sub'd only have 3k miles
    Did the 1k oil change
    When do you guys change the rear diff fluid on a new truck due to shavings and break in?
    5k miles?
  17. Dec 21, 2016 at 6:10 AM
    #277
    2016 Tacoma SR
    HOCO Maryland
    Technically 500-600 miles if you go based on new aftermarket gear installs.
  18. Dec 21, 2016 at 6:12 AM
    #278
    srdoublecab2.7
    Austin, Tx
    2017 DC SR 2.7 MGM
    Stock for a minute
    I'm just stock with a lot of freeway miles
    I was gonna do 5k for preventive maintaince
    Think I'll be ok?
    Storman and SilverII like this.
  19. Dec 21, 2016 at 2:03 PM
    #279
    2016 Tacoma SR
    HOCO Maryland
    You'll be fine. Diff fluid is probably the most over looked fluid out there. People with 200K on their trucks and have never changed it, they don't even know it's there. I was going to do mine early also however i'll be having 4.88 gears installed soon so I didn't bother.
  20. Dec 29, 2016 at 9:53 PM
    #280
    VLTHNTR77
    VLTHNTR77 Well-Known Member
    Andrew
    Everett, WA.
    2016 Inferno TRD off-road
    RCI skid and sliders, GoodYear Ultraterrains, HID's, SCS SR8s, lots of ME-SO goodies, Diamondback HD.
    I need to show this video to the stupid service team leader at my local dealer. She tried to tell me that over servicing the u-joints could cause a failure
    and void the warranty.
