3rd Gen DIY maintenance quick reference
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Amanelot, Dec 20, 2015.
  1. Feb 18, 2016 at 9:11 PM
    FtApache
    FtApache Well-Known Member
    2019 Raptor
    Don't know if this is relevant, I was searching for front rotor diameter and found out that it's the same size for all trims on the 3rd Gen, 10.8"
  2. Feb 19, 2016 at 9:11 PM
    HapaHaole
    HapaHaole Active Member
    Given the torque spec range, get a 3/8 Inch torque wrench. 1/2 inch is a bit too big for the low torque drain plug.
  3. Feb 20, 2016 at 8:16 AM
    Metalnut
    Metalnut It's a clown world
    Adam
    North Alabama
    2016 Tacoma DCLB 4x4 TRD OR
    BP-51s, UCAs, BAMF sliders, SCS Stealth 6, 285 Wildpeaks, HIDs, LEDs, custom grille, hard top.
    I've had good luck with GearWrench torque wrenches. I have their 1/4" and 3/8" ones and they've done well. I'm picking up a 1/2" soon to replace a cheaper 1/2" that I don't like too much.
  4. Feb 20, 2016 at 8:25 AM
    aggie77
    aggie77 Well-Known Member
    Georgetown, TX
    2016 Tacoma Ltd 4x4
    Lund Nerf Bars Auto tailgate unlock
    Alignment Specs.
  5. Feb 20, 2016 at 8:27 AM
    sorgon82
    sorgon82 wanna go for a rip bud
    Ont. Canada
    2016 Grey Tacoma sport dc long bed
    Is there a problem with using a half inch adapter on a 3/8 torque wrench. Just realized majority of my sockets are 1/2 but bought a 3/8 torque wrench
  6. Feb 20, 2016 at 8:29 AM
    aggie77
    Georgetown, TX
    2016 Tacoma Ltd 4x4
    You should never use an adapter or extension with a torque wrench. It will affect the reading.
    DAS Taco, JoeRacer302 and sorgon82 like this.
  7. Feb 20, 2016 at 8:29 AM
    dfelz
    dfelz Well-Known Member
    Oceanside, CA
    2016 Inferno DCLB TDR OR 4x4
    I have two of the tekton torque wrenches from Amazon, one low range (in-lb) and one high range, like the one you're thinking of getting. I really like them and feel they are a good quality wrench; also can't beat the price.
  8. Feb 20, 2016 at 9:51 AM
    JoeRacer302
    JoeRacer302 Well-Known Member
    Joe
    Pasadena, CA
    2016 DCSB OR MT Inferno
    Front: 5100's @ 0.85 Rear: 1/2" spacers 265/75r16 on RAY10
    I have a tiny Tekton (1/4" drive) I got off Amazon for doing the torques on my bike (important for carbon stuff ...), and I have nothing but good things to say about it ... I'd never heard of the brand, but it had high reviews on Amazon, and it's been good for me.
  9. Feb 20, 2016 at 2:58 PM
    renau001
    renau001 Well-Known Member
    How does it affect torque if it doesn't change the torque arm? Not doubting ya, I've just never seen this before and would like to know for my own sake. You definitely can't add a crow's foot or something like that since it changes the torque arm distance without calculating the change. Most torque wrench "manuals" talk about this and have a template formula for this scenario. I've always use extensions/adapters as needed.
    Sharky50 and Howen like this.
  10. Feb 20, 2016 at 4:48 PM
    aggie77
    Georgetown, TX
    2016 Tacoma Ltd 4x4
    I'm probably a bit more anal about this than most as I have rebuilt a few engines in my time and some of the torque specs are fairly critical. Also, when I mentioned extensions I wasn't implying the type that extend the axis outward. Those extensions can be used with the formulas you mention above (example: http://www.dmctools.com/Products/torque_conversion_charts.html ). You will find a lot of people who believe that a vertical extensions (ones that give you more depth on the same axis) do not affect the torque applied to the bolt or nut. That's not true because there is some amount of the torque being applied to the extension itself - twisting it like a clock spring is the best analogy that I can think of. You can try this for yourself by using a long (at least 6") extension to torque something down to, say 100 lbs. Then take the extension off and do the same thing. You should find that it tightens a bit more more. Rather than get into a scientific or religious argument with anyone, for general purposes on u-joint bolts, lug nuts, exhaust connections, headers, etc. using an 3/8-1/2 adapter isn't going to make any real difference. Plus or minus a couple of pounds on an 80 pound lug nut doesn't mean the wheel will come off or you will warp something.
    patkap41, PRE-K, JpaceGA and 2 others like this.
  11. Feb 20, 2016 at 5:35 PM
    Jack the Machinist
    Jack the Machinist Member
    Jackson
    2016 Tacoma MGM Access Cab, V-6 Auto
    Use the shortest adapter you can find. It will work fine!
    Jack the Machinist
    patkap41, Toms 17 and renau001 like this.
  12. Feb 20, 2016 at 5:40 PM
    sorgon82
    Ont. Canada
    Are you really a mechinist tho...jack??
    Just fuckin with ya. Thanks bro if i break anything i wont blame you.
  13. Feb 20, 2016 at 8:24 PM
    renau001
    Thanks, makes sense, I'll have to experiment like you're talking about. But yeah, sometimes you just need an extension, so I guess you just do the best you can. Using a torque wrench even with inaccuracy still probably closer than anything I used to do by feel.
    patkap41 likes this.
  14. Feb 20, 2016 at 9:27 PM
    Jack the Machinist
    Jackson
    Yes, really a machinist, built motors for 50+ years. Also a mechanical engineer, Cal Poly 1969. (Well, you asked....) ;-)
  15. Feb 22, 2016 at 3:11 PM
    #35
    renau001
    Okay, so I finally made my purchase and ended up with a 4Runner instead of a Tacoma. Since this forum is still a valuable resource, I don't mind keeping this thread up-to-date to try and give back, but obviously I would probably not be the best person to do that. If anybody wants to copy and paste the original post for a new thread to maintain, just let me know.
  16. Feb 22, 2016 at 3:53 PM
    #36
    sorgon82
    Ont. Canada
    You started this thread on maintenance and you didnt even own a tacoma?
    Thats funny
  17. Feb 22, 2016 at 3:59 PM
    #37
    renau001
    Was completely in anticipation of buying, getting ready for a new vehicle, even got the manuals from TIS. A lot of the info was duplicate from my Highlander so not really much time at all invested yet.
  18. Feb 22, 2016 at 4:42 PM
    #38
    Millerman93
    Millerman93 Well-Known Member
    Kentucky
    2016/3rd Gen/V6/ Double Cab/ SR/4x4
    Are the differential, and transfer case crush washers the same part numbers as the 2nd gens ?
  19. Feb 22, 2016 at 5:29 PM
    #39
    renau001
    I don't know for sure, but I suspect they will be. Wasn't got put any part #'s in the original post until it gets confirmed by somebody with a receipt or the websites start updating their databases with the 2016 model info.
  20. Feb 23, 2016 at 8:22 AM
    #40
    AAChaoshand
    AAChaoshand Well-Known Member
    Brandon
    Central Texas
    2017 Nissan Titan SL 4x4
    So is there a specific way to change the filter? I ordered all of the parts I need for when I hit 5000 miles here in about a month. Same concept as a usual oil filter except I am just replacing the filter in the housing?
