3rd Gen DIY maintenance quick reference
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Amanelot, Dec 20, 2015.
  1. Sep 25, 2017 at 11:33 AM
    #421
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    Recently experienced high pitched squeaking going over some speed bumps? What could this be?
  2. Sep 25, 2017 at 12:28 PM
    #422
    DuboissTaco
    DuboissTaco Well-Known Member
    Josh
    Northern Ontario, Canada
    2017 Toyota Tacoma DCSB Off-Road
    Minor electrical commodities, SDHQ hidden winch mount with Warn Zeon Platinum 10-S, Bilstein 5100s on all 4 corners with OME 885s and Icon Progressive 3-Leaf, more to come!
  3. Sep 25, 2017 at 12:59 PM
    #423
    specter208
    California
  4. Sep 25, 2017 at 1:06 PM
    #424
    TacoMan408
    TacoMan408 Well-Known Member
    CA
    2016 TRD Sport Manual
    OVTune (04B13+1.05 87 FOB), Morimoto XB Headlights, Toyota LED Fog Lights, Toyota TRD Lift Struts, Wheelers Progressive AAL, TRD Pro Tail Lights, 17" TRD Pro SEMA wheels, BFG 285/70R17, TRD Skid Plate, Bakflip MX4, OEM Audio +, Anytime Front Camera, G-Tek Fab Door Sill Protectors, WeatherTech Floormats Suntek Carbon 35% Tint
    MTNHABITOVERLAND and Vbpiper like this.
  5. Sep 25, 2017 at 1:07 PM
    #425
    specter208
    California
  6. Sep 27, 2017 at 4:04 AM
    #426
    specter208
    California
    Just rotated tires my self and torque to 83 lb ft. The manual says to to recheck the torque after 1000 miles. Would that require me to reloosen them and retighten?
    Vbpiper likes this.
  7. Sep 27, 2017 at 4:48 AM
    #427
    Omar RVA
    Omar RVA Well-Known Member
    Omar
    OR
    2020 Ram 2500 Power Wagon; 2019 Land Cruiser
    My best guess is it's the front radiator/body mount. There are a few threads about it on here but the short version is: either the bushing quality is crap (possible) or the holes don't really line up (more likely) and put the connection in constant sheer. The bolt and sleeve chew up the bushing over time and that's what we get.
    OA
    specter208[QUOTED] likes this.
  8. Sep 27, 2017 at 10:40 AM
    #428
    EB Group
    EB Group Carbon Jedi
    Rudy
    Halifax
    2017 TRD Sport DCSB 6M
    They don’t want you to loosen them and then retighten them.
    Just retighten them.
    If they have loosened a little because of the past 1000 miles if driving you’ll be tightening them back where they belong.
    Make sense?
  9. Sep 27, 2017 at 10:46 AM
    #429
    specter208
    California
    Thank you sir!
    EB Group[QUOTED] likes this.
  10. Sep 27, 2017 at 11:11 AM
    #430
    EB Group
    Rudy
    Halifax
    Totally differbet topic already discussed on tacomaworld but I came across it again. Doing my 5th oil change or so and I still have to guess, based on what I can make out on the dip stick and what I have put in the engine for oil quantity, whether I have enough oil in the engine or not. Come on Toyota!
    I’ve roughed up the surface on the dip stick but it’s still not a straight forward read. The dipstick always shows way overfilled. Never had another vehicle like this with regards to reading oil level.
    :facepalm:
  11. Sep 27, 2017 at 11:28 AM
    #431
    specter208
    California
    Warm the oil up then leave dip stick out for 5-10 minutes then recheck your oil level.
  12. Sep 28, 2017 at 2:36 AM
    #432
    jtifm
    jtifm Well-Known Member
    2017 TRDORDCSB
    Sometimes, even with this, I end up pressing it to a piece of tissue because it is so hard to see.
  13. Sep 28, 2017 at 12:15 PM
    #433
    EB Group
    Rudy
    Halifax
    I'll give it a try. What is the logic behind this method?
  14. Sep 28, 2017 at 12:34 PM
    #434
    specter208
    California
    Sometimes oil sticks to the dipstick tube and coats the dipstick giving you an inaccurate reading. By waiting you allow the oil to drain out of the tube.
    over60 and EB Group[QUOTED] like this.
  15. Sep 28, 2017 at 12:40 PM
    #435
    EB Group
    Rudy
    Halifax
    Ok thanks for the explanation , I'll give it a try.
  16. Sep 30, 2017 at 2:45 PM
    #436
    renau001
    renau001 Well-Known Member
    From the OP:
    1) Check w/ engine warm greater than 5 minutes after shutting off engine
    2) Tip: leave dipstick out while waiting 5 minutes to allow oil in dipstick to drain back down, makes it easier to read
    3) Per manual, it’s 1.6 qts from low mark to full mark, don’t overfill
    over60 and Blazingbluesport like this.
  17. Oct 1, 2017 at 6:09 PM
    #437
    riverrockar
    riverrockar Well-Known Member
    Indiana
    2017 Tacoma DCSB TRD Sport INFERNO
    sandblast or beadblast your dipstick if you can, I've had good luck with that.
  18. Oct 11, 2017 at 8:36 PM
    #438
    STacoS
    STacoS Well-Known Member
    Loren
    Poulsbo, Washington
    2019 T4R OR
    Does anyone have any clue if 2nd gen cv axles are compatible with 3rd gens?
  19. Nov 2, 2017 at 3:43 PM
    #439
    MTNHABITOVERLAND
    MTNHABITOVERLAND Well-Known Member
    2016 Tacoma Camper Build Instagram: @mountainhabit
    Vagabond Outdoors Camper
  20. Nov 2, 2017 at 3:44 PM
    #440
    MTNHABITOVERLAND
    My amigos have done research bc we were going to buy one for any of us to use in emerg...different part numbers unfortunately.
    STacoS[QUOTED] likes this.
