3rd Gen DIY maintenance quick reference
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Amanelot, Dec 20, 2015.
  1. Nov 2, 2017 at 5:08 PM
    #441
    TacoMan408
    TacoMan408 Well-Known Member
    CA
    2016 TRD Sport Manual
    OVTune (04B13+1.05 87 FOB), Morimoto XB Headlights, Toyota LED Fog Lights, Toyota TRD Lift Struts, Wheelers Progressive AAL, TRD Pro Tail Lights, 17" TRD Pro SEMA wheels, BFG 285/70R17, TRD Skid Plate, Bakflip MX4, OEM Audio +, Anytime Front Camera, G-Tek Fab Door Sill Protectors, WeatherTech Floormats Suntek Carbon 35% Tint
    They probably haven't updated their vehicle list. This is the correct part number. I can also confirm its the one they shipped me.
  2. Nov 2, 2017 at 5:17 PM
    #442
    MTNHABITOVERLAND
    MTNHABITOVERLAND Well-Known Member
    2016 Tacoma Camper Build Instagram: @mountainhabit
    Vagabond Outdoors Camper
    Thx a bunch!
  3. Nov 5, 2017 at 6:20 AM
    #443
    mrjoshyman
    mrjoshyman Well-Known Member
    Josh
  4. Nov 5, 2017 at 9:33 AM
    #444
    Omar RVA
    Omar RVA Well-Known Member
    Omar
    OR
    2020 Ram 2500 Power Wagon; 2019 Land Cruiser
    It’s been awhile since I did mine but I don’t remember joints/grease points that looked like that. What year is your truck? 3rd gens built before July 2016 have 5 total driveshaft zerks (2 front, 3 back). Everything after only have the 2 front shaft zerks.
    For the front driveshaft, the zerk closest to the transfer case is hidden behind a heat shield. You’ll need a socket and extension or small hands to get that one.
    OA
    EB Group likes this.
  5. Nov 6, 2017 at 7:21 PM
    #445
    Omar RVA
    Omar
    OR
    Do you have a 4x4 or 4x2? If you have a 4x4 there are two more on the front drive shaft.
    OA
  6. Nov 6, 2017 at 7:35 PM
    #446
    mrjoshyman
    Josh
    found uhm...had a brain fart forgot about front drive shaft lol the one by transfer case wasn’t a biatch to get to...
    Omar RVA[QUOTED] likes this.
  7. Nov 29, 2017 at 10:57 AM
    #447
    Jmb0351
    Jmb0351 Active Member
    2016 Tacoma TRD off Road
    Ive searched this thread... Has anyone changed the fuel filter on a 2016 Tacoma yet?? I just hit 43k Im guessing its due?? Any info is appreciated
  8. Nov 29, 2017 at 3:29 PM
    #448
    renau001
    renau001 Well-Known Member
    I can't imagine a fuel filter replacement would ever be required. It is not a maintenance item called for by Toyota.
    EB Group and #4TOY4ME like this.
  9. Nov 30, 2017 at 10:17 AM
    #449
    #4TOY4ME
    #4TOY4ME Now driving #5
    Robert
    Kingman AZ
    17 MGM OR 4X4 AC
    Level 8 Mk6 16x8 0 offset , Bilstein 5100 G4 Elite Fold A Cover
    The fuel filter is located inside the fuel tank. It is integrated with the fuel pump assembly. Not a regular maintenance item.
    Robert
  10. Nov 30, 2017 at 10:02 PM
    #450
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
  11. Dec 2, 2017 at 9:49 PM
    #451
    Dick Danger
    Dick Danger Member
    Richard
    Pasadena, CA
    2016 TRD Sport 4x4 AC
    Z series shell BAMF sliders
  12. Dec 3, 2017 at 5:45 AM
    #452
    splitbolt
    NW Arkansas
    No. Toyota recmomends their 75w transfer gear oil LF.
    75w90 has 3x the cSt at 100°; not to mention the unknowns as far as additive package.
    Omar RVA likes this.
  13. Dec 3, 2017 at 5:18 PM
    #453
    Omar RVA
    Omar
    OR
    There’s discussion about it in the diff/MT fluid change thread I made. I found the spec sheet online (in Japanese) and another guy more knowledgeable than me tried to figure out the additives.
    Long story short, there is no Toyota 75W LF transfer case fluid equivalent. Ravenol has a product that they claim is equivalent but it seems dubious. That said, the average dealer either has $50 dollar cans of the transfer case fluid on hand or they pump in 75w-90; there has to be countless other trucks out there with that in the t-case that are still running.
    OA
  14. Dec 3, 2017 at 5:48 PM
    #454
    INSAYN
    INSAYN Well-Known Member
    PNWet, Oregon
    '17 TRD OR DCSB 6MT 4x4...'97 Taco XtraCab 5MT 4x4
    DIY Fabricobbler.
    At what point are you changing transfer case fluid, and what does the manufacture say regarding frequency?
    The 3rd gen may be more space age and require higher detailed maintenance than the 1st get, but I am going to wait and read through my manual before living that expectation. I only have 1003 miles on my '17 so I have time.
    My question stems from never changing my 1st get manual trans, transfer case, or axle lube since I purchased it 20 years and 218k miles ago. Fluid checks always look like the fluids are still new. No failures, or leaks to date. Hoping the 3rd gen will be as forgiving.
    SC4333 likes this.
  15. Dec 3, 2017 at 6:08 PM
    #455
    hiroslammer
    hiroslammer Well-Known Member
    Carlsbad,CA
    2016 OR 4x4
    I changed out both front and rear differentials with Mobile 1 75W-90, went ahead did the transfer case as well. I realized the transfer case fluid was fine and didn't need to be changed. I went back replaced the transfer case fluid with Royal Purple Synchromax, I read it was compatible, no worries since.
  16. Dec 3, 2017 at 7:36 PM
    #456
    INSAYN
    PNWet, Oregon
    DIY Fabricobbler.
    Why? Was there something that lead you to need to change these fluids?
  17. Dec 3, 2017 at 9:39 PM
    #457
    hiroslammer
    Carlsbad,CA
    2016 OR 4x4
    Just some early preventive maintenance, had 30K miles. Diff fluid looked pretty rough, transfer fluid looked brand new.
  18. Dec 4, 2017 at 4:45 AM
    #458
    Omar RVA
    Omar
    OR
  19. Jan 1, 2018 at 3:59 PM
    #459
    Jaymtb
    Jaymtb Well-Known Member
    Jay
    Colorado Mtns.
    2017 TRD OR AC ARE MX
    Has anyone used 5w 20 or 5W 30 oil e.g. Mobil 1? I would like to use it in hot weather towing. It looks like the Canadian versions list it as OK to use.
    The 0W 20 looks like a fuel economy idea, versus engine protection.
    Might this give a problem with warranty?
  20. Jan 30, 2018 at 6:04 PM
    #460
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    I would think your playing with fire, but I'm no Toyota engineer
