3rd Gen DIY maintenance quick reference
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Amanelot, Dec 20, 2015.
  1. Jun 30, 2018 at 3:22 PM
    #501
    EB Group
    EB Group Carbon Jedi
    Rudy
    Halifax
    2017 TRD Sport DCSB 6M
    Don’t trust anyone.
    Old Pirate and INSAYN like this.
  2. Jul 15, 2018 at 8:56 AM
    #502
    Worrom1
    Worrom1 Well-Known Member
    16 taco 4 door lwb
    3inch pro comp with all 265/75/16 BFG AT
    I agree with thatnoobguy change your own. A buddy of mine took his gen 2 to jiffy lube for an oil change last week they took the old oil out and never refiled it he drove it 10 miles without oil in it. Jiffy lube towed it to there mechanic still waiting for their decision on what they are going to do,a new or reman short block I would think.
  3. Jul 16, 2018 at 5:41 PM
    #503
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    Any guys running redline MT90 in their 3rd Gen 6-Speed for an extended time now? Is the GL-4 fluid really safe for the 6MT? And does anybody have any experience running this oil in the cold? Are shifts still smooth? I can't seem to find any OEM Toyota GL-3 oil.
  4. Jul 16, 2018 at 6:38 PM
    #504
    EB Group
    Rudy
    Halifax
    Redline MT90 Satisfies the requirements for the 3rd Gen 6 Speed Manual Tranny.
    "Toyota Genuine Manual Transmission Gear Oil GL-3 (GL-4) or equivalent, SAE 75W-90"
    I have just changed the fluid in my manual tranny with the Redline MT90. It's 100% fine I noticed no difference from the OEM fluid I had been using for the last 50,000KMS.
    specter208[QUOTED] likes this.
  5. Jul 16, 2018 at 6:52 PM
    #505
    specter208
    California
    Any chance Toyota specs a different formula for cold weather markets.
  6. Jul 19, 2018 at 3:39 AM
    #506
    EB Group
    Rudy
    Halifax
    I highly doubt it. If they did I feel they would have documented the alternative spec. I'm in Canada and am not in anyway concerned with the MT90 in cold weather.
  7. Jul 23, 2018 at 6:47 AM
    #507
    xpert1111
    xpert1111 Well-Known Member
    Central NJ
    2018 DCLB Sport
    Man do I miss changing the oil on my 2011 Tacoma with the oil filter on top of the engine!
    tallpilot, jdr43 and EB Group like this.
  8. Jul 23, 2018 at 9:22 AM
    #508
    specter208
    California
    Where to find cheap crowfoot wrenches for 1/2 inch drive!
  9. Jul 23, 2018 at 9:24 PM
    #509
    EB Group
    Rudy
    Halifax
    If your in Cali you should have many places to choose from. Being on the east coast of Canada I am limited in knowing what stores you have at your disposal.
    What about Harbour Freight? I think that’s a US store.
    My only other suggestion would be Amazon.
  10. Jul 24, 2018 at 2:35 PM
    #510
    EB Group
    Rudy
    Halifax
    Harbour Freight on has 3/8" drive sets and they are super cheap!
  11. Jul 24, 2018 at 6:35 PM
    #511
    renau001
    renau001 Well-Known Member
    Be careful with those. Cheap yes, but my set did not fit well, would not go on the square drive.
  12. Jul 24, 2018 at 8:36 PM
    #512
    EB Group
    Rudy
    Halifax
    Not promoting anything, just answering a fellow members question. I've not used them.
  13. Jul 24, 2018 at 9:14 PM
    #513
    renau001
    10/4. Just sharing my experience as a warning.
  14. Jul 29, 2018 at 12:06 AM
    #514
    Joisey
    Joisey Well-Known Member
    Toyota isn't the only manufacturer that does this. I bought a new 2018 Toyota pickup, a new 2006 GMC pickup and before that a new 1991 Ford pickup. All trucks had the fluids checked the morning after I came home from the dealer. All trucks were low on all fluids except the transfer case fluids. Engine oil was almost a quart low in all trucks. Ditto for coolant, about a pint low on all 3 trucks. Grease fitings have had little to no grease across all 3 brands.
    Over inflated tires (including the spare) seems to be a common theme. My Ford was 8 pounds over max inflation, my GMC was 18 pounds over max (48 pounds in all tires AND the spare). I bought this truck on 12/13/06. Can't blame heat from the sun for that. My Toyota was 6, (2)@7, 8, and 11 pounds over max for the spare. All tire pressures were checked in the shade, inside the garage and before being ridden. I assume the factory overinflates the tires to prevent air loss if the vehicles sit on the lot for a long time. My GMC rode like it had solid rubber tires.
    Both the Ford and GMC were low on refrigerant ( I have all the equipment to do AC work). The trucks would blow cold air on a warm day and cool to slighty warm air on a hot day. IIRC the Ford was 5 ounces low and the GMC about 3.5 ounces low. I haven't had time to check my new Tacoma, but that is only 13 days old and blows air cold enough to chill meat on a 95 degree day.
    Why do manufacturers do this? If they save $1 on each vehicle, ten million vehicles =$10 million dollars.
    The old adage is true. If you want it done right, do it yourself. My trucks are only seen by the dealer for factory recalls. If they can't do something simple like checking fluid levels, they can't do anything complicated like changing spark plugs.
    When I buy a new vehicle, I buy two things right away. A factory service/repair manual. Money WELL spent. The second thing is a 4X6 side spiral ring bound note book. I put lines every half inch inside the front and back cover. Inside the front cover is a list of maintenance intervals and common part numbers related to them, such as oil, fuel and air filter part numbers, one on each line. Inside the back cover is a list of tightening torques, wheel lugs and spark plug torque are at the top of the list. I also list less frequent wear items, such as brake pad brands and part numbers, belt brand and part numbers, etc. All sale slips are stored in a file inside the house. Two years of summer heat make receipts unreadable.
    On the interior pages is the maintenance record, starting with purchase date, place and mileage, along with any defects in the vehicle when I took possession from the dealer.
    This allows me to see that brand x belt lasted 5,000 more miles than brand z belt, etc.
    I hope this helps.
    dave.h, gulzeb and taco abbo like this.
  15. Jul 29, 2018 at 9:03 AM
    #515
    INSAYN
    INSAYN Well-Known Member
    PNWet, Oregon
    '17 TRD OR DCSB 6MT 4x4...'97 Taco XtraCab 5MT 4x4
    DIY Fabricobbler.
    That's some fine OCD right there.
    When do you find time to drive your new vehicle?
  16. Jul 29, 2018 at 11:36 AM
    #516
    Joisey
    It's called being organized, not OCD. When a vehicle is under warranty, accurate records reduce the chance of the dealer avoiding a warranty repair due to something that I did. I worked 32 years in the pharmaceutical field where you had to keep spotless records in the event there was a recall on a product, AND to cover your ass. Old habits die hard.
    Yodeville, Popojijo, Toms 17 and 5 others like this.
  17. Aug 9, 2018 at 12:09 PM
    #517
    sorgon82
    sorgon82 wanna go for a rip bud
    Ont. Canada
    2016 Grey Tacoma sport dc long bed
    specter208 likes this.
  18. Aug 12, 2018 at 7:07 PM
    #518
    specter208
    California
    That is Qi (chi), it is for wirelessly charging your cell phone.
    Trenton722[QUOTED] likes this.
  19. Aug 15, 2018 at 6:52 PM
    #519
    gulzeb
    gulzeb G
    Gulzeb
    Fort Worth, TX
    Two 08 Highlanders, 11 Outback, 13 Outback
    In order of install: Tint all around Weathertech floormats Center console insert and tray 17x7.5 +15mm alloy FJ rims, painted black Morimoto 2stroke led low beams Toyota bed mat AVS in-channel vent visors Removed black stickers from doors Removed air dam Debadged JDM ASTAR reverse leds Door sill protectors Reflective black tailgate inserts Rear cam anytime Fabric console cover Extra coverage engine guards Rigid SAE fogs Kicker/Subaru in-dash speakers JBL GT7-96 front door speakers JBL GT7-6 rear door speakers Hushmat deadener and wave breakers in doors Noico deadener behind rear seats Timbren Tortun4L rear bumpstops Added Line-X'd OEM flares OEM mudflaps Skid from TRD OR Avid Off Road front bumper guard Fatmat hoodliner 2nd gen 5100's with 2885s Sway bar relocate Cut off exhaust behind spare Wet Okoles on front seats Wheelers Superbumps Wheelers 2” single AAL ATH corner tie-downs ATH bed stiffeners Line-X’d rear bumper end caps TRD Sport/OR tail lights OEM bed step TRD Pro grille Fortin remote start Leer 180 Sleeping platform in bed 265/70/17 Terra Grappler G2 BPF front recovery point OV Tune 1.04 87 Westin 30” hidden bumper light bar Rago hidden bumper brackets
    If I put a fumoto valve, will I still need to drop skid for oil filter?
    Never done it before, and thinking of putting the fumoto the first time I do oil change
  20. Aug 15, 2018 at 7:18 PM
    #520
    SilverII
    SilverII Well-Known Member
    DFW
    2016 Tacoma Limited 4x4 Blue
    on a Pro skid, Oil filter is via an access panel you can take off. the oil drain has a hole on the skid
