3rd Gen DIY maintenance quick reference
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Amanelot, Dec 20, 2015.
  1. Nov 19, 2018 at 3:50 AM
    #561
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    Regarding oil change. What is the best way to check the oil level? Is it best for the truck to have its natural rake or should the body be close to perfectly level? I did my change and sometimes the oil reads right on the mark and sometimes about 1/8" over.
  2. Nov 19, 2018 at 5:12 AM
    #562
    Tacorific
    Tacorific Well-Known Member
    NE Iowa
    Barcelona Red 2018 SR5 I4 4X4
    Torque Pro, LED Map & Dome lights, Westin Hitch, Ride Rite Air bags with Daystar perches, Utility Package Rear Cab Panel
    I hate to argue, but, using a drive adapter or extension with a torque wrench is fine. It's the distance from the center line of the socket to the handle length.
    From https://forums.nasioc.com/forums/showthread.php?t=1301143
    Quote: "If you're changing the drive from 1/4 to 3/8 there isn't any change in torque value. The only time the value changes is if you're using a crowsfoot or some other addition that moves your turning point away from the head of the wrench. Extensions, sockets, drive adapters, etc... all keep the turning point in line with the wrench's head, so there's no change."
    (Retired Mechanical Engineer)
  3. Nov 21, 2018 at 4:27 AM
    #563
    Mario0815
    Mario0815 Well-Known Member
    Mario
    2016 Tacoma TRD Sport
    Great information to have.
  4. Nov 21, 2018 at 1:24 PM
    #564
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    :popcorn: Sub'd. Thanks OP, Toyota care just expired so it's time to to do it myself. Great thread.
    I just ordered some oil change stuff off Amazon. Gonna replace the plastic oil filter housing with aluminum. Bought a Fumoto valve too. Got the OEM filters for $6.00 each.
    specter208 likes this.
  5. Dec 2, 2018 at 4:47 PM
    #565
    kapn
    kapn Well-Known Member
    Annapolis, MD
    2016 TRDORLB Blue
    I just did my first diy service on my 2016 Tacoma. It’s been over two years since I purchased it and the dealership handled the oil changes until now. After about 20 years of wrenching on all sorts of cars, (International Scout, old Range Rover, Alfa Romeo, and hundreds of thousands of miles racked up on various Saabs) it felt good to get back under a vehicle and do some maintenance.
    I did however have a heck of a time with the oil filter. It was extremely tight. I ended up tapping the edge with a hammer and screwdriver to get it to start to rotate. I was doubting my strength because I was having to brace myself to keep from sliding around with the force I was using. Eventually I got it off and discovered the filter was larger than the replacement. In addition, it was twisted. Did the dealer use too large a filter last oil change? Or did I get too small a filter?
    RobP62 likes this.
  6. Dec 2, 2018 at 6:39 PM
    #566
    17TRD
    17TRD Well-Known Member
    2017 TRD OR 4X4 DCSB
    You should have loosened it. After 5k-10k miles of heat cycles it will get tighter and almost impossible to
    remove in one piece. So many horror stories of filters over tightened at the dealer...
  7. Dec 2, 2018 at 6:53 PM
    #567
    Amanelot
    Amanelot [OP] Member
    Texas
    2016 MGM TRD Sport DCSB
    Wow what the heck? The filter on the left looks like the correct filter, but its hard to judge size based on a pic. The one on the right looks like its either some crazy cool design, or it was smashed in there because it was too big
    RobP62 likes this.
  8. Dec 27, 2018 at 7:13 AM
    #568
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    Can someone walk me through greasing the propeller shaft? Am I greasing the zerks? The yokes? The center bearing? All of them?
    C41n likes this.
  9. Dec 27, 2018 at 7:15 AM
    #569
    Farcedude
    Farcedude Well-Known Member
    Greg
    Westminster, CO
    ‘23 MGM DCSB OR
    C41n, RobP62 and Anchovy[QUOTED] like this.
  10. Dec 27, 2018 at 7:19 AM
    #570
    Anchovy
    TRD Ferguson
    RobP62 likes this.
  11. Dec 27, 2018 at 11:09 AM
    #571
    SOSHeloPilot
    SOSHeloPilot My 1st Muscle Car
    S.E USA & S.E. Asia too
    2024 4Runner SR5
    Missing My Last Tacoma --- Had 11 Toyota trucks in the past and many other Toyota cars too.
    ...^^^... Great write up ... lost this thread and found it again ... :thumbsup:
    Takotime likes this.
  12. Jan 6, 2019 at 6:40 PM
    #572
    johntoyota
    johntoyota "I'm higher than you'll ever be." -Treetop
    Down yonder in TN
    16 truck
    Front wheel bearing nut size and torque?
  13. Jan 6, 2019 at 7:16 PM
    #573
    gulzeb
    gulzeb G
    Gulzeb
    Fort Worth, TX
    Two 08 Highlanders, 11 Outback, 13 Outback
    In order of install: Tint all around Weathertech floormats Center console insert and tray 17x7.5 +15mm alloy FJ rims, painted black Morimoto 2stroke led low beams Toyota bed mat AVS in-channel vent visors Removed black stickers from doors Removed air dam Debadged JDM ASTAR reverse leds Door sill protectors Reflective black tailgate inserts Rear cam anytime Fabric console cover Extra coverage engine guards Rigid SAE fogs Kicker/Subaru in-dash speakers JBL GT7-96 front door speakers JBL GT7-6 rear door speakers Hushmat deadener and wave breakers in doors Noico deadener behind rear seats Timbren Tortun4L rear bumpstops Added Line-X'd OEM flares OEM mudflaps Skid from TRD OR Avid Off Road front bumper guard Fatmat hoodliner 2nd gen 5100's with 2885s Sway bar relocate Cut off exhaust behind spare Wet Okoles on front seats Wheelers Superbumps Wheelers 2” single AAL ATH corner tie-downs ATH bed stiffeners Line-X’d rear bumper end caps TRD Sport/OR tail lights OEM bed step TRD Pro grille Fortin remote start Leer 180 Sleeping platform in bed 265/70/17 Terra Grappler G2 BPF front recovery point OV Tune 1.04 87 Westin 30” hidden bumper light bar Rago hidden bumper brackets
    Axle nut? W0133-1812200. Torque for 2nd gen was 173 ft-lb, not sure about 3rd.
  14. Jan 6, 2019 at 7:19 PM
    #574
    johntoyota
    Down yonder in TN
    16 truck
    Looking to buy the socket for it? Do you know the size?
  15. Jan 6, 2019 at 7:23 PM
    #575
    gulzeb
    gulzeb G
    Gulzeb
    Fort Worth, TX
    35, if it is same as 2nd gen
    johntoyota[QUOTED] likes this.
  16. Jan 6, 2019 at 7:30 PM
    #576
    johntoyota
    Down yonder in TN
    16 truck
    Thank you!
  17. Jan 7, 2019 at 3:30 AM
    #577
    tallpilot
    tallpilot Well-Known Member
    David
    Florida
    2016 TRD OR 4X4 DC SB AT Silver
    Mobtown sliders, RCI skids, Bilstein 6112/5160/Dakar, DuroBumps
    It is the same. I just had mine off. Torque sounds correct as well. I’ll double check and edit this post if it’s different.
  18. Jan 7, 2019 at 10:34 AM
    #578
    Tacorific
    NE Iowa
    Is this the same nut as what is used on the drive shaft?
    Thanks,
  19. Jan 7, 2019 at 3:23 PM
    #579
    tallpilot
    David
    Florida
    The yoke flange nuts are much smaller than the axle nut 14 and 17mm. I am not sure of the pinion nut size. I haven't messed with it.
    BTW 173 is correct on the axle nut torque. So both the size and torque are the same on 6 lug second gens and third gens. Good to know.
    Tacorific likes this.
  20. Jan 10, 2019 at 1:26 PM
    #580
    714reyesj
    714reyesj Well-Known Member
    Danny
    Orange County, CA
    2017 TRD Off-Road 4x4
    So what's the consensus on the transfer case fluid?
    Ok to use the same Mobil1 75w90 used on the diffs or not?
    I tried looking for the OEM 75w Toyota fluid but it was on backorder at my dealership and its expensive AF.
