3rd Gen DIY maintenance quick reference
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Amanelot, Dec 20, 2015.
  1. Mar 20, 2016 at 8:52 PM
    #61
    renau001
    renau001 Well-Known Member
    2TR-FE engine:
    DENSO FK20HR-A8
    2GR-FKS engine:
    DENSO FK20HBR8
  2. Mar 20, 2016 at 8:59 PM
    #62
    stealthmode
    stealthmode Well-Known Member
    Alberta
    2016 Short N Stubby Bed- MGM
    Front and Rear lifts Tires ECGS bushing Lots of other crap +HP sticker
    Thank you:thumbsup:
  3. Mar 21, 2016 at 7:05 AM
    #63
    bsacamano
    bsacamano Well-Known Member
    2016 Tacoma Sport DCLB V6 4x4
    Any way to make the skids easier to remove for those of us who will be changing our own oil? Has anyone used any sort of quick release fastener or cut a hole in the thing for oil filter access?
  4. Mar 21, 2016 at 4:13 PM
    #64
    MVMike
    MVMike Well-Known Member
    2016 White Tacoma TRD OffRoad Double Cab
    DRIVE SHAFT U-JOINTS on 2wd
    FYI - My 2016 TRD Offroad 2WD has NO Zerks on any of the U-joints. Others with 2WD Offroad and Sports reporting the same.
    * Guess Toyo thinks we wont get them wet or dirty . . . Hah !!!! :mudding:
  5. Mar 21, 2016 at 7:38 PM
    #65
    arkywally
    arkywally Well-Known Member
    David
    2016 DCSB TRDOR
    ICON Stage4 285/70/17 Cooper STT Pro Method NV
    Sub'd good stuff...
  6. Mar 22, 2016 at 8:50 AM
    #66
    bsacamano
    Thanks for this list. I used it to order all my oil change supplies and changed the oil yesterday after 2,000 miles.
  7. Mar 22, 2016 at 1:30 PM
    #67
    renau001
    Good catch. Updated OP, thanks.
  8. Mar 22, 2016 at 1:31 PM
    #68
    renau001
    Great, take a look at the OP, if you can confirm the italicized info, That'd be great.
  9. Mar 22, 2016 at 4:36 PM
    #69
    bsacamano
    Yep. All italicized info correct.
    renau001[QUOTED] likes this.
  10. Mar 22, 2016 at 5:07 PM
    #70
    CFTaco
    CFTaco Well-Known Member
    Central Florida
    3rd gen. Tacoma TRD Off-Road 4x4
    Sub'd
  11. Mar 23, 2016 at 3:34 AM
    #71
    vinnyd34
    vinnyd34 Well-Known Member
    Vincent
    Williamsburg, VA
    2016 Silver Tacoma TRD Sport DCSB
    TRD Pro skid, TRD Pro Wheels , TRD Pro Grill, Factory Mud Guards, Factory Bed Mat, Exhaust Tip, N-Fab Nerf bars, Pop-N-Lock Tailgate Lock, MicTuning 32" Lightbar.
    Guys:
    On the oil change vid, he pulls the oil drain plug from the canister to drain excess oil from it before he removes the canister itself. My question: is this really necessary? Why not just remove the canister and not mess with the plastic fitting and drain hose? The down side is that you may spill a little oil. The upside is that you have one less thing to mess with and one less o-ring to leak! Your opinions count as I've learned a lot here. tia
  12. Mar 23, 2016 at 4:04 AM
    #72
    schmack b
    schmack b Well-Known Member
    Clarksdale, Mississippi
    2016 DCSB TRD OR M/T
    That is what most people do. Plus I have heard that the Hulk puts on that plug at the factory and even if u put your ratchet in the drain plug, u end up unthreading the canister anyway.
  13. Mar 23, 2016 at 5:31 AM
    #73
    renau001
    Never seen anything official, but the main advantage is it's cleaner. I've also seen some concern that you do not necessarily want to leave that o-ring in there forever as it has the potential to degrade if you never changed it. What would be interesting is if somebody could do a apples to apples comparison of using vs. not using the filter drain plug to see if it changes the total amount of oil that is drained.
  14. Mar 23, 2016 at 5:51 AM
    #74
    bsacamano
    I used the plastic fitting when I changed the oil a couple of days ago. There is no need to add a hose because it just drains straight down. I'll definitely use the drain fitting again next time I change the oil as well. There was a LOT of oil that drained out of there.
    It came right off with no problem at all.
    Also, the oil was B.L.A.C.K.! I was a little surprised to see that after only 2,000, but, then again, I've never changed oil after only 2,000 miles before.
    I'm also considering taking the angle grinder to the skid plate to cut a hole in it to be able to access the filter without having to take the skid plate off.
  15. Mar 23, 2016 at 11:42 AM
    #75
    Heepspo
    Heepspo I wouldn't say I'm missin' it, Bob...
    Washington State
    2016 TRD OR DCSB, Prem & Tech w/JBL, Towing
    Fuel Vector D600 17" Wheels, Toyo 285/70-17 AT2 Tires, Tuff Country 52907 3" Leveling Lift, Full Katzkin Leather (Black with Platinum Stitching), SOS Concepts Streamline Front Bumper, 3M Scotchgard PPF, "no vtec 4me" BHLM, Husky X-act Contour Floor Liners, Cali Raised Faux Pro Grille, Predator Sliders, WeatherTech Mudflaps, UnderCover Ultra Flex Tonneau Cover, OEM Bed Mat, Headlight Revolution Supernova V.4 Headlights/High Beams & Carbide Canbus 2.0 Amber LED Front Turn Signal Bulbs, Salex Console Organizer, Rhino Seat Belt Extenders (removes annoying dinging), 15% Window Tint, JDM ASTAR 800 Reverse Lights, LED Interior Lighting Package, Stant Locking Gas Cap, Redline Tuning QuickLIFT PLUS Hood Struts, Gentex Compass Mirror w/Homelink, mesojdm Ultimate Turn Signals, Hondo Garage Un-Holey Dash Mount and AR15 Bolt Radio Knobs, CBoy808 Custom Bedside Decals and Flags, De-Badged Doors, Tailgate and Interior Visor Stickers.
    I've changed my oil once so far and I've only done it while removing the plug. I guess I was lucky cuz the plug came out easily.
    I used the 5/8" ID tubing with the plastic fitting to drain it first (tubing ran directly to oil containment pan), so I don't know how messy it would have been without.
    One quick note: when using the plastic fitting and tubing, firmly and quickly push the fitting into the filter housing until it snaps into place or it will leak around it and cause a mess anyway. I kind of nonchalantly pushed it up in there and there was more mess than there needed to be. As soon as that spring is pressed, the oil starts running pretty quick.
    Once it all stopped draining out, I removed the filter housing and there was still a little oil that came out around the threads. I imagine that if I didn't drain it first, it would have been pretty nasty.
    Blazingbluesport likes this.
  16. Mar 23, 2016 at 12:42 PM
    #76
    renau001
    If both the plug and housing are properly torqued, this shouldn't be a problem. Having worked at an auto plant and knowing how their tooling is set up, I have somewhat of a hard time believing they're being over torqued at the factory. I think those stories come from shops and dealer techs over torquing. If you're the first person to touch it, should be good to go.
  17. Mar 24, 2016 at 12:04 PM
    #77
    tacitos
    tacitos Tah-Key-Toes
    16 TRDORDCLBJBL
    Sub'd
    Does the manual say anything about what to do if you have 2-years free service? :D
  18. Mar 24, 2016 at 12:40 PM
    #78
    renau001
    Nothin' is free :)
  19. Mar 25, 2016 at 7:39 AM
    #79
    SilverII
    SilverII Well-Known Member
    DFW
    2016 Tacoma Limited 4x4 Blue
    Any info on wipers?
  20. Mar 26, 2016 at 9:37 AM
    #80
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    Sub'd.
    Great thread! Very handy info.
