3rd Gen DIY maintenance quick reference
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Amanelot, Dec 20, 2015.
  1. Jul 31, 2020 at 8:19 AM
    #821
    CrazyAirborne
    CrazyAirborne Who jumps out of perfectly good airplanes?
    Central Wisconsin
    2017 TRD Sport
    Turned the OP into a PDF for easier viewing or saving to phone or whatever, figured Id share in case anyone finds it useful. Ill be saving it on my garage PC for a easy quick reference while working on the truck.
  2. Aug 1, 2020 at 7:59 PM
    #822
    Heybud
    Heybud Well-Known Member
    Washington
    2017 Tacoma TRD Sport
    Anyone know if you need an additive for the rear diff fluid? Not seeing anything on the list but figured I’d double check to be safe as a buddy mentioned It may be needed for the A-LSD. I’ve got a 2017 TRD sport for context.
    Amanelot[OP] likes this.
  3. Aug 1, 2020 at 11:49 PM
    #823
    Amanelot
    Amanelot [OP] Member
    Texas
    2016 MGM TRD Sport DCSB
    Depends on what fluid you plan on using?
  4. Aug 2, 2020 at 6:40 AM
    #824
    Heybud
    Washington
  5. Aug 9, 2020 at 6:55 PM
    #825
    jerkwithkeyboard
    jerkwithkeyboard Well-Known Member
    Western suburbs Chicago, ILL
    2016 TRD Sport DCSB Inferno 4x4, loaded /JBL/Tonneau Cover/ Roof Rack
    17" Black TRD rims Tacoma Stainless Steel Rear Tailgate Letter Inserts Brake light flasher Center LED 110v and 2-3amp USB plugs mod in back seat center 400w on all the time mod SSR-610-40 SumoSprings 32 INCH 180W CREE LIGHT BAR (5D ) AUXBEAM BedStep and Pop & Lock Power Tailgate Lock Blue LED glove box light (fix no light) Bed light Blue LED's Wired to turn on when Gate is opened Tempered Glass Center Touch Screen Protector Rear Camera anytime Navigation Bypass ( a must) Rexing V1 3rd Generation Dash Cam hard wired in OXILAM 912 921 LED Reverse Light 2000 Lumens TRD Pro Grill TRD Skid plate
    Heybud[QUOTED] and Amanelot[OP] like this.
  6. Aug 10, 2020 at 10:53 AM
    #826
    Heybud
    Washington
    Awesome, thanks!
  7. Aug 10, 2020 at 5:47 PM
    #827
    jerkwithkeyboard
    Some earlier posts about this, #736
    Toyota Genuine Differential gear oil LT 75W-85 GL-5 or equivalent - Toyota part # 08885-02506
    I also use it in the transfer case instead of
    SAE 75W Toyota Genuine Transfer gear oil LF or equivalent - Toyota part # 08885-81080
    SO much easer to just get one and put it in, got down to -15F to -20F last year and it shifted fine.
    Heybud[QUOTED] and Dirk Diggler like this.
  8. Aug 11, 2020 at 5:57 PM
    #828
    mattleg
    mattleg Well-Known Member
    Kansas
    2020 OR DCSB AT 4WD
    For the automatic transmission fluid, I worked out the math on the drain and fill:
    One cycle = 35% replacement
    Two cycles = 55% replacement
    Three cycles = 69% replacement (manual recommended)
    Four cycles = 78% replacement
    This assumes 10.8 qt total capacity (with aux air cooler), 3.3 qt drain and fills, a 4.0 qt final fill, and 100% mixing. Add 2% to those numbers for a 10.2 qt system capacity (without the aux air cooler). The replacement percentage also increases if you overfill during the process.
    Hopefully that's helpful to someone.
    nikonNUT, bgoods, patkap41 and 2 others like this.
  9. Aug 28, 2020 at 1:18 PM
    #829
    BrokenCoastie
    BrokenCoastie Nonsolis Radios Sediouis Fulmina Mitto
    James
    East Bay area
    ‘17 TRD OFF ROAD
    Anyone else having a hell of a time with the trans fill plug?
  10. Aug 28, 2020 at 1:23 PM
    #830
    mattleg
    Kansas
    2020 OR DCSB AT 4WD
    Not done one yet, but I'm debating an adapter of some sort to fill through the check plug.
  11. Aug 28, 2020 at 1:25 PM
    #831
    Dirk Diggler
    Dirk Diggler Under the Stun Gun
    Columbus, GA
    2017 MGM OR DCSB
    I used a 36" breaker bar...it was not cooperative
  12. Aug 29, 2020 at 8:19 AM
    #832
    Amanelot
    Texas
    First time busting it free was not fun, it kept feeling like it would round off. Make sure you use a torque wrench when you put it back in and it'll be easier to take off in the future.
  13. Aug 30, 2020 at 1:04 PM
    #833
    BrokenCoastie
    James
    East Bay area
    ‘17 TRD OFF ROAD
    Yea I got it off! Had to use a wrench as an extention for leverage. Washer was mangled so think someone at the factory was a dick about it. Drain pug came right out! Only have 29k on it but...the oil that came out was not pretty. So naturally, xfer and diffs next weekend! Just to be sure...
    Amanelot[QUOTED][OP] likes this.
  14. Aug 31, 2020 at 4:38 PM
    #834
    Demfer
    Demfer Well-Known Member
    M
    Black 2016 Tacoma TRD Off-road
    Just did rear diff, front diff and transfer case. Used amsoil severe gear oil 75w-90 for all. Runs smooth as butter now.
    note: at 34k miles, front and rear diff oil looked like $hit however transfer case looked like it had plenty of life left.
  15. Sep 2, 2020 at 9:55 AM
    #835
    sdsurfer
    sdsurfer @ODNAREM life...
    Dirk
    San Diego
    DCSB TRD 4X4
    5100s/OME 888s. Dakar leaf pack. Total Chaos UCAs. DeMello Sliders. BAMF Recessed Grille. Prinsu Cabrack and Toprack.
  16. Sep 2, 2020 at 6:57 PM
    #836
    BrokenCoastie
    James
    East Bay area
    ‘17 TRD OFF ROAD
    Whats this? Am I about to fuck my truck up? Why the popcorn?!
  17. Sep 14, 2020 at 4:38 PM
    #837
    BangosTaco
    BangosTaco Well-Known Member
    2020 Toyota Tacoma TRD PRO [MT]
    Stock
    So I have a question.. My 2020 didn't come with a oil drain gasket... How important is that gasket till the next oil change?
  18. Sep 14, 2020 at 4:51 PM
    #838
    BillW
    BillW Well-Known Member
    N. Phoenix
    2018 DCSB TRD OR MT
    Did it stay on the on oil pan?
    You can buy a 10pack on Amazon for cheap, I think they're important.
    nikonNUT and BangosTaco like this.
  19. Sep 14, 2020 at 5:26 PM
    #839
    BangosTaco
    Stock
    No it didn't. I was told to slower take the drain bolt off because oil will fly out. I made sure to hold onto the bolt while wrenching but I didn't feel or see the washer gasket
  20. Sep 14, 2020 at 5:27 PM
    #840
    BangosTaco
    Stock
    + it wasn't hard to un-tighten the bolt too!! Had my breaker bar on the side just in case I needed it
