3rd Gen DIY maintenance quick reference
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Amanelot, Dec 20, 2015.
  1. Mar 11, 2021 at 10:42 PM
    #901
    BangosTaco
    BangosTaco Well-Known Member
    2020 Toyota Tacoma TRD PRO [MT]
    Stock
    Is it allow to ask on this thread about where I can buy OEM Toyota fluids online?
    pop.tremuloides and Amanelot[OP] like this.
  2. Mar 12, 2021 at 5:44 AM
    #902
    Amanelot
    Amanelot [OP] Member
    Texas
    2016 MGM TRD Sport DCSB
    Of course.
    I usually hit up ebay and Amazon and buy from which ever is cheapest. They usually have bundle deals ex. 6 qts 0W20 for $40
    BangosTaco[QUOTED] likes this.
  3. Mar 27, 2021 at 10:43 PM
    #903
    Raeburn
    Raeburn Well-Known Member
    2017 ORDCSB
    Just greased the fittings on my 2017 off-road. Found 2, both on the front propeller shaft. One is covered by a small skid plate at the front of the transfer case and easy to miss (probably already been mentioned in this thread - my apologies if it has)
    Speedbird likes this.
  4. Mar 28, 2021 at 6:39 AM
    #904
    Speedbird
    Speedbird Well-Known Member
    Fort Couch
    2017 TRD-OR
    Check out this post: 3rd Gen DIY maintenance quick reference
    Short Answer: Amazon pump thing is very overpriced and tiring. Buy a empty catsup bottle at the dollar store ($1-2), rig up a short amount of clear tubing; takes 2-3 refills of the bottle and your done, just as messy maybe a little less than the rip off pump and faster in the end.
  5. Mar 28, 2021 at 7:30 AM
    #905
    BillW
    BillW Well-Known Member
    N. Phoenix
    2018 DCSB TRD OR MT
  6. Mar 28, 2021 at 12:36 PM
    #906
    jerkwithkeyboard
    jerkwithkeyboard Well-Known Member
    Western suburbs Chicago, ILL
    2016 TRD Sport DCSB Inferno 4x4, loaded /JBL/Tonneau Cover/ Roof Rack
    17" Black TRD rims Tacoma Stainless Steel Rear Tailgate Letter Inserts Brake light flasher Center LED 110v and 2-3amp USB plugs mod in back seat center 400w on all the time mod SSR-610-40 SumoSprings 32 INCH 180W CREE LIGHT BAR (5D ) AUXBEAM BedStep and Pop & Lock Power Tailgate Lock Blue LED glove box light (fix no light) Bed light Blue LED's Wired to turn on when Gate is opened Tempered Glass Center Touch Screen Protector Rear Camera anytime Navigation Bypass ( a must) Rexing V1 3rd Generation Dash Cam hard wired in OXILAM 912 921 LED Reverse Light 2000 Lumens TRD Pro Grill TRD Skid plate
    Above.
    Look like that's a north vs south thing.
    :101010:
  7. Mar 31, 2021 at 1:05 PM
    #907
    Tacowin1013
    Tacowin1013 Well-Known Member
    2017 OR DCSB 6MT MGM
    About to pull the trigger on fluids for front/rear diff since im at 37k miles, going to go with Amsoil Severe Gear 75w-90 since it comes in the easy pack quart bag, should make refilling a breeze. And Redline MT-90 for the manual trans fluid swap. Based on what i'm reading about the Transfer case, i'll probably wait to do the fluid swap, everyone seems to say when they flushed at 30k it was clean as new.
    Marcmtb1 and TeecoTaco like this.
  8. Mar 31, 2021 at 1:56 PM
    #908
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    Did all mine at 60K miles...front diff dirty, rear diff pretty clean, Trans not bad but MT-90 is way worth it and TC was clean clean clean...good call
    Tacowin1013[QUOTED] likes this.
  9. Mar 31, 2021 at 3:00 PM
    #909
    Tacowin1013
    Did you notice better shifting with the MT90?
    TeecoTaco[QUOTED] likes this.
  10. Mar 31, 2021 at 3:17 PM
    #910
    TeecoTaco
    SW Ontario
    Yep...now it wasn't earth shattering difference but it was a smoother difference for sure. Most notablly 2nd to 1st downshifts at a slow roll...much easier engagement. You will be happy with the Redline.
  11. Apr 1, 2021 at 1:20 PM
    #911
    SRick
    SRick Well-Known Member
    Rick
    2017 White Tacoma SR Access Cab Utility 4x4, 4 Cyl/5 SpdMT
    - ECGS Front 4x4 Needle Bearing Replacement Bushing - RCI Tacoma Skid Plate - Cooper, Discoverer AT3 4S, 265 /75 R16 116T SL OWL - 16" Dark Anthracite Alloy Wheel, PT94635160 - A/C Condenser Hose reroute - OEM all weather mats / OEM door sill protectors (stock) - Installed Intermittent Windshield Wiper Switch Assembly - Installed Towing rear light kit-4 wire - Installed Draw-Tite Max-Frame Trailer Hitch Receiver - Custom Fit - Class III - Installed CLAZZIO Leather Seat Covers, Gray - RCI Tacoma Gas Tank Skid Plate (on order) - RCI Tacoma Rock Sliders Rock Sliders
    I noticed a slight difference from 1st>2nd, and downshifting from 2nd>1st. I didn't have a smooth shift in either, and now have a slight, noticeable improvement-- I would recommend changing to Redline MT.
  12. Apr 5, 2021 at 7:13 PM
    #912
    tacomarich
    tacomarich luvsoffroading
    rich
    arizona
    trd 4x4 offroad
    This might have been posted before. With covid around this past year or so, I have not been driving nearly as much.
    Have a newer 3rd gen and it has been six months with barely 2500 miles put on.
    I see in the maintenance guide 5k or every six months. I have read posts 5k inspection, tire rotation etc. Then at 10k oil changes.
    I don't want to wait until 10k, before changing my oil and since so little miles driven in six months.
    Since it has been six months but way under 5k miles, just get my oil changed at least correct?
    I will wait for tire rotation at this point. Any other suggestions?
  13. Apr 6, 2021 at 6:14 AM
    #913
    Tacowin1013
    Its been beaten to death on this subject, some will wait the full 10k that is recommended for 1st oil change, others will swap fluids out early because they consider it "break in". I do all my own maintenance, so it was cheap and easy for me to swap, so I changed oil at 1000 miles. There were some metal and other stuff in it, but nothing unexpected from a new motor. It's your car and investment, do what you are comfortable with. If you are on the fence about swapping fluids, just do it. You'll have peace of mind. Thats what i did.
  14. Apr 8, 2021 at 4:21 PM
    #914
    tacomarich
    rich
    arizona
    trd 4x4 offroad
    Thank you. The dealer is stuck on recommend doing at 10000 miles or 1 year, even if no where close to 10k for oil change (shrugs). One other person told me 10 months if not driving much.
    I will have it changed sooner for piece of mind, after what you told me you found in your oil just after 1k miles!
    I have that toyota care and should be free.
  15. Apr 8, 2021 at 4:45 PM
    #915
    Tacowin1013
    Keep in mind if you use your Toyota care for early changes, you will have to pay for them eventually! Basically you get 2 free oil changes (10k and 20k) however you choose to use them is on you.
  16. Apr 8, 2021 at 5:03 PM
    #916
    tacomarich
    rich
    arizona
    trd 4x4 offroad
    I hear you and what they mentioned as well. I just can't justify waiting 10 months to one year or 10k for an oil change, especially when not driving as much.
  17. Apr 8, 2021 at 5:07 PM
    #917
    Watkinseli91
    Watkinseli91 Well-Known Member
    Eli
    Greenville, SC
    2021 LR PRO
    Lmao I went every 5000 for mine
  18. Apr 8, 2021 at 5:12 PM
    #918
    Tacowin1013
    And you're positive they changed your oil every 5k? Its 5k for tire rotations and 10k for oil changes per Toyota
  19. Apr 8, 2021 at 5:17 PM
    #919
    tacomarich
    rich
    arizona
    trd 4x4 offroad
    How many miles in six months? 5k?
  20. Apr 8, 2021 at 5:25 PM
    #920
    tacomarich
    rich
    arizona
    trd 4x4 offroad
    I'm still stuck on this 6 months or 5,000 miles. I mean I know it is 10 months to a year or 10,000 miles for the oil change, but what if you're not driving as much?
    for me 6 months and 2,500 miles so far.
