3rd Gen door sill protectors install
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Tmac3220, Oct 25, 2018.
  1. Sep 14, 2020 at 10:17 AM
    #41
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    Yep. Better than new.
  2. Sep 14, 2020 at 10:53 AM
    #42
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    My dealership knew nothing about the TSB for it and had yet to contact me. I guess I'll bring it up in the next service so they have no choice.
  3. Sep 14, 2020 at 11:44 AM
    #43
    24-7
    24-7 Well-Known Member
    Phil
    Florida
    16 TRD OR 4Door 6MT
    Driver, KO2's, Open Y-Pipe
    Nice write up. About 4.5 years late for me.
  4. Sep 14, 2020 at 12:17 PM
    #44
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    2017 Inferno DCSB TRD OR 4x4
    Those are optional now?
  5. Sep 16, 2020 at 10:03 AM
    #45
    Lt. Dangle
    Ohio
    Always, always take a copy of the TSB in with you when you go for service. Saves you an extra step.
  6. Sep 16, 2020 at 1:04 PM
    #46
    RedWings44
    Michigan
    Yes, I will be making sure I print one off before I go!
    Lt. Dangle[QUOTED] likes this.
  7. Oct 8, 2020 at 5:47 PM
    #47
    Bigkracka
    Bigkracka Well-Known Member
    Tx
    20 Tacoma SR5 Crew Cab V6
    It's much easier to pull the trim and door seal up than spray water everywhere. It will be straight and you need to clean under the seal anyway.
  8. Oct 8, 2020 at 5:55 PM
    #48
    BayouinBham
    BayouinBham Well-Known Member
    Zach
    Alabaster, AL
    Installed these sill protectors from TuffSkinz.
  9. Nov 16, 2020 at 3:16 PM
    #49
    gregnauman
    gregnauman Well-Known Member
    Greg
    2020 Tacoma TRD Pro
    None
    Can you post up some pics of yours for factory location?
  10. Nov 16, 2020 at 3:45 PM
    #50
    Travis17
    Travis17 Well-Known Member
    Travis
    2017 Tacoma Limited
    I used a heat gun when I installed mine. This made bending the edge much easier, just use a medium temperature.
  11. Feb 1, 2021 at 2:23 PM
    #51
    Columbian Taco
    Columbian Taco Member
    Columbia
    2012 Tacoma 2wd Base 5Lug
    1" rear drop. Currently sits 34.5" in the front and 35.0" in the rear.
    Will the 3rd gen sill protector fit on a 2nd gen? I really like how it overlaps a little bit.
    TexasWhiteIce likes this.
  12. Feb 22, 2022 at 1:27 PM
    #52
    EmollientFoil
    EmollientFoil Well-Known Member
    '22 Army Green SR5 Trail Special Edition
    I know this thread is super old, but...just installed mine, anyone know what happens to the moisture trapped underneath the protectors? I used the wet method like OP, went on amazingly, no bubbles, got all the water/air out. However, there's got to be residual moisture under there. I am sure this is a normal and trusted decal application method, I see it all the time for PPF etc. But for all those categories, where does the water go? Not big pockets but like the really small residual amount?
  13. Feb 25, 2022 at 7:36 AM
    #53
    Columbian Taco
    Columbia
    I did install the 3rd gen sill protector on my 2nd gen and it fits great. The overlap actually protects even better than the old 2nd gen protectors.
  14. Nov 17, 2022 at 2:55 PM
    #54
    AZaco
    AZaco New Member
    CT, would you kindly measure the front and rear sizes of protectors and let me know what those numbers are ...many thanks
