3rd Gen Driver's Seat Front Garnish
Discussion in '3rd Gen. Tacomas (2016-2023)' started by stftaco, Oct 16, 2023.
  1. Oct 16, 2023 at 9:59 AM
    stftaco
    stftaco [OP] Well-Known Member
    22 MGM DCSB Tacoma TRD Sport
    Somehow my driver's seat plastic garnish (at the front of the seat close to the back of the knees) is hanging low on the end closest to the shifter.
    Are there special clips or something that keep that garnish in place, tucked up against the seat and seat fabric?
    I can't see anything near there. I suppose I could take a look with a makeup mirror my wife uses (which I found was one of the only ways I could see the dang fuse holder under the driver's side dash).
    I suppose if I had to - I could try to remove the seat.
    I'm hoping someone else has been there, done that and so, thanks for any hints, tips, tricks on getting the garnish re-attached properly.
  2. Oct 16, 2023 at 11:09 AM
    Ryeguy
    Ryeguy Well-Known Member
    43* North
    2021 TRD Off Road 4X4 Blackout
    OEM Bed Extension, Bed Mat, Lomax Bed Cover, Auto lock tailgate (OEM)
    I’m not exactly certain of the seat component you are dealing with, but removing the seat from the vehicle is pretty simple. I pulled mine out to install my seat covers.
    I would remove the seat to get a better view and access to what you need to fix.
    stftaco[OP] likes this.
  3. Oct 16, 2023 at 12:39 PM
    stftaco
    Yep, things are always easier if you can SEE what you're dealing with and working on...
    Just can't seem to find the exploded view of the thing.
    Any tips for removing the seats? I know there are four bolts for mounting the seat in the vehicle, then there must be a wire harness to provide power to the seat positioner motors on the driver seat assembly, and another for activating the side impact air-bag for both front seats.
    I don't think I can get to the harnesses without being able to tilt the seat back (after removing the bolts). Is that about right?
  4. Oct 16, 2023 at 2:36 PM
    Ryeguy
    43* North
    I just noticed your truck is brand new. Maybe just take it to the dealer as a warranty repair?
    If you really want to go after the repair itself, I would disconnect the negative battery terminal prior to disconnecting the wiring harness under the seat.
    If you just unbolt the four mounting bolts, you can move the seat around quite a bit inside the truck without disconnecting or stressing the wiring harness.
  5. Oct 16, 2023 at 5:40 PM
    stftaco
    Yeah, it just sort of popped off. My wife is gonna freak when I take the door panels off to replace speakers, but if she sees me taking out the driver's seat, she might hit me over the head with a pan. :cheers:
    Ryeguy[QUOTED] likes this.
