3rd Gen E-locker: how does it work?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by pltommyo, May 4, 2021.
  1. May 4, 2021 at 1:52 PM
    pltommyo
    pltommyo [OP] Well-Known Member
    Tom
    2016 Gray Tacoma TRD Offroad
    SSO hybrid bumper, Warn winch, RCI skid trilogy, RRW sliders, everything in the cheap/free mods thread, and of course the frame recall work.
    I have seen a ton of videos, write-ups, and forum threads on how to fix the 2nd gen e-locker and see how easily it works. I can't seem to find anything that explains how the 3rd gen e-locker works. Mine is pretty much unusable, so I was hoping to find a "how to fix it" like I see for the 2nd gens. I have had mine locked in the "on" position after use, which is not a great feeling when you want to drive 100 miles home! It also pretty much refuses to go into lock, but after fiddling and rolling forward / backward and turning it might engage or disengage if it feels like it. I have tried to "use" it weekly but it never got any better and I was just more worried it was going to get stuck and keep me stuck in 4LO. Does anyone have any helpful links showing how the 3rd gen e-locker activates, or how to clean/repair it?
    claytaco1 likes this.
  2. May 4, 2021 at 1:55 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
  3. May 4, 2021 at 3:30 PM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
  4. May 4, 2021 at 5:11 PM
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
    https://www.tacomaworld.com/threads/stock-8-75-bd22an-locker-dissection.674592/
    http://www.ttguide.net/components-1291.html
    By chance you messed with it at all? It's a very simple mechanism with an internal solenoid that plunges a dog clutch into engagement when energized and uses a spring return to maintain the unlocked state. There's not much to fail or get dirty. What's your locking and unlocking technique? You need to drive a bit and turn the wheel when changing states to get the clutch aligned and not bound.
    SR-71A and BigWhiteTRD like this.
  5. May 4, 2021 at 5:34 PM
    BigWhiteTRD
    BigWhiteTRD Official thread killer (only crickets remain)
    Ted
    Treasure/Space Coast Florida
    2017 AC TRD OR Auto 4wd, 2012 AC SR5 4.0 MT 4wd
    When I want to be able to easily lock and unlock the rear (when testing), I do the following.
    Put truck in 4lo in neutral on flat ground (garage etc). CAREFULLY Jack just one rear wheel until it is off the ground and release the e-brake.
    Activate the locker and turn the lifted wheel gently by hand (if required) until it locks in. Deactivate the locker and turn the lifted wheel as necessary until it unlocks.
    I would try that and see if you can get it to repeatedly lock and unlock... I think you will probably find that you can get it to lock in and out easily (based on my experience). If not, further troubleshooting will be in order...
    pltommyo[OP], ShimStack and Kev250R like this.
  6. May 4, 2021 at 5:52 PM
    Harmon
    Harmon Well-Known Member
    Jacksonville
    2020 Tacoma SR V6 4X4
    265/75/16 BFG KO2's Front ARB Air Locker
    You do know that it only works in 4L right?
    I don't know why Toyota designed a locker that you can only use in 4L but they did. =(
    LeakyAC and pltommyo[OP] like this.
  7. May 4, 2021 at 6:04 PM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    KO-EO?
  8. May 4, 2021 at 6:07 PM
    ToyodaSun
    ToyodaSun Well-Known Member
    Parts Unknown
    17' DCLB TRD OR
    My best guess is so that people don't speed and roast the diff. My 2005 Tacoma was a 2wd Pre-Runner Off-Road and had the diff locker. :frusty:
  9. May 5, 2021 at 6:50 AM
    pltommyo
    Tom
    Thanks, all. Yes, I knew it must be 4LO. My process is to engage 4HI, drive a short distance to ensure solid engagement, stop, put in neutral, engage 4LO, put in drive and move forward a short distance to ensure engagement. Then put in neutral, engage locker, when light flashes, put in D and roll forward. It just stays flashing. I try weaving a bit to get the inner pins aligned. If by luck it does engage, I simply press the button to disengage and drive forward, weaving a bit. When that fails (most of the time) I try reverse since I know that should drive the balls backwards to their detents and that maybe works.
  10. May 5, 2021 at 8:31 AM
    ShimStack
    Ben
    NC
    Don't worry about shifting to N to engage the locker. That's just making things worse. It's fine to be driving forward when you engage and it helps (truck won't start the engagement process if you're over 5mph). Just don't be spinning tires. Drive slowly, press locker button, turn left or right until the light is solid. There are no balls, no pins, and no detents, this is not a Harrop, this is the 3rd gen e-locker. Look at the links above to see the hardware.
    When your 4WD, 4LO, and locker lights are solid they are engaged. No need to "drive forward to confirm".
    SR-71A, LeakyAC, BigWhiteTRD and 2 others like this.
  11. Feb 28, 2023 at 9:06 AM
    WarBeard_Actual
    WarBeard_Actual Well-Known Member
    Because it isn't designed to be used at speed. Your speed is very limited in 4L.
    LeakyAC likes this.
  12. Feb 28, 2023 at 9:20 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    what inspired you to reply to 2 YO thread and to a user that hasn't logged in here in 2 years
  13. Feb 28, 2023 at 9:26 AM
    WarBeard_Actual
    Was doing some googling on the electromechanical function of the locker in the tacoma, this thread came up, was skimming through it, saw some dumb shit, couldn't help myself.
  14. Feb 28, 2023 at 9:28 AM
    Toyko Joe
    Toyko Joe Here for the pictures
    :eek::rofl:
    LeakyAC likes this.
  15. Feb 28, 2023 at 10:02 AM
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    LOL, some "well known" TW users will resurrect old threads just to f with ppl and watch the fallout..
    gudujarlson and Chew[QUOTED] like this.
  16. Feb 28, 2023 at 10:05 AM
    Chew
    Chewy
    Midwest
    19 TRD OR
    I might just do that,,, shake things up, dig up ol bones and drag out skeletons
  17. Feb 28, 2023 at 9:41 PM
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
  18. Feb 28, 2023 at 9:49 PM
    mud
    mud Djentleman
    SoCal
    2019 TRD OR DCSB LMNOP QRS TUVWXYZ
    SR-71A likes this.
