3rd Gen ECT Power Button Question???
Discussion in '3rd Gen. Tacomas (2016-2023)' started by agjr200hp, Jun 15, 2016.
  1. Jun 16, 2016 at 6:42 AM
    99superduty
    99superduty Well-Known Member
    2016 DCSB OR 4x4 OME LIFT W/886 and DAKARS 265/75/16 Duratracs C4 lo pro bumper
    Doesn't own a '16, tries to tell us what the button does.......ignored.
  2. Jun 16, 2016 at 7:23 AM
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    you fail hard pal
    ect button does the same friggin thing is has done since toyota been putting them on vehicles
    plus the documentation for the aisin tranny indicates what it does
    I own two Toyotas that have ECT buttons. derp
  3. Jun 16, 2016 at 9:07 AM
    DRJ1014
    DRJ1014 Well-Known Member
    CA
    Its a poor mans SPORT button.
    KB Voodoo likes this.
  4. Jun 16, 2016 at 12:44 PM
    sethhawaii
    sethhawaii Well-Known Member
    2016 TRD offroad 4x4
    you dont mind it revving to 2500 in first gear?? or did it get more smoother shifting over time?
  5. Jun 16, 2016 at 1:32 PM
    txags92
    txags92 Well-Known Member
    2016 DCLB TRD OR 4x4 BBP
    One thing to keep in mind when comparing the button's function is that none of the previous versions cited are on engines that have Atkinson cycle capability. I think based on my experience that the ECT button does three things:
    1. Disables 6th gear. Makes sense as you aren't supposed to tow in overdrive.
    2. Changes throttle response...this cannot be argued...it does this. If you are arguing that it does not, you have not driven a 2016 with and without the ECT engaged. There is a definite lag in the first 1/2 to 1" of throttle that is not there when ECT is engaged.
    3. I THINK that it may disable the Atkinson cycle timing. The reason I think this is that if you are driving at or below about 2000 RPMs on relatively level ground, and engage the ECT, the RPMs of the engine will change (increase) without any change to the position of the throttle. I guess it could be just the throttle map changing where the engine runs at that throttle setting, but to me it would make sense to disable the Atkinson cycle at lower RPMs under ECT since it is designed to produce better MPG, but not necessarily better power at lower RPM.
  6. Jun 16, 2016 at 1:40 PM
    stan23
    stan23 Well-Known Member
    stan
    Santa Clara, CA
    2025 DCSB TRD Sport 4x4
    Not trying to argue with you, but go drive a 2016 AT tacoma and try for yourself what ECT on/off does. The higher shift points is not the only thing that has been changed. the throttle response is significantly different.
    Herniator and txags92 like this.
