3rd gen engine skip
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Panda2, Jan 27, 2020.
  1. Jan 27, 2020 at 7:40 PM
    Panda2
    Panda2 [OP] Well-Known Member
    2019 Silver Tacoma TRD Off-Road 4DSB
    I have a 2019 TRD OR. It’s a 6sp. Whenever the engine is forced to work a bit, like trying to hold cruise control at 70mph up a rise in the highway, there is a definite feeling the engine is skipping or varying power output or sputtering - however you want to visualize it. I can buy non-ethanol gas and it will ALMOST go away, but really just disguises the issue. I’m so frustrated with this. Of course the dealer thinks I’m nuts and calling Toyota does nothing. The problem is real. Any suggestions? Thank you.
    davidstacoma likes this.
  2. Jan 27, 2020 at 7:44 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    I'll be 80-85 on cruise up a hill and it'll skip / miss. I just let the engine eat, 5500 rpm and all. No idea if it's normal but it doesn't bother me much
    Junkhead likes this.
  3. Jan 27, 2020 at 7:52 PM
    Panda2
    Man...it bothers the heck out of me. If this truck was 4K not 40k I’d be less bothered!
    Doobfucious likes this.
  4. Jan 27, 2020 at 7:55 PM
    MDFM31
    MDFM31 Well-Known Member
    Chester Co, PA
    16 DCSBOR
    @OVTune found that these engines are allowed a ton of pre-detonation under the factory PCM parameters. The info is somewhere in the 2700 page thread about the tune, or check his website blog, which is very informative.
  5. Jan 27, 2020 at 7:55 PM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Meh, it's just a quirk of this engine. There's people that have 200k in this engine already. Also, if u hit quote on the bottom right of my reply, it'll reply directly to me and tag me.
  6. Jan 27, 2020 at 7:58 PM
    Panda2
    Got it! Thank you.
    Skydvrr[QUOTED] likes this.
  7. Jan 27, 2020 at 7:59 PM
    Ronzio
    Ronzio Well-Known Member
    Pennsylvania
    17 DCSB TRDOR
    Yeah if your cruising around at 2 grand under load it’ll fish bite...
    nphagert and Skydvrr like this.
  8. Jan 27, 2020 at 7:59 PM
    NYCTaco52
    NYCTaco52 Half man, half goat
    Somehow known as Stewart, but named Ben
    Ft Lauderdale, FL
    2022 Subaru Ascent
    Damn Camry engines :anonymous:
  9. Jan 27, 2020 at 8:02 PM
    Panda2
    Is there anything that can be done to fix this?
  10. Jan 27, 2020 at 8:04 PM
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    Have you tried different grades of gas, like mid grade, to see if it makes a difference?
  11. Jan 27, 2020 at 8:04 PM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    oVtune might help. It's an ECU tune for this engine. Go to the main 3rd gen forum then use search, tons of data so prepare for a read.
  12. Jan 27, 2020 at 8:06 PM
    Panda2
    Yes. I’ve tried all grades. The only significant difference is made with Ethanol Free, which is pricey and hard to find.
  13. Jan 27, 2020 at 8:09 PM
    2019tacosr5
    2019tacosr5 Well-Known Member
    Jacob
    2019 White Tacoma SR5 V6
    Just send it
  14. Jan 27, 2020 at 8:09 PM
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    Mine does this on 87, but goes away on 93. Sucks to hear you weren't as lucky.
    CB3TACO and davidstacoma like this.
  15. Jan 27, 2020 at 8:11 PM
    MDFM31
    Chester Co, PA
    16 DCSBOR
    OVtune. There is a thread just for the manual tune.
  16. Jan 27, 2020 at 8:18 PM
    Sergio W
    Sergio W Well-Known Member
    Sergio
    Lafayette CO
    2015 TRD PRO
    Does it happen whether or not you're using cruise control?
  17. Jan 27, 2020 at 8:44 PM
    StayinStock
    Bob
    Missouri
    Yes I do
    Some
    Maybe the Camry has a Tacoma motoro_O
  18. Jan 27, 2020 at 8:45 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Maybe they both have a Lexus Motor?
  19. Jan 27, 2020 at 8:46 PM
    StayinStock
    Bob
    Missouri
    Yes I do
    Some
  20. Jan 27, 2020 at 8:58 PM
    troutspinner
    troutspinner Fishing Addict
    Gilbertsville, Pa
    2020 Magnetic Gray Limited
    Could this just be a symptom of switching between Atkinson and Otto mode?
    Coming from non-Toyota and now to this 2020 Tacoma you can definitely feel the different modes the engine has.
    Doobfucious and Chew like this.
