3rd gen engine skip
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Panda2, Jan 27, 2020.
  1. Jan 30, 2020 at 7:19 AM
    #61
    Gvsukids
    Gvsukids Well-Known Member
    Justin
    Grand Rapids
    Would regearing help?
  2. Jan 30, 2020 at 7:42 AM
    #62
    KVTaco
    KVTaco Well-Known Member
    Yes it is a feature and I don't like it but gotta live with it unless you change driving habits to always be at higher revs.
  3. Jan 30, 2020 at 7:49 AM
    #63
    Superhulk LB
    Superhulk LB Well-Known Member
    Josh
    Oregon
    2019 superwhite DCLB off road
    Tonneau cover, Black exhaust tip, blacked out badges and tailgate lettering. Black rhino(glamis)18x9 wheels with +12 offset. LT265/70/18 Toyo Opencountry ATIII. Metaltech 4x4 rock sliders Cali Raised lower grill light bar/mounts TRD Pro Skid, DD Fogs(pro), Ironman 4x4 FC pro lift.
    Same thing happens to me with my automatic. Drives me crazy! I get everything thinks it’s supposed to be normal and just the design of the truck or that we all want to spend money to OV Tune it. But I’ve driven hundreds of vehicles and this is the worst I’ve experienced. The closest thing to it was a 90 Escort and I fixed that by replacing a fouled spark plug.
  4. Jan 30, 2020 at 10:54 AM
    #64
    CaptainBart45
    CaptainBart45 Well-Known Member
    Bart
    2017 Tacoma Sport 4x4
    Work in progress...
    Chew likes this.
  5. Jan 30, 2020 at 11:51 AM
    #65
    Syncros
    Syncros Well-Known Member
    Nature of the beast.
    Precisely why the 6AT trucks will downshift to 4th under the same conditions. The engine needs to run at a higher RPM to produce the power required to maintain the speed. What you're feeling with the manual in 6th gear is the engine lugging because it's under too much load and the computer is doing it's best to stop detonation from occuring.
    The way I understand it is higher grade & non-ethanol fuel helps as it reduces the pre-ignition when the engine is under load at low rpm.
    Chew likes this.
