3rd Gen Entune Radio Head Unit Comparison
Discussion in '3rd Gen. Tacomas (2016-2023)' started by IcemanPNW, Aug 27, 2020.
  1. Sep 26, 2024 at 9:50 AM
    #121
    beef ranger
    beef ranger Well-Known Member
    19 OR 4WD 6MT DCSB CEMENT
    Why not just go aftermarket?
    other solution is to just mount your phone next to the head unit. I stuck a mount on right above the hazard lights switch
  2. Oct 31, 2024 at 5:54 PM
    #122
    TacoFez
    TacoFez Active Member
    Garden Grove, CA
    2017 Tacoma TRD Pro
    Has anybody figured out a workaround to match up the dash display with the headunit? Minor issue, but I would like to get back to the blue dash display without having a bright white head unit... 3rd world problems...
  3. Oct 31, 2024 at 6:05 PM
    #123
    IcemanPNW
    IcemanPNW [OP] Well-Known Member
    M. E.
    3rd Gen TRD Off Road
    Nope, have tried, don’t think it exists. I just go with red.
  4. Nov 28, 2024 at 6:41 PM
    #124
    Derk33
    Derk33 Well-Known Member
    Derek
    Pennylvania
    22 Army green TRD OR
    Is the DCM only offered in the entune 3.0 premium or can the plus and basic run it too?
  5. Jan 7, 2025 at 10:39 AM
    #125
    OJ_
    OJ_ New Member
    2019 Quicksand SR5
    Hi, I'm new to the forum and have been looking at pulling out my old Entune 2.0 Base non-navigation, non-JBL head unit and putting in an Entune 3.0 with CarPlay. After reading through this thread and looking around, I've narrowed down my options to either the Entune 3.0 Base 7" (86140-04110) or the Entune 3.0 Plus 8" (86140-04230). I've read however, that putting in the 8" version might cause fitment issues with the trim piece around the head unit. Does anybody know if I can put in the 8" unit and have it fit or am I limited to the 7" unit. Ideally, I would like to have the larger screen.
  6. Jan 7, 2025 at 12:00 PM
    #126
    kbUSMC2012
    kbUSMC2012 Well-Known Member
    Kevin
    2019 TRD Off Road 4x4
    I’m not aware of any fitment issues between 7” and 8”. My understanding is that the dimensions of the head unit are the same, it’s just the screen size within the head unit that is different.
    For reference, I installed an 8” entune 3.0 system in my 2019 TRD Off Road with no fitment issues.
    With you coming from an SR5, if you have the lower end head unit (with the volume knobs on top), you will need a new trim piece to accommodate the larger head unit.
  7. Jan 7, 2025 at 8:09 PM
    #127
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    SR5 HU bezel is different size vs TRD trims.
    Back in the time, TRD bezel was $400.
  8. Jan 16, 2025 at 6:37 AM
    #128
    TacoRayPNW
    TacoRayPNW Active Member
    2018 TRD OF LB Quicksand
    I am looking into upgrading my 2018 TRD OF to the entune 3.0. I just want the apple car play functionality in an OEM HU. I don't have the JBL but I do have the NAV in my 2.0 Does anybody know what 3.0 HU I would need to keep all the functionality I already have (Nav, USB, AUX, steering controls, etc.)?
  9. Jan 16, 2025 at 8:35 AM
    #129
    Captbrad88
    Captbrad88 Well-Known Member
    Brad
    2018 Tacoma trd offroad
    Any as long as it doesn’t have JBL. Get a 3.0 base or premium just as long as it’s not a JBL version. Then you have to get the harness, but you will retain pretty much everything. Depending on premium/base radio you could loose some functions like nav and that nav screen/compass on dash but nothing you can’t live without. All steering wheel features work and if you get the base not having nav isn’t life ending because with CarPlay you more than likely using apple maps or google anyways. Just watch out for the candaian one, it comes in KM default and ALWAYS defaults back, (refer to first page for numbers)
    TacoRayPNW[QUOTED] likes this.
  10. Jan 16, 2025 at 9:56 AM
    #130
    TacoRayPNW
    Thanks for the info!
    Would the 3.0 premium work if I got the OEM+ audio upgrade? or would I have to have the JBL for that?
  11. Jan 16, 2025 at 11:04 AM
    #131
    Captbrad88
    Brad
    I am not 100% sure how that systems would work with the 3.0 if you got it for the 2.0 but I’d assume it just uses the factory connectors with some inline harnesses, I’d say you could probably double harness up and be ok but again I never seen how the system plugs up to the 2.0.
  12. Jan 26, 2025 at 5:12 AM
    #132
    Gouda
    Gouda Member
    I just switched to the “entune 3.0 plus” (86140-04230) and lost factory NAV (as expected) and also lost the screen on the instrument cluster that would show the compass and speed limit, which makes sense. Apple and Google maps both show these so I’ll just have to get used to looking in a different spot. Can’t confirm the “premium” units would keep both of these, but just sharing what I now know.
    Everything else still seems to work fine and the 8” screen is a nice upgrade from the old 7” one, though the resolution could be improved.
    Solid upgrade for less than $600 with the harness.
    Michaeltx8908 likes this.
  13. Feb 19, 2025 at 2:56 PM
    #133
    cedy01
    cedy01 Active Member
    Cedric
    Vancouver
    2016 Black Tacoma TRD Sport
    3" bilstein lift 33" tires SCS rims off-road lights TRD pro grille & amber lights cali raised rock slider +more to come
    Has anybody been able to make an entune 3 head unit work with the older entune 2 navigation box? I saw that you could buy a navigation box and cables to add navigation for the entune 3 system so was curious if you could retrofit the older box to the new unit as well
    My entune 3 hasn’t been charging my phone or connecting to CarPlay recently and it sucks not having navigation even if it is slightly outdated
  14. Feb 19, 2025 at 2:58 PM
    #134
    kbUSMC2012
    Kevin
    I’m unsure that that would work. The UI is completely different between the two and I doubt the new head unit would have been designed for interoperability with the old navigation unit.
  15. Apr 20, 2025 at 3:15 PM
    #135
    Michaeltx8908
    Michaeltx8908 New Member
    Michael
    2016 White Tacoma TRD Off-Road
    I was thinking of getting the 86140-04230 like you, but you mentioned losing the speed limit in the instrument cluster? Just to clarify, you clearly said "speed limit" as in the current road's max speed limit is lost on the instrument cluster, right? Sorry, i just need to hear it because I really wouldn't want to lose the digital speedometer.
  16. May 4, 2025 at 8:21 AM
    #136
    JayBaksy
    JayBaksy Member
    Jay
    ID
    19 Tacoma TRD Pro
    I have been scrubbing this thread and others for a couple days now trying to come up with a parts list of what I need. Anyone that can confirm I’m on the right track or correct me please help! I have a 19 TRD Pro with JBL 2.0. Since it’s JBL I’m assuming I’m going to need the JBL Entune 3.0 to retrofit. I’ve also seen that I possibly need the corresponding amp part number that goes with the new 3.0 HU. Can anyone confirm that? I don’t need any of the Entune suite of apps I’m only after car play compatibility and retaining the OEM look and equally important the OEM sound I.E. I don’t want loss of bass or sound quality. Is it possible to run the lower tier 3.0 HU with my current JBL amp or am I stuck having to find the JBL 3.0 HU and Amp that goes with the 3.0 HU.
