3rd Gen: Flash to Pass and Low Beams
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Ted Steel, Dec 5, 2020.
  1. Dec 5, 2020 at 7:01 AM
    Ted Steel
    Ted Steel [OP] Well-Known Member
    Ted
    NC
    2018 Cav Blue Pro 6MT, 2014 Baja (sold)
    Hey all. I have a 2018 TRD Pro that I bought 2nd hand a year ago. With the headlight switch OFF, when I used flash-to-pass by pulling the headlight stalk backwards/towards driver, both the high beams (good!) AND the low beams (bad) come on at the same time.
    Anyone else experience this? I'm wondering if there is something amiss with my truck. Can the lights behavior be coded that way?
    I'm running Xenon Depot Philips HIDs in the low beams (thanks @crashnburn80!!) and my issue is, cycling the ballast on/off/on/off is not good for aftermarket HIDs. I would MUCH prefer just the high beams come on rather than both the high and low beams. I have evidence of an aftermarket alarm system in the truck that despite my best digging before buying the truck, I didn't realize until months after I bought the truck...
  2. Dec 5, 2020 at 7:04 AM
    Ted Steel
    Ted
    NC
    One other thing. Here is a snapshot from the Owners Manual. If I'm interpreting this correctly, I would think ONLY the high beams come on when using flash to pass:
  3. Dec 5, 2020 at 8:29 AM
    caribe makaira
    Caribbean, Puerto Rico
    Did you install & wired them? Show the wire taps to the vehicle from the HID's.
  4. Dec 5, 2020 at 8:39 AM
    avi8or_co
    avi8or_co Well-Known Member
    2019 Cavalry Blue TRD Sport, 2023 Lexus IS500
    I get both high and low as well with the switch in off or with the drls on. Light wiring and anything connected to them are completely stock, only modification are more powerful bulbs.
  5. Dec 5, 2020 at 8:48 AM
    Tullie D
    Tullie D Well-Known Member
    Tullie
    Wilson, NC
    2019 SR5 V6 SSM Access Cab
    There's an easy solution: Don't use "flash-to-pass". It pisses people off anyway . . .
    Tnc, Mtn Mike, Spare Parts and 4 others like this.
  6. Dec 5, 2020 at 8:48 AM
    mutely
    mutely Well-Known Member
    TRD Pro in metallic primer
    Why is this bad? it’s the correct behavior and been this way on EVERY vehicle ive even owned that came with Halogen headlights. Light are off, both beams come on when you flash, lights are on, only high beams come on.
  7. Dec 5, 2020 at 11:42 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Even in a dual filament bulb like the 9003/H4 in 2nd Gen, both high and low are illuminated using the flash to pass feature. That is the designed behavior and unfortunately not one that is very friendly to aftermarket HIDs.
  8. Dec 5, 2020 at 11:48 AM
    caribe makaira
    Incorrect...
  9. Dec 5, 2020 at 11:53 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Is that for a 2nd Gen? I don’t have the truck anymore to verify but I’m almost certain they work that way.
  10. Dec 5, 2020 at 12:05 PM
    Ted Steel
    Ted
    NC
    Appreciate all the replies!
    Yeah, I installed the HIDs myself, but it worked this way even before I installed them.
    OK got it and good to know. I was worried that the remnants of an aftermarket alarm system was causing some kind of weird behavior. Reading manual, it only says it will turn the high beams on, but doesn't mention the low beams. It's worded poorly, IMHO.
    There are a multitude of situations in which you'd want to do this without pissing people off: Yielding the right of way to another motorist at a 4 way stop, signaling to a truck it's safe to come into or out of the hammer lane, to thank another motorist who yields in a situation they didn't need to, to alert a distracted driver you're to their left or right flank, to inform another driver that something is wrong with their vehicle, to alert a driver going 10-20mph under the speed limit on a country road (where I primarily drive) you are about to overtake them... I could keep going.
    Yeah, good question. Because aftermarket HID ballasts aren't designed to be quickly cycled on and off. This it the FIRST vehicle with separate high/low beams (i.e., dedicated bulbs and reflectors) where flash-to-pass turns on both high and low beams. It's not an issue for stock trucks with halogens, I'll give you that, but it would be nice if only the high beams came on when using flash and the headlights are off.
  11. Dec 5, 2020 at 12:05 PM
    caribe makaira
    Yes, 2nd Gen...
  12. Dec 5, 2020 at 12:07 PM
    Ted Steel
    Ted
    NC
    Yeah, same question as crash. Is that 3rd gen or 2nd gen?
    EDIT: You posted just as I did. 2nd gen. Ok thanks.
    Despite my avitar, I have a 3rd gen I'm questioning.
  13. Dec 5, 2020 at 12:09 PM
    mattleg
    mattleg Well-Known Member
    Kansas
    2020 OR DCSB AT 4WD
    3rd Gen Switch Logic Below
  14. Dec 5, 2020 at 12:16 PM
    Ted Steel
    Ted
    NC
    Reading this from my phone. If I'm looking at this correctly, the Low beam would NOT come on with Flash or does?
    Thank you for this.
  15. Dec 5, 2020 at 12:18 PM
    caribe makaira
    And I corrected the miss information...:burp:
    crashnburn80 likes this.
  16. Dec 6, 2020 at 6:35 AM
    Ted Steel
    Ted
    NC
    @mattleg and @caribe makaira thank you for posting these. Sitting in front on a computer this morning finally on a big monitor (rather than my phone) and I'm still not following this.
    How should I interpret that table you posted @mattleg? If I only look at the Dimmer Switch, what do EL, HU, HF and HL mean? I've searched all 11,292 pages of the shop manual I have and no where does it list these particular abbreviations. If I knew this, I'm quite certain I wouldn't have the rest of these questions...
    Also what are the lines and the circles meant to depict? In your diagram above, does the line in the "Low" position mean that only "EL" and "HL" are hot (where circles are shown) in that switch position? (my assumption is YES give the image I found below) Or is Low active in all 4 positions? It only has circles in EL & HL so it's slightly confusing. Flash, on the other hand, has the "line" through EL, HU and HF but a circle in all three.
    The truck does have auto-lights/Light Controlled Switch, but have it disabled (not in AUTO position).
    I found this on page 6,000-something, but nowhere can I found how to interpret what this is showing. The light control switch is easier to decipher, but the Dimmer Switch (the function I'm concerned with) I'm scratching my head on what EL, HL, HU and HF means...
  17. Dec 6, 2020 at 6:39 AM
    Ted Steel
    Ted
    NC
    A bit more... I also found the below, which tells me EL (and LFG, for fogs switch) appears to be a ground, but I still do not know what HL, HU and HF mean.
  18. Dec 6, 2020 at 6:44 AM
    caribe makaira
    HU-Headlights Upper
    HL-Headlights Lower
    HF=Headlights FLASH
    Even though they show a "separation" between Dimmer sw and Headlight sw, they are 2 in 1 switch.
    mattleg likes this.
  19. Dec 6, 2020 at 6:57 AM
    Ted Steel
    Ted
    NC
    You never fail! Thank you sir... Seems so straight forward now that I know that.
    So even though there is no circle on HL here, it does in fact trigger HL (low beams) when the switch is in Flash. Correct?
    I'm clearly not an electrical master, but if I were drawing this table, I wouldn't include the lines. Confusing for this plebian brain of mine.
    EDIT: thinking on this a bit more, seems like if they are reflecting HF as a separate function in here, that it could in theory trigger HF/Flash/High without triggers HL/Low. Perhaps in prior model years it did.
  20. Dec 6, 2020 at 7:14 AM
    mattleg
    Kansas
    2020 OR DCSB AT 4WD
    Note that the HL contact on that switch set has no connection to the module. The signal for low beam is from the other switch set with the H contact, for manual on. Auto of course can turn on the low beam as well based on the light sensor and internal logic of the module.
    I will check for sure, but my memory is high beam does not turn off the low beam, only the fogs.
