3rd gen flooded
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SoonToBeOn39s, Jul 25, 2022.
  1. Jul 25, 2022 at 6:31 AM
    Road_Warrior
    Road_Warrior There is nothing on my horizon except everything
    East Coast
    2021 Black SR5 4x4
    My SR5 does
  2. Jul 25, 2022 at 6:39 AM
    Borracho Loco
    Borracho Loco My truck identifies as a Prius.
    DFW, Texas
    2021 Voodoo Blue - Tacoma TRD Offroad DCSB
    Oh look, another mod....
    Good God man, you paint such a vivid picture with your words. (I'm jealous I didn't say something like this first)
    soundman98, Just1n, stftaco and 2 others like this.
  3. Jul 25, 2022 at 6:43 AM
    Squatting Pigeon
    Squatting Pigeon Remember, bird watching goes both ways. Moderator
    North Texas
    TRD OR 4R | GR Corolla
    It’s already been mentioned, but I’ll say it again. Change the fluid in both diffs. IIRC the front diff breather is on the drivers side firewall, and it was likely under water (or at least close) based on how you were perched in that big ole puddle.
    While you’re at it, do the rear diff breather mod to help with next time.
    Gen3TacomaOBX likes this.
  4. Jul 25, 2022 at 6:51 AM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Sorry this happened to you.
    Pull the carpet out and clean the floor pan. You can probably pressure wash the carpet once it is out. Pull the door panels off and clean in there as well.
    I believe there are some electrical connectors under the carpet, get them clean and dry before reassembly.
    As others said inspect/change any suspect lubricants.
  5. Jul 25, 2022 at 7:03 AM
    CrispyTacoLover
    CrispyTacoLover Well-Known Member
    2024 Tacoma and 4Runner Offroad Premium
    FOR SALE. Like new, low miles. :D
  6. Jul 25, 2022 at 7:09 AM
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    Fluids as mentioned, but just as important the electrical as @RustyGreen mentions... there are a number of harnesses underneath the vehicle, they should be okay, but I don't think Weatherpack is rated for IPX-7, so I'd pull them apart and give them a good WD-40ing. Make sure you disconnect and dry all the connectors under the carpet, and lower down in the cab. Spray with Deoxit or similar, and re-assemble. If you don't get that, you're going to have a really entertaining and colour dash display in something between a couple of months and a year or two!
    cgs2k2, Chew and RustyGreen[QUOTED] like this.
  7. Jul 25, 2022 at 8:37 AM
    Tcodyw88
    Tcodyw88 Well-Known Member
    Cody
    El Segundo, Ca.
    2020 TRD offroad
    @20tacosr5 I got stuck in a creek once for a few hours and water had gotten into the cab as well. I didn’t get any electrical damage all speakers and power seats and seat heaters are still fully functional.
    Remove the seats, remove the carpet kit, and remove the door panels let them all sit in the sun. Use a towel to wipe down any residual moisture in the cab as well as any hard water marks. I did two different things when I could ran a dehumidifier inside the cab to help pull excess moisture, and on hot days I cracked all the windows down 1” and let the truck sit in the sun.
    Just know you can’t cover the smell you have to remove all the moisture to get rid of the smell.
    note I had my 5.29 gears installed a few months after this and no water or rust was found in the diffs.
    mwb and Squirt like this.
  8. Jul 25, 2022 at 8:40 AM
    cgs2k2
    cgs2k2 old man
    as people mentioned - aside from some fluids make sure you check, dry, clean electrical connections under the seat and carpet and the door sill.
    otherwise - no big deal - have fun, learn a lesson
  9. Jul 25, 2022 at 8:52 AM
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    On my 2nd gen, I used to drive in the swamps, got stuck in deep water a couple of times. Most of the electric connections where under the seats, so if the water didn’t get that high, you should be fine.
  10. Jul 25, 2022 at 8:59 AM
    NACAircrew
    NACAircrew Well-Known Member
    My pronoun is Chaz
    TRD OR/4R Trail
    Raptor lights/Meso everything/Predator steps
    Mods: rear diff breather
    :burnrubber:
  11. Jul 25, 2022 at 9:14 AM
    SoonToBeOn39s
    SoonToBeOn39s [OP] Well-Known Member
    I finally got bigger tires 2020 Long Travel Tacoma 1997 MAGNUM
    Thank you guys for the suggestions. Ill definitely be doing a diff fluid change and pulling the floor mats and seats. Thanks!
  12. Jul 25, 2022 at 9:18 AM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    Regardless of the price tag, some people like to get out on adventures and enjoy using their vehicles…and sometimes shit happens.
  13. Jul 25, 2022 at 9:27 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    don't wait, you should already have that thing in a garage and tearing parts out, and tell those buddies of yours to bring some fans.
    soundman98 likes this.
  14. Jul 25, 2022 at 9:52 AM
    SoonToBeOn39s
    As of right now im tearing my interior apart
  15. Jul 25, 2022 at 10:00 AM
    #35
    bonifacio_629
    bonifacio_629 Well-Known Member
    Walther
    Virginia
    2018 Tacoma TRD Sport, 6MT 4x4 DCSB, Inferno
    Predator steps, TRD cat-back, lots of orange stickers.
    Someone tell him that $35k is just scratching the surface in boat land, unless of course we're talkin' jon boats, skiffs, and things that doesn't have engines. Lol.
    OP, 3rd that get a Servpro or if you're DIY, gut the interior promptly. I'm about to have to deal with this because of a leaky roof rack that I didn't know was even leaking, no visible water, foggy windows, etc but still mold on the carpet pad.
    SoonToBeOn39s[OP] likes this.
  16. Jul 25, 2022 at 10:07 AM
    #36
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    I did this once, immediately after I pulled the cab plugs, when I got home I removed the seats, shop-vac'ed about 5 gallons of water out of the carpet, cleaned the silt from the cab floor as best I could, used milk crates to prop up the carpet and put carpet dryer blower fans to blow air under the carpet and drove around for a month in summer with the windows down and the heat on and there was still condensation in the vapor barrier on the jute in the carpet two years later when I completely gutted the cab and did dynamat and the vinyl fleet vehicle carpet replacement and the humidity dropped noticeably.
    The humidity is going to be obnoxiously high in the cab until you totally replace the carpet too I'll bet.
    0/10 wouldn't do again and I only had 2" of standing water on the passenger side and was only stuck for about 10 minutes.
  17. Jul 25, 2022 at 10:12 AM
    #37
    Arries289
    Arries289 Yo!
    Franklin TN
    2018 TRDOR DCSB BBP 6MT Tech & Prem
    Glad it is working fine now, but I would really like to hear from you in 2 months when the corrosion kicks in to full gear on the wiring connectors and modules.
  18. Jul 25, 2022 at 10:18 AM
    #38
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    for your next lake crossing...
  19. Jul 25, 2022 at 10:42 AM
    #39
    Kernel Panic
    Kernel Panic Member
    2020 Tacoma TRD 4x4 Off-Road
    Quick question for a noob here: I see many people suggestion the check/replace of the diff fluids, I was just wondering why? I'm 100% not questioning the validity of the advise, but just wondering what water does to the diff fluid/parts. Again, super auto noob here lol
  20. Jul 25, 2022 at 10:42 AM
    #40
    Xtremsiege2
    Xtremsiege2 Well-Known Member
    Norwalk CT
    21' LR Pro. Lots of fast bikes
    Are they not all currently on high school summer break here? I did something similar when i was a senior getting an old jeep XJ stuck in a swamp for 3 days. However it was a $500 jeep and mostly just mud.
    saltybum likes this.
