3rd gen front driveshaft rebuild or replace
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BigAirGar, Oct 19, 2023.
  1. Oct 19, 2023 at 8:11 AM
    BigAirGar
    BigAirGar [OP] Well-Known Member
    Ont Canada
    2016 TRD Sport DCLB AT
    Liv Free Rock Hrd
    Looking for advice on front driveshaft rebuild or replace ? I have a groan under acceleration when 4H engaged and suspect a seized u-joint on front shaft.
    Last spring I replaced both front half shafts (aftermarket) and did the Yukon bushing at same time because it was more time and cost effective that way...only needed boots!
    TIA Gar
  2. Oct 19, 2023 at 8:46 AM
    Buttskevin21
    Buttskevin21 Well-Known Member
    Kevin
    Washington
    2019 Brocoma, 37s, Lt, Dual Tcases, blah blah blah https://www.instagram.com/kevinjbutts/
    Stock-ish
    I'd just give it a shake to see if its a ujoint or the slip section. It should be a ujoint, which the avarage joe could possibly do or its easy for a local driveline shop to do.
    fourfourone likes this.
  3. Oct 19, 2023 at 12:45 PM
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    you joints are relatively easy change, doesn’t make much sense to replace an entire driveshaft just for your joints. It’s also rather costly
