3rd Gen Front License Plate
Discussion in '3rd Gen. Tacomas (2016-2023)' started by gators22, Oct 26, 2022.
  1. Oct 28, 2022 at 10:04 AM
    #41
    bonifacio_629
    bonifacio_629 Well-Known Member
    Walther
    Virginia
    2018 Tacoma TRD Sport, 6MT 4x4 DCSB, Inferno
    Predator steps, TRD cat-back, lots of orange stickers.
    8 out of 10 for me get CONFUSED and POSSIBLY ANGERY
  2. Oct 28, 2022 at 10:11 AM
    #42
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I miss PA inspections for stuff like that, and checking tire wear. WA has nothing, ever.
  3. Oct 28, 2022 at 10:15 AM
    #43
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Peeps don't care. I've seen both: them just staring blankly at me or just looking down at their phone.
    The dolts running with just DRLs on at night are hopeless. About the best that can be done there is flashing the HBs as fast a possible from behind. LoL!
    Yeah every once in a while, we'll get whiners here wanting backlit gauges when the lights are off. :rolleyes: I've only seen one Taco driving at night with no lights, which is hitting way, way above the average.
  4. Oct 28, 2022 at 11:33 AM
    #44
    Arcticdc5
    Arcticdc5 Well-Known Member
    My 20 yr old Acura with aftermarket HIDs goes through inspection with flying colors after he asks which parts I've replaced since my last visit (in this case it was front lower ball joints and rotors/calipers) and of course the 360 degree light inspection, horn, tire tread, parking brake test, etc. Of course being a car helps with lower beam pattern, but in a SUV/truck makes it worse.
  5. Oct 28, 2022 at 11:38 AM
    #45
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I sort of remember older Acuras had projector low beams? If so, those retrofits are good in my book. Hell, today's LED arrays put out way more glare than OG projectors.
  6. Oct 28, 2022 at 12:25 PM
    #46
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    Are LED bulbs in turn signal or brake housings allowed? If not, that kind of sucks. I agree on that rule for headlights.
  7. Oct 28, 2022 at 12:34 PM
    #47
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
    Front license plate? Never heard of her. #azftw
    tonered likes this.
  8. Oct 28, 2022 at 7:39 PM
    #48
    BLtheP
    Plano, TX
    The DRL at night folk are indeed fully hopeless and clueless. To date I don’t think a single one I’ve flashed at has realized and fixed it.
    As for the backlit dash, it’s funny you mention that. You’d think it would cause confusion, and clearly it does, but it shouldn’t. They make the dash super bright for daytime (when exterior lights are not on). They are bright enough to be painfully bright at night. How people can sit there and drive down the road with the dash lights that bright and not realizing something is wrong, is beyond me. For someone who isn’t clueless, the bright ass dash should be plenty of indication that the headlights aren’t on. Once you turn the lights on it drops to a far more tolerable level.
    scouterjan likes this.
  9. Oct 28, 2022 at 7:45 PM
    #49
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I've actually heard that folks have argued with cops believing that their lights were on. :rolleyes:
    You'd think that the extra brightness would be an easy clue, but I am also surprised by the number of folks that crank the brightness to max, effectively killing night vision.
    In the end, driving skills and actual care is non-existent for most.
    BLtheP[QUOTED] likes this.
  10. Oct 28, 2022 at 7:50 PM
    #50
    BLtheP
    Plano, TX
    Yeah, and I’m sure if they did do a fully backlit Tacoma dash, we’d just start seeing more of them in the same situation. People are idiots, in general.
    I’m one of the ones who turns the dash lights basically as low as they’ll go. I already don’t like the blue color, but in general with any dash color I want it about as dark as it can get without being off.
    tonered[QUOTED] likes this.
  11. Oct 28, 2022 at 7:53 PM
    #51
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Same. Minimum is good for me.
  12. Oct 28, 2022 at 8:12 PM
    #52
    scouterjan
    scouterjan Well-Known Member
    Jan
    22 TRD OR AC in good old white
    Front plates are required here in BC but half the vehicles here are from Alberta and they are not required to use front plate, kind of sucks
  13. Oct 28, 2022 at 8:16 PM
    #53
    DuffyBank
    DuffyBank Well-Known Member
    Big Country Customs, Abbotsford BC makes a flip up front.InkedIMG_20220325_065806_LI.jpg
  14. Oct 30, 2022 at 6:26 PM
    #54
    bonifacio_629
    Walther
    Virginia
    Oh yeah. I've had LED bulbs and MESO Total Tails since it was new. SOME inspectors let you get away with throwing LEDs into the Tacoma projectors, some will fail it. Best bet is to just swap the halogens back in.
    It used to be tougher. When I moved here a few years ago you had to remove or place covers on any off-road lights or light bars. Now, you can have them as long as they aren't wired in with the regular headlights.
