3rd gen fuel pump wire location for kill switch?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ConnorB14, May 12, 2025.
  1. May 12, 2025 at 7:42 AM
    ConnorB14
    ConnorB14 [OP] Member
    I’ve seen a couple forums for 1st and 2nd gen kill switch set ups and only 1 for the 3rd gen that only shows fuel pump wires along the frame rail, I was hoping to find a fuel pump wire location under the hood or in the cabin where I could easily just splice into and put a kill switch inside the cabin, does anyone have any experience doing this on a 3rd gen?
  2. May 12, 2025 at 11:18 AM
    nds0000
    nds0000 Well-Known Member
  3. May 12, 2025 at 12:11 PM
    ConnorB14
    That just looks like it just replaced the fuel pump relay and has a ground the rest is just wiring it to where I want to go right?
  4. May 12, 2025 at 12:15 PM
    airforceb2cc
    airforceb2cc Well-Known Member
    Don
    KCMO
    2021 DCSB Nightshade
    Ironman FCP; 315/75R16; KDMAX; Skids; Sliders
    Why not just tap the IGN1 circuit and put a kill switch on that?
  5. May 12, 2025 at 12:22 PM
    nds0000
    Btw, I would not use a fuel pump relay. It dies on the way you could get suck in the middle of nowhere. Take the starter relay instead.
    Jakerou likes this.
  6. May 12, 2025 at 12:52 PM
    ConnorB14
    Because I have no idea what that is, I’m very very very rookie when it comes to electrics I know how to do basic stuff and that’s it, if you could educate me that’d be great!
  7. May 12, 2025 at 12:53 PM
    ConnorB14
    How does it die? Does it just draw power all the time?
    GTGallop likes this.
  8. May 12, 2025 at 1:21 PM
    airforceb2cc
    Don
    KCMO
    Then honestly I would take the truck somewhere to get a kill switch installed. Cutting wires on a factory loom is very risky if you aren't confident. Installing a stereo and ditch lights is one thing...cutting a factory harness and adding resistance to a sensitive circuit is another.
    MagicToolbox and BabyBilly like this.
  9. May 12, 2025 at 2:10 PM
    ConnorB14
    You think so? It’s just hard cuz there are 0 mechanics I trust in my area, I’ve been to atleast 6 shops in my area that either tried to charge me way more than what it’s worth, done terrible work, or have had my vehicle for literally months
  10. May 12, 2025 at 2:17 PM
    airforceb2cc
    Don
    KCMO
    Yes I do. I would invest in a club and a couple strategically placed air tags instead. Kill switches are usually easier to defeat if the thief knows anything about electronics. It will slow them down...sure...but so does a club and an alert on their phone that there is an air tag following them. They will usually ditch the truck instead of searching for the tag(s).
    BillF1564 likes this.
  11. May 12, 2025 at 6:13 PM
    ConnorB14
    I agree I’ve just seen so many instances of peoples trucks being stolen then wrecked and I can’t bear that loss this truck means too much to me
  12. May 12, 2025 at 9:23 PM
    Canadian Caber
    Canadian Caber R.I.P Layne Staley 67-2002
    Les
    B.C. Canada, eh
    2020 TRD Sport DCLB 4X4 Super White
  13. May 12, 2025 at 9:30 PM
    Bishop84
    Bishop84 Well-Known Member
  14. May 12, 2025 at 9:42 PM
    Canadian Caber
    Les
    B.C. Canada, eh
    Very easy to do with the fob. Press and hold lock and then press unlock twice. Blinks twice, it’s then shut off. No annoying faraday case to handle. It works for me and my wife. As per usual, if they really want it they will get it. Just want to slow them down or hopefully they move on. Sucks having an emotional attachment to a vehicle. :rofl:
    dirt clod, #4TOY4ME, helix66 and 2 others like this.
  15. May 13, 2025 at 4:57 AM
    ConnorB14
    my fob is a key that unfortunately doesn’t work I have to put the key in the door to open my truck everytime , but I wanted something more convenient like the kill switch the club seems pretty annoying to deal with and not that effective
  16. May 13, 2025 at 9:33 AM
    helix66
    helix66 Well-Known Member
    DPRC
    2017 DclB TRDor MgM
    ProGrille,MesoStuff,Tinted,AllPro sliders, RCI ALL skids, BAMF diff skid, KDmaxPro tune, Demello bumper, Warn evo10s, BD s8 & squadrons, Accutune UCAs, Fox 2.5pes, Eibach & Deaver
    I do the same with the fob pretty much most of the time but I wonder if they can catch the codes at that moment too.
    There’s times I felt paranoid and used the key to lock/unlock it.
    It’s funny because I mentioned a kii switch and people using jammer/readers a while ago and somome said that’s not a thing…..at least in SoCal it is.
    I remember when the club came out, it was a joke and easily defeated, funny to see it back.
    I was considering a kill switch too, might still try it, AirTag sounds like an idea too if you silence it. Never tried one.
  17. May 13, 2025 at 9:58 AM
    nds0000
    Not cutting wires with the 41.22! You replace the starter relay - be sure to use the correct one! The 2023 TRD OR needs the reverse relay. Then run the cables through the engine bay and attach the ground to a solid ground. That's it! No cutting no wires!
  18. May 13, 2025 at 10:01 AM
    nds0000
    Nothing is perfect - not even relays... They may brake also. Seldom but would you chance your luck in a rainy crappy day?
  19. May 13, 2025 at 10:02 AM
    ConnorB14
    I didn’t know you could silence AirTags?
  20. May 13, 2025 at 10:02 AM
    ConnorB14
    Good point
