3rd Gen Gas Door
Discussion in '3rd Gen. Tacomas (2016-2023)' started by hiPSI, Feb 15, 2023.
  1. Feb 15, 2023 at 4:35 PM
    hiPSI
    hiPSI [OP] Laminar Flow
    South Carolina
    2024 Long Tundra
    I try to remember to write this ever time I grease the door but I always forget. Every 3-4 months I take a can of white Lithium Grease and put a little dab on each hinge point.
    After working it back and forth a dozen times it closes like butter.
    How to tell if the gas door needs lubricated? Open it fully,
    Try to easily flick it closed with one finger. It should fully close and latch with one easy flick.
    If it doesn't, it needs lubricated.
    There.
  2. Feb 15, 2023 at 4:48 PM
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    Good reminder ^^^ I almost had to buy a new fuel door last week due to corrosion, thought the hinge was shot. Dealer was going to charge $65 for the door and $10 for the rivets, plus I would’ve had to paint it to match, probably another $25 if DIY. Thankfully, I was able to resurrect the original door with some lube …good to go now.
    Tacospike and Junkhead like this.
  3. Feb 15, 2023 at 4:50 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    Haven’t greased my gas door in almost 5 years.
    :annoyed:
    burnttaco7, Malvolio, INSAYN and 3 others like this.
  4. Feb 15, 2023 at 4:51 PM
    hiPSI
    South Carolina
    2024 Long Tundra
    You won't have to if you can easily flick it closed....
    Junkhead[QUOTED] and Tacospike like this.
  5. Feb 15, 2023 at 4:52 PM
    Tacospike
    Two Trucks
    Idk. 7 years and mine still works like day one
    gatriguy, hiPSI[OP] and Junkhead like this.
  6. Feb 15, 2023 at 5:01 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    I’ll perform that test on Friday and report back.
    hiPSI[QUOTED][OP] and Tacospike like this.
  7. Feb 15, 2023 at 5:01 PM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Place this one in the "Am I over thinking this" file! :D
    hiPSI[OP] likes this.
  8. Feb 15, 2023 at 5:04 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    I've honestly never noticed the difficulty of any of my doors or hatches. Probably because Im in the habit mule kicking my gas door shut. It really is the best way to close a gas door.
    One of these days, Charisse, the third shift cashier at the Diamond Shamrock, is going to notice my kicks. I can be as much a protector as your bulletproof lexan cubicle, Charisse. You'll see.
  9. Feb 15, 2023 at 5:13 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Same. I even blast the inside real quick with the pressure washer when I wash it.
  10. Feb 15, 2023 at 5:30 PM
    Tacospike
    Two Trucks
    Semi off topic question:
    Your pressure washer clean up a 20+ year old driveway top ~ concrete.
    just tree residue for me
  11. Feb 15, 2023 at 5:46 PM
    hiPSI
    South Carolina
    2024 Long Tundra
    I do it because my last Tacoma door almost bit the dust until I babied it with wd40 and eventually got it moving freely. This time? One minute every several months to keep it problem free.
    Have you guys not seen the multitude of posts on these things?
    Skydvrr, blu92in99 and Lt. Dangle like this.
  12. Feb 15, 2023 at 6:00 PM
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    All I will say is for all the people poo pooing this, it only takes once to mess up your door. And then every time you look in the drivers mirror, it will remind you that you thought it was no big deal.
    Trust me, it is easier to just spray it once in a while and move on with your life.
    /wonky gas door crew member
  13. Feb 15, 2023 at 6:16 PM
    maxmk8
    maxmk8 Well-Known Member
    2022 Electric Lime M/T Taco
    Inside of the gas tank?
  14. Feb 15, 2023 at 6:18 PM
    JTScribe52
    JTScribe52 Well-Known Member
    Dan
    2018 SR5
    Top and bottom of each section, or just the top and let it work its way down?
    hiPSI[QUOTED][OP] likes this.
  15. Feb 15, 2023 at 6:24 PM
    hiPSI
    South Carolina
    2024 Long Tundra
    A dab on top and bottom. White Lithium does not run much. It is made to stay in place in outdoor environment for awhile.
    JTScribe52[QUOTED] likes this.
  16. Feb 15, 2023 at 6:29 PM
    splitbolt
    NW Arkansas
    Yes, it does.
    I have to keep on it, otherwise I get black mold near the garage. It's a northern exposure and doesn't get any sun there.
    Tacospike[QUOTED] likes this.
  17. Feb 15, 2023 at 6:56 PM
    Buck Henry
    I get it and I do it too. But probably just once or twice a year for me and it don't take much.
    Junkhead, hiPSI[OP] and Tacospike like this.
  18. Feb 15, 2023 at 7:04 PM
    Kelvin
    Kelvin Wheeeeee
    16’ GX460 with some junk bolted on
    Yes. 9/10 Toyota techs don’t want you to know that’s the original and best fuel system cleaner.
  19. Feb 15, 2023 at 7:12 PM
    splitbolt
    NW Arkansas
    o_O
    No. I open the fuel door and spray the inside of the door, hinge area and plastic area below the fuel cap.
    Junkhead likes this.
  20. Feb 15, 2023 at 7:27 PM
    splitbolt
    NW Arkansas
    Okay, I just sprayed it with white lithium spray; absolutely no change in how it feels or closes. The clip on the door does not overcome the friction on the plastic pin with "one easy flick".
    IIRC, this maintenance idea came about as a solution for mangled doors hinges, right? I think some people are just extraordinarily clumsy & careless with the door. :notsure:
    Junkhead, hiPSI[OP] and Skydvrr like this.
