3rd Gen Gas Mileage
Discussion in '3rd Gen. Tacomas (2016-2023)' started by arthur106, Mar 10, 2022.
  1. Mar 29, 2022 at 4:54 AM
    #61
    codyjphoto
    codyjphoto Well-Known Member
    Cody
    2015 gx460
    A bunch of junk
    Loaded down like this, I average 16 to 19 mpg. Rtt, usually 10 gallons onboard water, fridge, etc etc. 20220327_073301.jpg
    I'm leaving my mamba rtt on full time now because it's a bitch to remove. But we camp once a month anyway.
    NMBruce likes this.
  2. Mar 29, 2022 at 5:19 AM
    #62
    KauaiTimez
    KauaiTimez Member
    where do you guys live that have 80mph speed limits? Highest we have is 55; and they’re strict. Got a ticket for going 62 on our “highway” last week.
  3. Mar 29, 2022 at 5:19 AM
    #63
    Tacospike
    Two Trucks
    Toll roads ~ TX
  4. Mar 29, 2022 at 5:20 AM
    #64
    skeletron
    skeletron Disgraced Member
    Clark
    Sakerlina
    2020 TRD Broh
    Idaho, Montana, Nevada, Oklahoma, South Dakota, Texas, Utah, and Wyoming
    mic_sierra and Tacospike like this.
  5. Mar 29, 2022 at 5:20 AM
    #65
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Same.
    I'll add my data points: 11.5 mile commute. 3 miles of stoplights, followed by 6 miles of interstate, followed by 2.5 miles of stoplights. I was bored one month so I set up a mini-stat study where I did 5 morning commutes at 80 mph, and 5 morning commutes at 60 mph. randomized order, but making sure that each dataset includes one run on each monday, tuesday, etc...
    The 80 mph run wound up an average 30 seconds faster than the 60mph. After factoring distribution, it was just barely considered to be significant enough above the background noise. Turns out, it was the stoplights both before and after that equalized the time. MPGs differences however, were very significant. 21.1 vs 17.5.
    Currently, I'm running 65-70 mph, and getting 19-20 mpg on the commutes. My tank average remains at mid 17's to low 18's. As it also turns out, idling in the drive-through is what's really killing my gas. :anonymous::anonymous::anonymous:
    33yrsoftoys likes this.
  6. Mar 29, 2022 at 6:16 AM
    #66
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    It the same in some parts of major highways here...55 mph...go more than 10 over and it'll cost you. For the most part its 65, but everyone is doing 10, or more over. I use to do a a couple hare scrambles races a season in fish house ny...seemed 787 near albany was a stickler for 55 mph. I got a ticket a few times on that road, one ticket was for 57 mph....I told the sheriff that pulled me over to button his shirt his heart was falling out.
  7. Mar 29, 2022 at 6:22 AM
    #67
    Borracho Loco
    Borracho Loco My truck identifies as a Prius.
    DFW, Texas
    2021 Voodoo Blue - Tacoma TRD Offroad DCSB
    Oh look, another mod....
    In Texas we have a lot of Toll Roads. The speed limit for many of them are 70 or 75MPH. One Toll Road, down near Austin the speed limit is 80MPH. Also, the average MPH for highways in Texas is 65.
  8. Mar 29, 2022 at 6:51 AM
    #68
    33yrsoftoys
    33yrsoftoys Over 40yrs now
    joel
    mid Michigan
    2021 dcsb off road 6 speed manual
    Bilstein 6112's 5th clip 1/4" spacer driver's side. Icon tubular UCA's with Delta joint, wheelers superbumps, ECGS bushing. Allpro standard leaf packs, 5160's, U bolt flip kit with wheelers super bump's, extended stainless steel brake lines, carrier bearing drop. Icon rebounds 17" with Nitto terra grappler G2's 285/70/17's.
    I think you're really on to something with idling. My experience with winter MPG loss can be directly tied to cold startups, idling to get warm. Around a 2mpg loss.
  9. Mar 29, 2022 at 7:16 AM
    #69
    Horseshoez
    Horseshoez Well-Known Member
    Dale
    Maryland
    I've never understood why folks do that; the best thing you can do for your engine is to start it, click on your seatbelt, and then drive away at conservative speeds.
  10. Mar 29, 2022 at 7:50 AM
    #70
    NMBruce
    NMBruce Well-Known Member
    SW Colorado
    2020 Quicksand TRD OR, sold = 2006 GX470 (past 85, 2-1987 pickups,90, 92, 96 pickup, 2000 xtracab, 2002 double cab)
    Ironman Foamcell 3" lift, ARB dual compressor, GoPro mount, BadElf mount, Drive grab handle, RCI skids, Victory sliders, half rack, TuffStuff Alpha ll RTT, Dometic 75 Fridge, extra USB & Outlets
    That temperature reading is the Toque Converter temps reading, which I have been told is always 10-15° higher than the transmission temps reading.
    I want/need to add an aftermarket trans cooler, just started looking. In an early post, #52 I was talking about a trip and how it affected my torque converter temps, they got very hot. I am normally around 180-195, but live in the mountains so seeing 220 is common, when I am in 3rd gear pulling a hill, but then it drops right back down.
  11. Mar 29, 2022 at 8:15 AM
    #71
    zoo truck
    None
    It can get down to several degrees of -0 temps here when you start your truck. I let it idled a minute, or less till the high rpm idled down some before taking off. I've notice a bit more than 2 mpg loss. Its more like 3-4 during the winter. I guess it depends if you do more short trips to.
  12. Mar 29, 2022 at 8:32 AM
    #72
    Horseshoez
    Dale
    Maryland
    I live in New Hampshire so below zero temperatures are just an occasional fact of life. The fact is, letting your engine idle, even at sub-zero temperatures, is not a good thing to do.
  13. Mar 29, 2022 at 8:45 AM
    #73
    bulalo
    bulalo Well-Known Member
    SoCAL Inland Empire
    2017 trd offroad 4wd LB
    KDMax pro 9.0
    Thanks. This would be my next project . Tnx
  14. Mar 29, 2022 at 8:58 AM
    #74
    mosccat
    mosccat Well-Known Member
    Mark
    Currently in Bend, OR
    2020 OR
    Lol, my stock 2020 TRD OR LB sometimes gets 14mpg……….. when I’m pulling my 4,700lb travel trailer on the hwy.
    Aloha!
  15. Mar 29, 2022 at 9:15 AM
    #75
    mosccat
    Mark
    2020 OR
    It’s all about how you drive and knowing when the TC is locked or not. I just did a 3,400 ft climb up and over a 7,600ft peak and my tc temp didn’t get over 210’. This is with my 4,700lb travel trailer going from Alomogorda to Roswell and I averaged over 14mpg with a slight tailwind.
  16. Mar 29, 2022 at 9:17 AM
    #76
    mosccat
    Mark
    2020 OR
    Getting the best MPG is an art form….
  17. Mar 29, 2022 at 9:42 AM
    #77
    skeletron
    Clark
    Sakerlina
    2020 TRD Broh
    Or a 50mph tail wind lol
  18. Mar 29, 2022 at 9:44 AM
    #78
    mosccat
    Mark
    2020 OR
    Or longest downhill in USA (probably)… Mauna Kea summit (13,500ft ish) to sea level.
    skeletron[QUOTED] likes this.
  19. Mar 29, 2022 at 9:45 AM
    #79
    skeletron
    Clark
    Sakerlina
    2020 TRD Broh
    Ahhhhh yes that will do it too
  20. Mar 29, 2022 at 1:17 PM
    #80
    NMBruce
    SW Colorado
    agree
    when I hit those really high tc temps I was running 70mph into a 20mph head wind and in 3rd gear to keep 70mph. When I go over a mountain, one pass is 9400ft and the other 11,000ft.
