3rd gen having issues
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Onemoretaco, Apr 3, 2018.
  1. Apr 3, 2018 at 1:02 PM
    Onemoretaco
    Onemoretaco [OP] Active Member
    Ivan
    92530
    2016 mag gray 6 speed manual 4x4
    Nothing fancy just something to get around and go on the occasional trail ,KD max tune, Dry filter aFe intake. TE37X 16×8 -20offset wrapped in 285/75R16 Yokohama Geolandar M/T. Fox 2.0 up front and fox 2.0 with resi non-adjustable.
    Fellow Taco peeps, makes me sad to say that my first post on here is asking for help trouble shooting my 3rd gen, Its a 6 speed manual and I'm having issues not sure what it may be. I started getting this weird lost of power and when stepping on it it struggles/sputters on the way up of the RPM gauge CEL light flashes and trac off flashes, then when going to a stop it feels as it's going to give out, CEL was check and I got a cylinder 5 misfire, I checked everything and checked out perfect test drove and ran fine. So cleared the CEL and just the other day it did it again this time the cylinders were lettered and I got Cyl E and another I can't remember, also an air flow disturbance, checked it all once again and checked out fine. Drove and cleared once again but today it has begun to do the same thing. The CEL has not stayed on for me to be able to scan. Maybe someone has had a similar issue that can help? I'm at 46,000 miles my warranty is up. I would appreciate and help/advice. Thank you.
  2. Apr 3, 2018 at 1:03 PM
    CO_0321er
    CO_0321er Well-Known Member
    Isn’t the power train warranty out to 60k?
    STexaslovestacos likes this.
  3. Apr 3, 2018 at 1:05 PM
    dnlskier
    dnlskier Well-Known Member
    17' TRD SPORT MT
    AFE intake?
    Stocklocker likes this.
  4. Apr 3, 2018 at 1:06 PM
    Onemoretaco
    Ivan
    92530
    Toyota only gave me 25k not sure as to why
  5. Apr 3, 2018 at 1:07 PM
    Camel89
    Camel89 Well-Known Member
    Houston, TX
    2016 TRD OR 4x4
    25k is the free maintenance. Full warranty is until 36k. Powertrain is up to 60k.
  6. Apr 3, 2018 at 1:08 PM
    Onemoretaco
    Ivan
    92530
    Stock intake, flowmaster super10 exhaust
  7. Apr 3, 2018 at 1:09 PM
    Alesimo
    Alesimo Jeeper
    Alec
    Houston, Texas
    2020 Jeep Wrangler JLUD
    What is that sensor that people had going out? Maybe it's that. The cam thing??
  8. Apr 3, 2018 at 1:09 PM
    Onemoretaco
    Ivan
    92530
    Didn't know that! Ok I'll have to call and make sure and if so make an appointment! Thank you.
  9. Apr 3, 2018 at 1:11 PM
    woohoo_tacos
    woohoo_tacos Well-Known Member
    Atlanta
    2017 TRD off-road 4x4
    3” lift 285/70-17 TRD PRO wheels 17x7
    Cylinder E is cylinder #5. If you are getting this code first step is replacing the ignition coil and spark plug (always a good idea to replace in pairs). I am a tech and deal with this issue pretty often. It could be intermittent
  10. Apr 3, 2018 at 1:11 PM
    Camel89
    Houston, TX
    2016 TRD OR 4x4
    The crankshaft position sensor (CPS). It very well could be as it's a fairly common issue, at least on TacomaWorld..
  11. Apr 3, 2018 at 1:11 PM
    Onemoretaco
    Ivan
    92530
    Maybe! Maybe a cam sensor. They had a recall but I took it in before I had any issues a few months ago, it was the Crankshaft position sensor,
    Alesimo[QUOTED] likes this.
  12. Apr 3, 2018 at 1:13 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Make sure that you have a CEL with a stored code before you take it in.
  13. Apr 3, 2018 at 1:13 PM
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    hmmm. sometimes non-OEM exhaust systems do not have the expected back pressure that the factory sensors and computer detect. This could throw the computer system into fits.
    jsinnard and Onemoretaco[OP] like this.
  14. Apr 3, 2018 at 1:13 PM
    Onemoretaco
    Ivan
    92530
    Yeah maybe I was thinking the same I took it in for the recall I'm hoping it's that, I had no issues prior though.
  15. Apr 3, 2018 at 1:16 PM
    Onemoretaco
    Ivan
    92530
  16. Apr 3, 2018 at 1:18 PM
    Dirty Harry
    Dirty Harry Well-Known Member
    Andrew
    SW Florida
    2021 Tacoma 2.7 SR 4x4
    If you've got a oiled filter in your AFE it could also be you Mass Air Flow sensor.
    Onemoretaco[OP] and MOC221_ like this.
  17. Apr 3, 2018 at 1:23 PM
    Onemoretaco
    Ivan
    92530
    Thanks will do! Appreciate it!
    tonered[QUOTED] likes this.
  18. Apr 3, 2018 at 1:35 PM
    CO_0321er
    Definitely call, the lower train is to 60k so you should be good
  19. Apr 3, 2018 at 1:41 PM
    Alesimo
    Alesimo Jeeper
    Alec
    Houston, Texas
    That's the one! Thank you ha.
    Good luck OP!
