3rd Gen HID vs LED vs Halogen H11 projector headlights
Discussion in '3rd Gen. Tacomas (2016-2023)' started by crashnburn80, Jan 25, 2019.
  1. Jan 1, 2020 at 5:55 PM
    #2281
    glantzy
    glantzy Well-Known Member
    David
    2020 Cement Grey TRD Off Road Premium DCSB
    I’ve dug for info on this, and haven’t found a suitable thread, so I’m gonna post it here, where it’s kinda relatable, and you folks seem to have an understanding of this kinda stuff:
    So - my headlight indicator is always on. Now, I’m fine with daytime running lights operating at all times, but they operate exactly as the second position does. Attached below is a pic of my stock headlights (reflected in a window to showcase the differences.). Should the base position be any less? Should my light indicator be ON on the dash even when the lights are not “on”?
  2. Jan 1, 2020 at 6:04 PM
    #2282
    SpeySquatch
    2016 TRD OR DCSB
    Off should be off...that’s weird
  3. Jan 1, 2020 at 7:22 PM
    #2283
    CaliTaco718
    CaliTaco718 Instagram: socalmike9000
    Chapel HIll, TN
    2019 TRD Sport DCSB 4x4 MGM
    Falken AT4's.
    @BadDogMax can you send me the link please? I see a few of these on Amazon with different prices.
  4. Jan 1, 2020 at 7:24 PM
    #2284
    MrMccrackin
    MrMccrackin Well-Known Member
    Gilbert, AZ
    2004 TRDOR PreRunner, 2017 MGM TRDOR 4x4
    Do you have automatic headlights?
    If so that might be the reason when it’s dark the headlights come on even in the off position.
    Jpalafox likes this.
  5. Jan 1, 2020 at 7:24 PM
    #2285
    BadDogMax
    BadDogMax Well-Known Member
    IdahoLand
    2019 TRD Pro
  6. Jan 1, 2020 at 7:28 PM
    #2286
    glantzy
    David
    Daytime and nighttime...
  7. Jan 1, 2020 at 8:13 PM
    #2287
    Toy_Runner
    Toy_Runner Well-Known Member
    99 4Runner SR5
    3" OME lift, heavy coils f/r 3/16" steel skids Modified Coastal Offroad diy bumper 5spd swap ('98 donor)
    @150k
    Excellent explanation of how a projector lamp works. Thank you for the breakdown.
    As far as how the led viewing angle v intensity drop off, if the center axis offset could be minimized, would a multi-sided bulb be capable of minimizing the intensity drop off, in comparison to a double sided blade approach currently taken? And regarding the different focal zones of the reflector cup, two questions:
    1- if a drop in replacement bulb were to use a multi led array, would leds placed closer to the "base" of the reflector cup provide greater center intensity than the current double sided blade array?
    2- I have seen reference to a "chip flip" modification to a morimoto bi-led projector. Their led array was a triangular led array made of closely spaced small led chips, with (iirc) the tip of the triangular array pointed to the back of the cup. The mod is to flip the led 180, and (iirc) this results in higher hotspot intensity for better projection distance. Would having say a 1x2/1x3, led chip array (e.g. osram white or black flat or luxeon) located near the base of the blade stem perpendicular to the opposing facing LEDs representing the replacement "filament" result in better central hotspot intensity due to its close proximity to this throat of the reflector cup?
    150k likes this.
  8. Jan 1, 2020 at 11:49 PM
    #2288
    150k
    150k Member
    No, I don't think any 3+ sided LED bulb would be successful. The light-emitting area of any replacement bulb needs to fit within the dimensions of the bulb it's replacing. I don't think that's physically possible for a 3+ sided LED bulb. Better two-sided designs will be the answer.
    And I think we're basically there in terms of 2-sided designs. Even in a filament H11 bulb, there's so much "junk" in the way of the light-emitting area (filament) such as the supports, lead-in wires, black-top, base of the bulb, etc., that good LED chips shouldn't have much of an issue mostly matching. The most important paths of light emission would be contained within the gamma 1 angle on this 2D image.
    The above is just a 2D image. For a more complete perspective of what a reflector roughly "looks" at in a bulb, look no further than than this H11 halogen bulb:
    Most of the bottom 50% of the glass capsule is shaded blue because that's not important; light going out the bottom of the glass is basically going to hit the metal base of the bulb and not the reflector. Also, light traveling out the top 10% of the glass capsule isn't super helpful either, as it's traveling away from the reflector.
    And the big long wire in the back is shaded in blue. The big long wire itself is already blocking the filament from seeing the reflector (or vice versa) so the designers probably thought that the extra blue wouldn't hurt. Plus the more blue the bulb is, the cooler it looks. But the point is that there's a relatively small window on the glass through which the reflector sees the filament, which is good for LED chips, as they fall off rapidly in terms of intensity with changes in viewing angle. People like to talk a lot about how a bulb emits a "360 degree" pattern of light, which is roughly correct, but an automotive bulb has a lot of stuff in the way of light emission, so it's not that important for a LED bulb to emit a full "360 degree" pattern of light.
    The above is basically what the Europeans are saying here:
    The issue is that in most projectors, the heel of the reflector cup and the bulb's longitudinal axis are perpendicular. Unless we're talking about a relatively rare "side-entry" projector like on the 4Runner or Lexus IS. While having chips directly face the heel of the reflector would help with intensity, I'm not sure if the overall design--having a 3+ sided bulb--would be ideal, given the importance of matching the location, size, (and other characteristics) of the filament.
    I doubt a legitimate 3+ sided LED bulb will ever see the light of day, given the longstanding law that any automotive bulb must work in every fixture it can be plugged into. If I wanted to make 9006 bulbs tomorrow, then my 9006 bulb needs to, by law, work with a 1995 Toyota that takes 9006 bulbs and a 2032 BMW that takes 9006 bulbs. By work, I mean it must, among other things, create a compliant beam pattern.
    I doubt that whenever it comes time to "legalize" LED substitute bulbs, there will be an exception to this long-standing rule. That is, if someone in the future makes a legitimate 9006R (9006-retrofit) LED bulb, it must work in every 9006 headlamp. A 3-sided bulb is a non-starter for reflectors.
    Yes, the "designer" of the projector said that the flip defocuses the beam. I don't know much more in terms of specifics. I also doubt the validity of the "higher hotspot intensity" that people are claiming, partly because eyes, as I've shown, are easily misled. And a random peak lux reading somewhere in a beam is meaningless.
    I would be interested if someone sent the projector out for testing though, or did some useful in-house testing.
  9. Jan 2, 2020 at 2:27 PM
    #2289
    mynameistory
    mynameistory My member is well known
    Tory
    Redondo Beach, CA
    4Runner
    @crashnburn80 , do you have any info on the placement of auxiliary high-beam lamps according to the J581 standard? I plan on installing the SS3 pods in the front grill on the high-beam circuit, and want to make sure the mounting locations are compliant. For example, width between lamps, height to ground (is roofline or hood mounting allowed), etc. I know aiming is also pertinent to compliance.
    xxTacocaTxx and Toy_Runner like this.
  10. Jan 2, 2020 at 2:36 PM
    #2290
    Tullie D
    Tullie D Well-Known Member
    Tullie
    Wilson, NC
    2019 SR5 V6 SSM Access Cab
    Where did you get the crystal ball? How do you know that a 2032 BMW will take 9006 bulbs? :rasta:
  11. Jan 2, 2020 at 8:02 PM
    #2291
    crashnburn80
    crashnburn80 [OP] Vehicle Design Engineer
    Kirkland, WA
    2003 DCSB TRD OR
    Between 22” (min) and 54” (max) from the ground, on the same horizontal plane as far apart as practical.
    https://www.govinfo.gov/content/pkg/CFR-2004-title49-vol5/xml/CFR-2004-title49-vol5-sec571-108.xml
    Aux high beams should be mounted as high as practical to avoid shadows and the light being interrupted by changes in the roadway elevation. On my truck with a 2.25” lift and 1.5” larger tires, 54” will just hit the ditch light mount location. However hood glare is really counterproductive/harmful for your night vision, so I would keep them forward of the hood line.
  12. Jan 2, 2020 at 9:10 PM
    #2292
    Toy_Runner
    99 4Runner SR5
    @crashnburn80 does this also override state laws regarding auxiliary lighting requirements? E.g. lights above the oem headlamps must be covered with an opaque cover at all times? Even if thats plainly spelled out, I foresee a lot of tickets being handed out and a lot of magistrates getting pissy.
  13. Jan 2, 2020 at 9:24 PM
    #2293
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    I am not familiar with all the individual state laws. A state may make more restrictive laws than federal laws though (just not less restrictive), so you should follow the laws of your local jurisdiction. However, for practical purposes I’d mount the aux driving lamps at the same level as the OEM headlamps in front of the grill anyway, making it a non-issue. The ditch light location is not a good one for driving lights, I was just providing it as an example reference point based on the 54” max spec.
  14. Jan 3, 2020 at 9:38 AM
    #2294
    MrMccrackin
    Gilbert, AZ
    @crashnburn80
    Has anyone ever thought of changing the Aux Bed Lights to amber?
  15. Jan 3, 2020 at 9:42 AM
    #2295
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Are you referring to the TRD 3rd brake bed lights, on either side of the brake light? What would be the purpose?
  16. Jan 3, 2020 at 12:05 PM
    #2296
    MrMccrackin
    Gilbert, AZ
    Yes, those specifically.
    Wouldn’t amber/yellow be easier on the eyes and enable to see better?
    I wonder if they could double as “chase lights” ?
  17. Jan 3, 2020 at 8:25 PM
    #2297
    mynameistory
    Tory
    Redondo Beach, CA
    4Runner
    You should look at the work that MESO Customs is doing in this area.
    xxTacocaTxx likes this.
  18. Jan 4, 2020 at 5:33 PM
    #2298
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    For task lighting I'd use white. While amber/yellow is easier on the eyes, white will provide higher intensity and higher contrast and overall better visibility for tasks like securing things in the bed.
  19. Jan 4, 2020 at 6:54 PM
    #2299
    CaliTaco718
    Chapel HIll, TN
    Falken AT4's.
    Do LEDs in low and high beams affect the auto high beam function?
  20. Jan 4, 2020 at 7:45 PM
    #2300
    mynameistory
    Tory
    Redondo Beach, CA
    4Runner
    Yes, they make auto headlights less effective in the dark.
    xxTacocaTxx, Boghog1, DWD484 and 2 others like this.
