3rd Gen HID vs LED vs Halogen H11 projector headlights
Discussion in '3rd Gen. Tacomas (2016-2023)' started by crashnburn80, Jan 25, 2019.
  1. Feb 22, 2020 at 5:51 PM
    #2541
    JonWon
    JonWon Well-Known Member
    AZ
    2017 DCSB OR 4x4
  2. Feb 22, 2020 at 6:25 PM
    #2542
    crashnburn80
    crashnburn80 [OP] Vehicle Design Engineer
    Kirkland, WA
    2003 DCSB TRD OR
    gurneyeagle likes this.
  3. Feb 22, 2020 at 6:26 PM
    #2543
    JonWon
    AZ
    2017 DCSB OR 4x4
    Ah gotcha thanks for pointing that out : )
  4. Feb 22, 2020 at 8:47 PM
    #2544
    phdog
    phdog Well-Known Member
    Jim
    Northern Colorado
    2017 TRD Off Road
    w/Super Terrific Happy Hour Mod
    After reading and rereading the first page of this plus several other threads I'm confused as to what halogen bulb is the best upgrade over the OEM.
    I thought the answer was to put the Philips H9 bulb into the low beam but then elsewhere it says the GE Megalight Ultra +130 H11 is better or the GE Nightbreaker Xenon +120. These are over $40 for a pair with lower lifespan vs about $13 for two H9 bulbs.
    I'm inclined to the the Philips H9 since it's a cheap experiment. Any reason to think the Megalight or Nightbreaker is really that much better?
  5. Feb 22, 2020 at 9:16 PM
    #2545
    Juggernaut
    Juggernaut Captain
    Sacramento
    25 TRD OffRoad DCSB
    TLDR: H9 throws the most light, is the cheapest, and likely the longest lasting halogen. Only con is you have to trim the plug.
  6. Feb 23, 2020 at 1:49 AM
    #2546
    Tullie D
    Tullie D Well-Known Member
    Tullie
    Wilson, NC
    2019 SR5 V6 SSM Access Cab
    :frusty: :facepalm:
    PLUS you've got spares handy already (the high beam bulbs)
  7. Feb 23, 2020 at 7:11 AM
    #2547
    phdog
    Jim
    Northern Colorado
    2017 TRD Off Road
    Thanks. Got a pair on order.
    bamma likes this.
  8. Feb 24, 2020 at 7:48 PM
    #2548
    phdog
    Jim
    Northern Colorado
    2017 TRD Off Road
    This will no doubt get buried but in case you are lucky enough to find it, I may have a better way to modify the H9 socket for an H11 harness. The videos I watched talked about easily cutting the extra plastic tab inside the socket with side cutter, sharpe knife, scissors, etc. and one said the plastic was very soft. Well, the plastic on the Philips bulb is very hard and none of these worked. Another video used a Dremel and cutoff wheel but that just jacked up the socket.
    Anyway, no idea what this is called, but if you have a tool like below in your Dremel kit it works great. easy to control, small and fits inside the socket easily and doesn't do much unnecessary damage. Took maybe a minute or two. The tip on this one is really small like 1/16" or maybe smaller.
  9. Feb 24, 2020 at 9:25 PM
    #2549
    Anderson5290
    Anderson5290 Well-Known Member
    Brandon
    Corona, Ca
    2018 Tacoma TRD OR 4x4
    Tuned Fox 2.5 resi with dsc, JBA HD UCA, total chaos knuckle gussets, rear trd pro fox shocks, Deaver U402 stage 1 rear leafs, archive garage u bolt flip with fox 2.0 air bumps, White knuckle off road rock sliders, BAMF 1/4” steel skids, Magnaflow exhaust, Archive Garage Hammer Hangers, Cbi high clearance rear bumper, 285/75/16 tires.
    I heated up a razor blade with a torch and carefully removed the piece. Took me all but 5 mins to mod the H9 lights to fit.
  10. Feb 24, 2020 at 10:53 PM
    #2550
    Duezzer
    Duezzer Well-Known Member
    Glenn
    2019 Cavalry Blue TRD Sport
    Some - Will list later - has lift and new wheels and rubber
    What make the H9 so much brighter than the H11. Just drove home tonight with the H9s installed.
    I am so greatfull for your work!!!!!!
    crashnburn80[OP] likes this.
  11. Feb 24, 2020 at 11:49 PM
    #2551
    Sasquatchian
    Sasquatchian Well-Known Member
    It's a slightly higher wattage - 65w vs. 55w, likely has a more tightly wound filament which, in conjunction with the higher wattage, yields a higher luminance, with a shorter lifespan in return. They spec the H9 for high beams because of the luminance and also knowing that they don't get used nearly as much as the low beams, so most drivers will never know that they have shorter life. Just be sure to carry a couple of spares in your glovebox.
  12. Feb 25, 2020 at 7:43 AM
    #2552
    skierd
    skierd Well-Known Member
    David
    Fairbanks, AK
    2021 F150 XL STX Screw 4x4 2.7
    Burr grinder?
    I have a similar bit, but instead of a ball it’s a long skinny grinder instead of a ball and it’s what I used to mod my bulbs (among many other projects).
  13. Feb 25, 2020 at 9:04 AM
    #2553
    Duezzer
    Glenn
    Kept the H11s for back up. But thinking of ordering the H9s and mod them so they are ready to go in
  14. Feb 28, 2020 at 9:56 PM
    #2554
    150k
    150k Member
    Just want to confirm everything said so far. These are results from a Japanese OEM (Stanley) H11 halogen projector.
    • You might see a slight upgrade when converting from well-worn, stock/long-life type bulbs to a LED bulb with grandiose claims:
    • You might have better luck with a el-cheapo eBay/Amazon LED than a $150 LED bulb:
    • You might have more luck with a upgrade halogen bulb, like the GE Megalight +130 that's been mentioned many times, or similar (similar does not mean a Silverstar)
  15. Mar 2, 2020 at 8:36 AM
    #2555
    plasticsnaks
    plasticsnaks Well-Known Member
    Brett
    South TX
    2019 DCLB Off-Road
    Eibach stage 1 -wheeler’s 2” aal-spc uca’s FN 5 Star w/Falken Rubitrek AT 265/70r17. Nitro 4:88’s KDMax tuned Leer 100r
    https://www.amazon.com/Hakko-CHP-170-Stand-off-Maximum-Capacity/dp/B076M3ZHBV
    These work very well in modding the H9’s....and super quick!
    Very easily clips off the plastic ridge inside the plug and then just crimp or “indent” the steel base with the cutters then grab and twist off the piece.
    Takes a few seconds.
    MiTacoTRD likes this.
  16. Mar 2, 2020 at 10:50 PM
    #2556
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Revisited and updated with digital spectrometer readings. I'm playing catchup from equipment down time.
  17. Mar 9, 2020 at 10:10 AM
    #2557
    Jbarth
    Jbarth Well-Known Member
    Albuquerque, New Mexico
    2019 TRD OR
    Has there been an instrumented test on the 2020 LED Headlights in this thread?
  18. Mar 9, 2020 at 10:26 AM
    #2558
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Not yet. I hope to at some point.
    TheCochese and Jbarth[QUOTED] like this.
  19. Mar 9, 2020 at 10:34 AM
    #2559
    bshammer0
    bshammer0 Well-Known Member
    Brandon
    Nashville, TN
    2017 DCSB TRD OR 4x4
    Prinsu, TruckCovers USA, Coverking, OVTuned
    Thanks for posting these, I've been hoping for some time that we'd get some data on here regarding the quality of the Xtremevisions, and I've tried practically every halogen light that's been recommended and always come back to those Philips XVs. Even though other lights have a higher peak intensity/output, these Philips just seem "right" to my eyes in terms of color temp, contrast, uplight, peripheral vision, etc., What's even crazier is the 400hr bulb life considering the output
  20. Mar 12, 2020 at 6:06 AM
    #2560
    mhornco
    mhornco Well-Known Member
    gurneyeagle and xxTacocaTxx like this.
