3rd Gen HID vs LED vs Halogen H11 projector headlights
Discussion in '3rd Gen. Tacomas (2016-2023)' started by crashnburn80, Jan 25, 2019.
  1. Aug 10, 2020 at 10:47 PM
    #2981
    tattooedsnake
    tattooedsnake Well-Known Member
    Erick
    Connecticut
    '10 TRD sport 4x4
    -Bilstein 6112 front shock. Leveling lift -Bilstein 5100 rear shock w/TSB leaf pack. -Cooper Rugged Trek 265/70/17 -EBC front ultimax rotors w/yellow pads -Stoptech sport rear drums -Steel braided brake lines -Wet Okele seat covers front/rear with heaters -Custom built exhaust with Black Widow venom 250 muffler -Afe Stage 2 Dry CAI -Diode dynamics SS3 fog lights yellow. -OPT7 Projector Headlight Assembly w/Black backing -Undercover Flex Tonneau cover -Weather Tech floormats front and back
    Hmm...
    But for off-road only. Is that because of the recent NHSTA mandate on led replacement bulbs?
  2. Aug 10, 2020 at 11:05 PM
    #2982
    crashnburn80
    crashnburn80 [OP] Vehicle Design Engineer
    Kirkland, WA
    2003 DCSB TRD OR
    Replacement LED bulbs are not street legal in headlights and never have been. Any credible manufacture would state 'off road only' to avoid implying otherwise.
  3. Aug 11, 2020 at 11:35 PM
    #2983
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
  4. Aug 17, 2020 at 7:26 AM
    #2984
    Rainoffire
    Rainoffire Well-Known Member
    2017 QS DCLB TRD Sport
    Oh giggity!
    Took another 3 days for the right headlamp to arrive in my hands!
    Now just the harness...
    selrod, Aws123, MGMSangTaco and 4 others like this.
  5. Aug 17, 2020 at 1:45 PM
    #2985
    Invid
    Invid Well-Known Member
    New Braunfels, Texas
    2016 Tacoma Limited
    Nice. That's the TRD units?
  6. Aug 17, 2020 at 1:58 PM
    #2986
    Rainoffire
    On the box it actually says Limited Headlights.
    But, other than the TRD Pro, these LED headlights are an add on, only after you have optioned out for certain packages.
    I recall it is not available in Canada, except for the Limited and Pro.
    Invid[QUOTED] likes this.
  7. Aug 17, 2020 at 2:52 PM
    #2987
    Banggerr
    Banggerr Well-Known Member
    Out of curiosity where has everyone gotten their ge +130s? The sites I seem to find them in stock on seem rather not trustworthy
    davidstacoma likes this.
  8. Aug 17, 2020 at 2:56 PM
    #2988
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    Try these folks. I've always had good luck with them.
    https://www.powerbulbs.com/us/login
  9. Aug 17, 2020 at 3:00 PM
    #2989
    Banggerr
    Out of stock unfortunately... I guess people must’ve bought them out with their stimulus checks
    RCrumb likes this.
  10. Aug 17, 2020 at 3:04 PM
    #2990
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Tungsram is GE’s parent company. The GE label is no longer being used on automotive bulbs, and so the labeling is changing over to Tungsram. The product is identical.
    Banggerr[QUOTED] likes this.
  11. Aug 17, 2020 at 3:36 PM
    #2991
    DesignatedDriver
    DesignatedDriver Member
    2020 Taco
    Stock
    I have a 2020 Taco SR5 which has an h11 LED 55w bulb for the low beams and a Phillips - Germany h9 65w reflector for the high beam. The owner's manual lists both of these 'bulbs' as halogen but that is not correct. I called the dealer parts store and they tell me I can only replace the whole headlight assembly to replace one bulb. I don't believe them. I can't tell who made the h11 LED bulb as there seems to be no identifying markings on the LED 'bulb'. The low beam bulb is clearly marked by Phillips Germany. Any ideas on replacement LED 'bulbs' for future use when mine goes hasta la vista baby? I have read the whole first page of this thread and found it enlightening. Working on reading the other 151 pages. It seems to me that the 2020 model I have already has incorporated the better lighting system crashnburn80 suggested maybe due to this thread?
  12. Aug 17, 2020 at 3:49 PM
    #2992
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Welcome! If you have an LED low beam and a halogen high beam, it means someone put an aftermarket LED in your halogen assembly. The OEM LEDs do not have removable bulbs and the headlight assemblies are completely sealed, no serviceable bulbs. A replacement LED in the halogen assembly performs poorly, your LED is likely a downgrade and the halogen bulb upgrades will perform better in the halogen housing. No need to read all the pages, all the info is updated and contained in posts 1-3, save preliminary OEM LED testing in the last couple pages.
    xxTacocaTxx likes this.
  13. Aug 17, 2020 at 3:58 PM
    #2993
    Too Stroked
    Tom
    I'd be willing to bet your parts guy is mixing up which headlight assemblies you actually have. If you have H11 and H9 bulbs, you have the halogen housings. The optional (on lower trim levels) LED housings do not have replaceable "bulbs." I'd also bet if you pull either your low or high beam bulbs that you'll find they are indeed halogens. This of course assumes nobody slapped in aftermarket LED bulbs.
    As for ideas on LED bulbs for future use, do us all a favor and don't do it. No reputable manufacturer even sells LED headlight bulbs anymore. They've all been pressured to pull their dreadful products off the market by government regulators.
    Boghog1 likes this.
  14. Aug 17, 2020 at 4:00 PM
    #2994
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    I wonder if my unopened set still being labeled GE will be collectable one day :D
    El Duderino and davidstacoma like this.
  15. Aug 17, 2020 at 4:07 PM
    #2995
    DesignatedDriver
    2020 Taco
    Stock
    Crashnburn & stoked, I beg to differ with you. I just bought it straight from the dealer and it wasn't on the lot for more than several days. The dealership is a high volume one so they move a lot of Tacos. I have pulled the bulbs on both high and low and they are as I described. Would you like a picture? If as Crashnburn contends that I have an aftermarket headlight, then the dealership has done something that is uncouth and possibly illegal? Stoked you have lost your bet. What was the wagger? The vehicle is new manufactured in Mejico and just arrived before I bought it with less than 3 miles on the odo so I doubt that anyone put after market lights on at the dealership. It is a strange world is it not?
  16. Aug 17, 2020 at 4:09 PM
    #2996
    Kairide
    Kairide Well-Known Member
    2020 White SR5
    Being a fellow 2020 SR5 owner, I am almost 100% certain you have halogen low and high beams. I’m not even sure if LED headlights is an option on SR5s.
    Just try pulling a bulb, if you can, it’s halogen.
    Too Stroked likes this.
  17. Aug 17, 2020 at 4:09 PM
    #2997
    Too Stroked
    Tom
    Yes, I would love a picture of both the low and high beams bulbs.
    Spoiler Alert: I work in Service at a Toyota dealership.
    johnnyroid and davidstacoma like this.
  18. Aug 17, 2020 at 4:11 PM
    #2998
    Kairide
    2020 White SR5
    Does your Monroney sticker say you have LEDs? If not, than you don’t have legitimate OEM LEDs.
  19. Aug 17, 2020 at 4:18 PM
    #2999
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    It would be interesting to see a picture of the low beam bulb. Replacement LED headlight bulbs are not legal, and not used by Toyota or any other car manufacture. So if you have a replacement LED bulb in there, it was put in there after the vehicle left the factory.
    Tacotoast likes this.
  20. Aug 17, 2020 at 4:19 PM
    #3000
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    I bought mine from powerbulbs that @Too Stroked linked to. They still have 20% off with code LIGHT20
    If you’re looking for the H11 Tungsram (formerly GE) Megalight Ultra +130 They are here:
    https://www.powerbulbs.com/us/product/tungsram-megalight-ultra-h11-twin
    Or you can search the site
