3rd Gen HID vs LED vs Halogen H11 projector headlights
Discussion in '3rd Gen. Tacomas (2016-2023)' started by crashnburn80, Jan 25, 2019.
  1. Aug 18, 2020 at 10:20 PM
    #3061
    crashnburn80
    crashnburn80 [OP] Vehicle Design Engineer
    Kirkland, WA
    2003 DCSB TRD OR
    The GE/Tungsram H11 glare cap is oddly deep.
    NMTrailRider[QUOTED] likes this.
  2. Aug 21, 2020 at 10:20 PM
    #3062
    Rainoffire
    Rainoffire Well-Known Member
    2017 QS DCLB TRD Sport
    @crashnburn80 What are your thoughts on PPF for the headlights? Since I now have the new OEM LED headlights, I was thinking of applying the extra XPEL paint protection on them.
  3. Aug 21, 2020 at 10:36 PM
    #3063
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Personally not a fan of any kind of film on the headlights. All films, even clear, will reduce output to some degree and reduce focus, which reduces output intensity. The films typically fail long before the headlights OEM UV coatings would, and then you have to remove the film and hope it doesn't damage the headlight. Then you see threads on asking how to clear the adhesive or residue left behind off the headlight, and in doing so you may remove or harm the UV stabilizing coating meant to prevent the headlights from fogging in the first place. Unless you are somewhere that gets crazy sun like Arizona, I'd just trust the OEM UV coating. If you wanted more protection, I'd look to topically applied UV stabilizing products that are not permanet. Obviously topically applied products only help with UV and not rock chips. However, significant rock chips should be pretty minimal on a polycarbonate lens, UV is far greater threat to polycarbonate.
  4. Aug 22, 2020 at 7:46 AM
    #3064
    avi8or_co
    avi8or_co Well-Known Member
    2022 Lunar Rock TRD Sport
    Autogeek has some good products for that purpose. I used Optimum Opti-lens on my lights when they were new and my Lexus when I bought it new back in 16. It comes in a syringe type bottle and you apply it like a ceramic coating. They claim it’s permanent after cure and I believe it, the my IS is 4 years old now and the headlight surface is just as slick and clear as when I applied it. Not cheap at $70 but you can do 2 or 3 pairs of lights with it, my wife’s car got treated as well from the same bottle, a little goes a long way.
    907rx7 likes this.
  5. Aug 22, 2020 at 8:09 AM
    #3065
    MikeyMcFly
    MikeyMcFly This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 2021 WRX STI
    Building a Broja
    You earlier had made a post about the film not being optically clear and that prompted some reading of my own and I came to the same conclusions
    The big area I saw the issue was on Porsche forums. Porsche specifically mentions to not put film on their lamps.
    Seeing as the halogen Pro lamps have a tendency to lose their UV hardcoat early, I didn’t want to chance it. I’ve been doing Opti-Seal for now.
  6. Aug 22, 2020 at 6:50 PM
    #3066
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
  7. Aug 23, 2020 at 9:03 PM
    #3067
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    The OEM LED headlight has a very unique high beam compared to the OEM halogen or Morimoto LED units. Rather than focusing the light above the low beam cut off, there is very significant overlap of the high beam pattern with the low beam, it is aimed a lower than the stock halogen high beam. This should give exceptional down road visibility compared to the other options that just add uplight to the pattern. Still thinking about how to best present the data.
    Toy_Runner, SirWade, Aws123 and 3 others like this.
  8. Aug 24, 2020 at 1:31 AM
    #3068
    AustinMada
    AustinMada Thinking About Tacos
    WA.
    19 DCSB OR
    Throw some LEDs in that thing
  9. Aug 24, 2020 at 6:41 AM
    #3069
    Rainoffire
    Thank you for your input. I was worried, because I do have some rock chips on my original headlights and the OEM UV coating is actually already flaking on them, they are even ceramic coated with a bi-monthly maintenance wash. Is Opti-seal better?
    We actually get quite a lot of sun here, with a UV index of 10+ all year long. It was 12 today, and 11 for the remainder of the week.
  10. Aug 24, 2020 at 8:03 AM
    #3070
    MikeyMcFly
    I'm a Masshole
    Building a Broja
    After having the lamps on my truck for two months I was finally out after dark in a dark area (thanks COVID and two small children) and really got to play around with them.
    I have a KC 30” C-series bar under the grille and I found the high beams all but washed out the bar. With halogen lamps the bar would wash out the head lamps, low or high. They are simply that good.
    Curious what the actual numbers show. We all appreciate the work, it’s unreal.
  11. Aug 24, 2020 at 8:35 AM
    #3071
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    Question for you based on this. What would you do differently lighting-wise if you had started with the LED headlights? Just floods for camping while parked? Ditch lights only? Or bumper / grille / roof lighting still super helpful?
  12. Aug 24, 2020 at 11:26 AM
    #3072
    MikeyMcFly
    I'm a Masshole
    Building a Broja
    Oh man, fantastic question. I’d have the roof lights, no doubt because Marty McFly aesthetics.
    I don’t know if I’d have the front bar. The high beams do the majority of that. I’d have to think long and hard. Any auxiliary lighting of specific areas like ditch lights, would still make sense.
    Let me play around again on a dark night and I’ll confirm how good or bad they are.
    daveeasa[QUOTED] likes this.
  13. Aug 24, 2020 at 2:16 PM
    #3073
    bshammer0
    bshammer0 Well-Known Member
    Brandon
    Nashville, TN
    2017 DCSB TRD OR 4x4
    Prinsu, TruckCovers USA, Coverking, OVTuned
    Agree 100% - the Philips Xtreme Vision +100 are still by far my favorite halogen due to their color temp and wide field of view. I run them in both my lows and fogs and I've tried most of the other top performers on here and while I agree with peak intensity and distance there's always an element of "what looks right to your eyes" and these do the trick for me.
  14. Aug 24, 2020 at 2:19 PM
    #3074
    NMTrailRider
    NMTrailRider Well-Known Member
    New Mexico
    Agreed. The GE’s blast super bright straight down the road. But the Philips gives much better wide coverage. And on a dark Hiway, it’s overall more useful to me and my eyes.
    bshammer0[QUOTED] likes this.
  15. Aug 24, 2020 at 10:02 PM
    #3075
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    UV index of 10+ all year is surely brutal. I've honestly not experimented much with the applied UV coatings to give a review on which products are better. But I'd much rather apply a maintenance product like waxing the truck, that just wears off and needs periodic reapplying rather than something relatively permanet that will likely fail earlier than the OEM coating and the removal may damage the headlight and cause other issues. I hand wax my truck twice a year, in spring and fall. I'd just add headlight coating to that exterior maintenance interval.
    Rainoffire[QUOTED] likes this.
  16. Aug 24, 2020 at 10:48 PM
    #3076
    Rainoffire
    Thank you,
    I guess I'll just apply a thicker coating on the headlights then.
    Wish I had a garage, so this wouldn't be too much of a problem. Doesn't help that my apartment parking doesn't have a lot of shade.
    Do the tail lights also have a UV coating? They do not seem to fade as fast a headlights.
  17. Aug 25, 2020 at 4:48 AM
    #3077
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    That's exactly how it works....when you don't do your research first before buying them and then taking care to properly install and align them.
    Boghog1 likes this.
  18. Aug 25, 2020 at 9:06 AM
    #3078
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Parking under a cover in the shade would definitely be the most ideal defense. Taillights are commonly made of acrylic which is far more resistant to UV and doesn't need a coating, unlike the polycarbonate the headlights are made from. Though in the case of the 3rd gen Tacoma they may be polycarbonate, if so they would also have a coating. If they have a clear outer plastic layer (like 2nd Gen), it is likely polycarbonate. If the outer plastic is colored, it will be acrylic. I haven't paid close attention to the 3rd Gen tails.
  19. Aug 25, 2020 at 9:21 AM
    #3079
    Rainoffire
    Interesting info to know. Didn't know they would be made out of different materials. Is there a reason why? Lens clarity?
  20. Aug 25, 2020 at 9:49 AM
    #3080
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Polycarbonate has significantly greater impact resistance. I'd actually withdraw my polycarbonate statement for the taillights (I started to 2nd guess myself) even with a clear layer they are likely acrylic. Acrylic can be optically clear, it just doesn't do as well with impact resistance which isn't typically an issue on the back of a vehicle.
