3rd Gen HID vs LED vs Halogen H11 projector headlights
Discussion in '3rd Gen. Tacomas (2016-2023)' started by crashnburn80, Jan 25, 2019.
  1. Feb 15, 2019 at 6:39 PM
    #301
    kakwvu
    kakwvu Almost Heaven
    Kyle
    WV
    ‘24 JLURX
    Modesto Tacoma and Geeterman like this.
  2. Feb 15, 2019 at 6:57 PM
    #302
    El Duderino
    El Duderino Obviously, you're not a golfer.
    Jeremy
    HI->PNW
    19 nautical blue SR5 premium 4x4
    Stuff, things, this, an ADS
  3. Feb 15, 2019 at 8:41 PM
    #303
    Rodchester
    Rodchester Well-Known Member
    Baton Rouge
    2017 Quicksand SR5 DCSB V6
    Weather tech mats, LED interior lights and reverse lights, tube steps, bed extender, bed mat, folding bed cover, TRD Pro grill, blacked out badges and wheel center caps. Kicker speakers(all 6). Front bed rail header. Under hood LEDs. Tufskinz door and interior foam inserts. Chrome interior door handles. Fumoto drain valve. Aluminum oil filter canister. Rear view mirror with Homelink. Quick charge USB charging ports. TRD badge on grill. MESO fuse box cover. Redline Tuning hood struts. Ceramic coating. Pop & Lock auto tailgate lock. LED bed lights. Lower bumper LED light that bar. MESO coin holder. TRD cat back exhaust. Hikari Ultra LEDs high and low beams. 2020 TRD Sport wheels and TRD center caps. RSC Nano dashcam. DSM from the Taco Garage. Blue Sea dual USB outlet on back of center console. KDMax7.0
    It’s going to be interesting to see how the 2020s compare. Looks like they will come stock with LEDs (available).
  4. Feb 15, 2019 at 10:09 PM
    #304
    crashnburn80
    crashnburn80 [OP] Vehicle Design Engineer
    Kirkland, WA
    2003 DCSB TRD OR
    If you want a mid-upgrade with longer life, then yes. GE +130s will be significantly better but pay for it with much shorter bulb life.
    It will be, but the OEM LED reflector headlights don’t look thrilling. Typically lights like those will be stock like performance, but just LED instead of halogen meaning they are whiter but not much if any brighter. However they are then not upgradeable without replacing the housing. I don’t have high hopes for them, I’d bet the Morimoto LED headlight assemblies are brighter at a more reasonable cost though it would be very interesting to see how the beam pattern compares.
    Too Stroked likes this.
  5. Feb 15, 2019 at 10:32 PM
    #305
    NMTrailRider
    NMTrailRider Well-Known Member
    New Mexico
    I'd prefer halogens tbh. And retain the ability to upgrade rather than be stuck with a mediocre led.
  6. Feb 15, 2019 at 10:35 PM
    #306
    NMTrailRider
    New Mexico
    For what it's worth- My last set of those Philips 100's lasted 26 months. That's in comparison to 12 months for the Silverstars I ran before the Philips. Obvs not all drivers will see the same longevity.
  7. Feb 15, 2019 at 10:43 PM
    #307
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Same here, but I am one who also likes the ability to upgrade and tinker with my lights.
    Actually sounds pretty on par. I think those are rated at 450 hours. Mine are 200 hours and last a year.
    NMTrailRider[QUOTED] likes this.
  8. Feb 15, 2019 at 11:12 PM
    #308
    NMTrailRider
    New Mexico
    I like tinkering, too. I just like trying new stuff and studying the differences and varying characteristics.
  9. Feb 15, 2019 at 11:22 PM
    #309
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    For sure. I want to put together the best headlight setup possible and want the modularity. To get locked into a basic off the shelf LED setup that matches a stock H11 in output just seems depressing if caring about output over color temp. But I’m sure there are also those that are thrilled over LED for color temp and maintenance compared to halogens.
  10. Feb 16, 2019 at 1:22 AM
    #310
    Pro-Taco
    Pro-Taco Well-Known Member
    Lou
    Commiefornia
    2019 OR DCSB 4X4 Prem/Tech Cement
    All TRD Pro parts
    I don't think Toyota's new LED headlight will be reflector based. All LEDs have some type of projector (jewel) in them, nor do I think they will be as bad as regular halogens. Judging by what's out there right now, they should be on par with other LEDs or even better. Oh, and Morimoto is late to the party. I'd personally buy OE headlights rather than the aftermarket.
    Paulndot likes this.
  11. Feb 16, 2019 at 5:07 AM
    #311
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    Unfortunately, you're probably right on the performance of OEM Tacoma lighting. The Insurance Institute for Highway Safety now rates Headlight Performance and basically, everybody sucks. (And it doesn't mater if you're running halogen, HID or LED as a light source.) Based on what we've seen so far, I doubt anybody's going to significantly raise the performance bar on anything other than a high performance (and high dollar) vehicle. That said, they'll still probably be better engineered than the aftermarket crap that will undoubtedly appear shortly afterwards.
  12. Feb 16, 2019 at 5:12 AM
    #312
    kakwvu
    Kyle
    WV
    ‘24 JLURX
    If you can find them :)
  13. Feb 16, 2019 at 5:17 AM
    #313
    Too Stroked
    Tom
  14. Feb 16, 2019 at 5:20 AM
    #314
    kakwvu
    Kyle
    WV
    ‘24 JLURX
    trazerr likes this.
  15. Feb 16, 2019 at 6:15 AM
    #315
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    I assume the new Tacoma LED headlights will be like the Tundra's LED setup :notsure:
  16. Feb 16, 2019 at 7:36 AM
    #316
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    They have already released photos of them, they are down firing LED reflector headlights. Look up images of the 2020 Tacoma and check out its headlights. As for performance one can only speculate at this point till they are actually tested.
  17. Feb 16, 2019 at 12:37 PM
    #317
    smikec
    smikec Well-Known Member
    I guess I'm not understanding the concern about bulb longevity.
    Do you not drive your truck because it's going to need gas?
    You fill your tank regularly, but won't change a bulb (that costs less than a tank of gas) every few years? and is just as easy to do.
    Confused.
  18. Feb 16, 2019 at 12:41 PM
    #318
    smikec
    but this isn't a Yukon, it takes 30 seconds at worst on our trucks.
    Tacosrus likes this.
  19. Feb 16, 2019 at 1:05 PM
    #319
    NMTrailRider
    New Mexico
    Some people just don't like to mess with it. They're satisfied with a little less performance if it means they don't need to change their bulb for 6 years. And even then, they'd probably have someone else change it for them.
    Likewise, some don't wanna spend $60/year on bulbs for arguably minimal gains in performance when they can spend $20 and never buy a bulb again.
    Different strokes for different folks. No biggie.
    JeffB, trazerr and Boghog1 like this.
  20. Feb 16, 2019 at 1:07 PM
    #320
    smikec
    agreed, no biggie
    makes you wonder why they are in a performance lighting thread then
    wideloadwillis likes this.
