3rd Gen HID vs LED vs Halogen H11 projector headlights
Discussion in '3rd Gen. Tacomas (2016-2023)' started by crashnburn80, Jan 25, 2019.
  1. Oct 12, 2020 at 3:48 PM
    #3421
    Kairide
    Kairide Well-Known Member
    2020 White SR5
    If it's a good aftermarket LED than it will have a warranty. Morimoto Bi-LED MLED 2.0 projectors and their XB LED headlights both have 5 year warranties. The AlphaRex LEDs have a 2 year warranty. I'd be happy with a 5 year warranty on a product.
    Toyota's bumper to bumper warranty is 3/36,000, I'm assuming their LED headlights are included as part of the bumper to bumper, but not 100% sure. If so, the aftermarket warranty with Morimoto is actually better than Toyota's.
    If the truck is 10+ years old, I'd expect minor issues.
    GarlicFarts[QUOTED] likes this.
  2. Oct 12, 2020 at 10:23 PM
    #3422
    crashnburn80
    crashnburn80 [OP] Vehicle Design Engineer
    Kirkland, WA
    2003 DCSB TRD OR
    I have not. But retrofits are a highly customized product with a lot of variables vs an off the shelf top quality OEM grade solution. While higher peak intensity output would be achieved with a quality retrofit using OEM components, I'd advocate for the OEM LED solution between the two. Also note that retros are not legal, so if your state does inspections they would likely not pass.
    GarlicFarts likes this.
  3. Oct 13, 2020 at 4:21 AM
    #3423
    GarlicFarts
    GarlicFarts Bertolli Roberto
    Lil Rhody
    2020 White DCSB TRD OR
    SOS bolt-on sliders In-cab sleeping platform J-Dub IFS Skid
    coming from a state that does inspection I can shed some light on this.
    there are laws about exhaust noise. If it’s anything BUT what comes from the factory it can get you nabbed for a fix it ticket (I think we don’t do those in RI I think it’s just a fine and you have to show up to traffic court regardless).
    lights - same way. As long as they are the same or similar to OEM you’re fine. So an HID ballast in halogen housings is a no go.
    in RI at least. 3.5.17.B.2 says
    So you can go out and get an SAE headlamp assembly no problem, but once you start fiddling with it at all, it’s illegal. Tint, retrofit, etc. all illegal.
    practically speaking, last time I went for an inspection (before they implemented the cameras recording) I was worried about my tires being at the minimum or a hair below minimum tread. They plugged in and didn’t even turn on my lights. As long as it isn’t obnoxiously obvious, you’re good.
  4. Oct 13, 2020 at 7:22 AM
    #3424
    El Duderino
    El Duderino Obviously, you're not a golfer.
    Jeremy
    HI->PNW
    19 nautical blue SR5 premium 4x4
    Stuff, things, this, an ADS
    Retros are illegal for Hawai’i state inspections. Drop in LEDs will also fail you.
  5. Oct 13, 2020 at 7:57 AM
    #3425
    GarlicFarts
    Lil Rhody
    Actually. Now that I read it...
    http://www.dmv.ri.gov/documents/manuals/Official_Manual_Motor_Vehicle_Inspections.pdf
    This does not prohibit the bulbs, this is explaining the assembly only in this section. You cannot use a non DMV approved (probably defacto SAE approved) headlamp assembly. You cannot tint over headlamp assemblies.
    There's nothing, I guess, that says you (in Rhode Island) cannot use a non-oem headlight bulb in the approved headlamp assembly.
    :boom:
    From Hawaii:
    http://hidot.hawaii.gov/highways/files/2013/11/HAR19-133.2-10-22-2013.pdf
    Actually. 19-133.2-32 is similar to RI. They restrict the lamps, but nothing about the bulbs shall be OEM level or similar. They can't reject for non-OEM bulbs. "Not of an approved type or color" is the lamp itself, so the same deal - SAE/approved housings. In theory, Hawaii has no leg to stand on to reject non-OEM bulbs. They may have some candle power ratings they would violate, but just because it's non-OEM (LED, etc) is not a rejectable reason.
    PS - I am an Aerospace Quality Engineer. Reading through specs and regulations to find how to conform and the ways where these requirements don't make sense. It's boring as hell.
    El Duderino[QUOTED] likes this.
  6. Oct 13, 2020 at 8:20 AM
    #3426
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    I’m chuckling to myself thinking about you trying to argue your point to a Kamehameha grad police officer or judge.
    6MTPro, Toy_Runner, Boghog1 and 3 others like this.
  7. Oct 13, 2020 at 8:24 AM
    #3427
    GarlicFarts
    Lil Rhody
    I wouldn't. I know it would be an uphill battle and the end result wouldn't be: You can use your lights, it would be: We've changed the laws or had an official interpretation that you're an idiot.
    BUT as they're written. :notsure:
    More hassle than it's worth. Grab some cheap-o H11s to put in during inspections if you're that dead set on not using normal H11s.
  8. Oct 13, 2020 at 8:53 AM
    #3428
    El Duderino
    Jeremy
    HI->PNW
    Judge is either Punahou, St Louis, or I’olani grad lol. Police for sure Kamehameha lol
    6MTPro likes this.
  9. Oct 13, 2020 at 9:36 AM
    #3429
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    RI does have fix it tickets. I got one once that said I had 10 days to get the problem fixed and the car inspected at a state owned inspection facility. I was able to get around it though. I've never had an issue with aftermarket exhaust.
  10. Oct 13, 2020 at 9:46 AM
    #3430
    boston23
    boston23 Well-Known Member
    Adam
    Eastie
    2019 SR5 DCSB 4x4
    Can someone please tell me which bulbs I can toss in my factory housings to brighten up my high beams?
  11. Oct 13, 2020 at 10:23 AM
    #3431
    avi8or_co
    avi8or_co Well-Known Member
    2022 Lunar Rock TRD Sport
    Pretty sure that’s been covered...In crash’s testing I think he found the stock H9 is the best option in the stock high
  12. Oct 13, 2020 at 10:29 AM
    #3432
    Rainoffire
    Rainoffire Well-Known Member
    2017 QS DCLB TRD Sport
    Everytime i read Kamehameha, Dragon Ball is the first image that comes to mind.
    I'm like, what does Goku have anything to do with headlights?
    El Duderino, GarlicFarts and Boghog1 like this.
  13. Oct 13, 2020 at 10:42 AM
    #3433
    Kairide
    2020 White SR5
    I never had issues in Hawaii getting my motorcycle to pass inspection with aftermarket HIDs. They were more interested in ensuring all the lights actually function, they didn't really care what type of lights they were.
    El Duderino likes this.
  14. Oct 13, 2020 at 10:57 AM
    #3434
    Invid
    Invid Well-Known Member
    New Braunfels, Texas
    2016 Tacoma Limited
    Same for me in Texas. They just ensured that the lights came on and didn't care about the bulb type. Easy pass every year with my HID units.
  15. Oct 13, 2020 at 10:59 AM
    #3435
    boston23
    Adam
    Eastie
    2019 SR5 DCSB 4x4
    Just so much data, i’ve re read the first post several times. I’m not sure what product his testing results are pointing to
  16. Oct 13, 2020 at 11:42 AM
    #3436
    travadol
    travadol Well-Known Member
    Travis
    Prairies, Canada
    2020 Cement DCSB OffRoad Premium
    You know, I wish my province in Canada did inspections. I know people advocate for smaller government, and I generally agree. However, the amount of obviously illegal headlight/tailight/wheels etc make driving here a nightmare. SO MANY aftermarket LED lights in reflector housing. I'm sick of being blinded when I'm working at night. The only thing cops routinely nab people on is front side window tint.
    mikmabz, ownubad and GarlicFarts like this.
  17. Oct 13, 2020 at 11:44 AM
    #3437
    Toy_Runner
    Toy_Runner Well-Known Member
    99 4Runner SR5
    3" OME lift, heavy coils f/r 3/16" steel skids Modified Coastal Offroad diy bumper 5spd swap ('98 donor)
    Basically all of his testing points to:
    H9 for lowbeam being the best bang/buck spent.
    H11 GE/Tungsram brand Megalight +120 or +130 for about 13-15% higher max intensity than the Philips H9 in low beam. However, these are 1- significantly more expensive than the H9. But the trade off is that the H9 will put more light throughout the total beam pattern, whereas the + focus rated H11's should keep overal lighting the same, but provide further reaching low beams.
    The rebased HID kits for h11/H9 lowbeam suffer from a few problems, they tend to "bounce" in the housing, they're illegal, and along with being the brightest option for low beam (basically 2x the max intensity of the + rated H11's) theybl also cause MASSIVE amounts of glare for oncoming traffic.
    The highbeam already uses H9's. There are no + focus rated H9's because H9's are already a high spec bulb. If you need more light with highbeams, you really need to look at aftermarket SAE compliant auxiliary highbeams/driving lights.
  18. Oct 13, 2020 at 12:08 PM
    #3438
    GarlicFarts
    Lil Rhody
    I live in RI, near the MA border and grew up in NH and ME, also near the MA borders.
    I can tell you....our inspections solve none of that.
    Toy_Runner and Boghog1 like this.
  19. Oct 13, 2020 at 12:09 PM
    #3439
    travadol
    Travis
    Prairies, Canada
    The more you know!
  20. Oct 13, 2020 at 12:17 PM
    #3440
    avi8or_co
    And also....public service announcement.....please just replace your $5-20, whichever you may choose to install, low beam bulbs rather than simply using your high beams at night because you’re too fking cheap or lazy to stop at autozone.
    Apparently that is a becoming a common thing here in Central FL, and I can imagine other places, as you can clearly see a low beam is burned out on their car because one low is on and the other is not along with their high beams being on. I will continue to return the favor with my much brighter than your high beam light bar in the hood scoop.
    Aws123, Toy_Runner and GarlicFarts like this.
